Old Aug 26, 2015, 04:35 PM
danpos is offline
Find More Posts by danpos
danpos's Avatar
Canada, NB, Fredericton
Joined Dec 2011
Originally Posted by Scamp73 View Post
Has anyone found non E-Flite retracts that work good and fit this bird?
CORRECTION>
USE THESE INSTEAD
http://www.hobbyking.com/hobbyking/s...dProduct=14838
I'm using these in mine with the stock wheels and legs .
danpos is offline Find More Posts by danpos
Old Aug 26, 2015, 07:22 PM
Scamp73 is offline
Find More Posts by Scamp73
United States, NC, Autryville
Joined Jan 2012
http://www.hobbyking.com/hobbyking/s...ount_2pc_.html
Did they require any mod or pretty much screw in?
Scamp73 is offline Find More Posts by Scamp73
Old Aug 27, 2015, 08:17 AM
danpos is offline
danpos's Avatar
Joined Dec 2011
If I remember right they dropped right in. Or required a very small amount of trimming to fit.
I used them with oleo struts too.
Here is an old video that my daughter took while I was flying the P-51B with the retracts and oleo struts. This is before I installed a nitro engine in the Mustang.
Eflite P-51B close call. (3 min 10 sec)
At the beginning of the flight I lost radio contact for a couple seconds. I thought it was gone.
If you look close you can see it tumbling to the ground for a couple seconds. It was fast recovery. Lucky I didn't lose to much speed when that happened.
Old Aug 27, 2015, 09:10 AM
danpos is offline
danpos's Avatar
Joined Dec 2011
Just to be clear on what I found was the best combination of retracts and oleos for this plane.
Retracts- (you need to buy two).
(they will work with the stock struts even though the stock struts are only 4mm)
Oleo struts.
http://www.hobbyking.com/hobbyking/s...Class_2pc.html
I also suggest you change the pin in the retracts to music wire.
Discussion E-Flight Platinum series P-51b nitro_star Scale Kit/Scratch Built 2 Aug 27, 2010 04:09 PM
Question E-flite p-51b RCDestroyer Electric Plane Talk 4 Aug 26, 2010 12:10 PM
Sold ESM P-51B Mustang - "Frank Tiano Series" mustang1971 Aircraft - Fuel - Airplanes (FS/W) 8 Jun 06, 2010 02:32 PM
For Sale Nib E-flite platinum series AT-6 Texan w/ optional accsry's lavochkin Aircraft - Electric - Airplanes (FS/W) 8 Mar 31, 2009 06:51 PM
For Sale NEW - Top Flite P-51B Mustang #RARE# JimJams Aircraft - Fuel - Airplanes (FS/W) 5 Apr 13, 2006 05:17 AM
