Old Jul 31, 2015, 09:33 PM
yorkiepap is online now
Find More Posts by yorkiepap
yorkiepap's Avatar
SW PA
Joined Aug 2010
Question
Determining motor kv.....
Hey guys,
I have an old ArtTech 1000mm w/s F4U that I'm planning to use at our clubs' warbird races. It is an "el cheapo" & I won't fret if I total it since it has a very brittle foam construction. I finally maidened it a couple weeks ago & it flew fine, albeit quite slow for the warbird pylon racing. I removed the 11 X 6 X 3 stock plastic prop & replaced it with a Xoar wood elec. prop 12 X 8 X 2blade. The stock 20A ESC read 17.5A full throttle with a 35c 2200 3S battery & somehow still felt like it was lacking "pulling power". I put in a 4S just to "feel" the difference & definitely was better, although the motor & newly installed Turnigy Plush 30A ESC were both hot after 3min full power.
Ok, there are no markings on the motor at all. How do I determine, if possible, what KV the motor is or can't that be calculated? The only data I could find was that it is a C4038-15. Here's the link for the plane listing. Thanks for any help...
Denny
http://www.nitroplanes.com/at-21148-f4u-arf.html
yorkiepap is online now Find More Posts by yorkiepap
Old Jul 31, 2015, 11:28 PM
JureZ is offline
Find More Posts by JureZ
Sokol
JureZ's Avatar
United States, CA, Palm Springs
Joined Jul 2013
read here : http://www.bavaria-direct.co.za/constants/
scroll down until you see: " The Drill Press Method"
JureZ is offline Find More Posts by JureZ
Old Aug 01, 2015, 04:32 AM
ronaldopn is online now
Find More Posts by ronaldopn
ronaldopn's Avatar
Brazil, RJ, Rio de Janeiro
Joined Oct 2012
Very simple method if you have a digital tachometer and wattmeter, voltmeter or even a lipo voltage indicator:
- have your power system ready and connected (Rx, ESC and motor)
- put a strip of metallic tape outside the rotor. This tape will reflect the tachometer laser and give rpm readings.
- Remove any prop or adaptor from motor and fix it in a vise (I usually just hold it in my hands)
- Turn on the Tx
- Plug the battery to the ESC
- power up to full throttle an check your rpms and voltage
- motor kv=rpm/voltage
Here is a link for a test I did (the lamp is used to help tachometer readings)
https://drive.google.com/file/d/0B77...RRWjduUTQ/view
ronaldopn is online now Find More Posts by ronaldopn
Old Aug 01, 2015, 06:00 AM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
The Electric Motor Constant Kv
AKA The Generator Constant, RPM/volt, Annotated as Kv
http://theampeer.org/Kv/kv.html
Ken Myers is offline Find More Posts by Ken Myers
Old Aug 01, 2015, 10:28 AM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Was this a static run of 3 minutes? Of course it will get hot! How hot? Too hot to touch?
A 12/8 could very possibly pull far more than 17A on 3S. On 4S, I'd drop back to a 10/8 and test max static current briefly to establish max numbers, then fly it and recheck motor/esc heat. Esc/ motors are not designed to be stationary and must have adequate air flow to live.
Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Aug 02, 2015, 08:42 PM
yorkiepap's Avatar
SW PA
Joined Aug 2010
Thanks for the responses guys. I'll fly it on 3S & try a 4S in the air to see how it does. I have a nice assortment of replacement motors so I'll check to see what will improve the planes' speed a bit. I'm not looking for a speed demon.....just something competitive.
Denny
Old Aug 04, 2015, 04:23 PM
KRProton is online now
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
When I want to do a quick kV check I connect the motor to a data logging ESC (like most Castle Creations ESCs). I connect a battery, run the motor at full throttle for two or three seconds (no prop of course), then read the voltage and rpm in the data log from that run and do the math (rpm divided by voltage = kV).
I've read about the drill method and of course reading the rpm with a tachometer and the voltage with a Watt meter (which I've done, but also subject to a little human error and interpretation), but I wonder how much more accurate those are than reading the data from an ESC?
Tim
KRProton is online now Find More Posts by KRProton
How to determine Kv of unknown motor? rsieminski Power Systems 10 Jan 08, 2015 10:18 AM
For Sale DT750 motor, 1400 KV motor 1450 KV motors etc free_diver Aircraft - Electric - Multirotor (FS/W) 0 Nov 26, 2014 07:26 PM
Discussion It's possible to determine the Kv of a motor with accuracy ? A scientific approach. u0000 Electric Motor Design and Construction 14 Jun 29, 2011 11:41 AM
Question Help determining Kv of a motor from a data sheet. bigmark61 Power Systems 2 Feb 15, 2008 12:41 PM
Determining Kv Dr Kiwi Power Systems 30 Feb 07, 2006 11:55 AM
