Old Aug 16, 2015, 10:30 PM
7127 is online now
Find More Posts by 7127
United States, CA, Elk Grove
Joined Mar 2014
Motor recommendation
Can anyone recommend a replacement motor and propFor my MXS, specifically from hobbyking . I'm using a 3 cell battery.
7127 is online now Find More Posts by 7127
Old Aug 16, 2015, 11:37 PM
moteasa is online now
Find More Posts by moteasa
Quit making stuff I must buy!
moteasa's Avatar
United States, TN, Smyrna
Joined Feb 2014
http://www.hobbyking.com/hobbyking/s...dProduct=26482
They have no props worth a crap though.
moteasa is online now Find More Posts by moteasa
Old Aug 17, 2015, 03:28 AM
GoAround is offline
Find More Posts by GoAround
Can't fly 3D for toffee ...
GoAround's Avatar
United Kingdom, Taunton
Joined Dec 2012
I use the props linked to below. I get them from the UK warehouse and don't see them listed for US. They are very strong, fit the T Motor 2206 perfectly, cost next to nothing and work great. I use the 7" versions on the Minis and 10" versions on the 39".
My second favourite are the Tuff. They are not as 'tuff' as the Turnigy stuff though ..
http://www.hobbyking.com/hobbyking/s...5SF_4_pc_.html
GoAround is offline Find More Posts by GoAround
Old Aug 17, 2015, 10:57 AM
Springbok14 is offline
Find More Posts by Springbok14
Joined Aug 2015
Originally Posted by ROLLING CIRCLE View Post
Good to hear that the problem seems to have been diagnosed. The MXS-C is pretty tough so should be pretty easy to swap servos. Very strange to have a whole set of bad servos... Send TH an e-mail. Hopefully Brad can help you out somehow.
Yes the servos swapped out fairly easily (thankfully!)
I got the plane up for its maiden flight yesterday and everything worked perfectly. What an incredible piece of engineering this little thing is!
I couldn't wipe the grin off my face while it was airborne.
I'll try emailing TH and see if they can do anything for me regarding the original servos, hopefully they'll be able to throw me a bone.
Judging by how this MXS-C flies I will likely be purchasing more planes from them.
Thanks for the help everyone.
Springbok14 is offline Find More Posts by Springbok14
Old Aug 17, 2015, 03:00 PM
ROLLING CIRCLE is offline
Find More Posts by ROLLING CIRCLE
TEAM TWISTED
ROLLING CIRCLE's Avatar
United States, MD, Middle River
Joined Dec 2011
Great to hear it Springbok!
Cody would be very proud to hear about your satisfaction with the MXS-C. He does nice work and it's great to hear from those that appreciate it.
Could there be another Wojcik design in our future...
ROLLING CIRCLE is offline Find More Posts by ROLLING CIRCLE
Old Aug 17, 2015, 03:20 PM
KamikazePilot is offline
Find More Posts by KamikazePilot
Twisted Do Nut!
KamikazePilot's Avatar
Joined Dec 2010
The possibilities are high on that. Haha!
Good deal Spring enjoy the mini.
KamikazePilot is offline Find More Posts by KamikazePilot
Old Aug 17, 2015, 03:52 PM
daft pilot is online now
Find More Posts by daft pilot
#14 royal wulf
daft pilot's Avatar
bluegrass state
Joined Dec 2009
Cody is a beast! He's gotta be one of the most entertaining people I've ever seen fly. His style is unique and his skills are clearly world class.
One of my all time favorite rc flying vids. Really sick stuff....
Extreme Flight 60" Laser EXP (5 min 21 sec)
daft pilot is online now Find More Posts by daft pilot
Old Aug 29, 2015, 08:38 AM
steve_rc is online now
Find More Posts by steve_rc
United States, MD, Monrovia
Joined Jul 2014
CG confusion
I finished building my MXS and started balancing the plane. The manual says the CG is 3.56" behind the leading edge or 1.25" behind the wood spar. Being an engineer I did both of these measurements and discovered they end up in different locations. 3.56" behind the leading edge is actually a little more than 1.5" behind the spar.
Clearly it's a mistake in the manual, so which CG location is correct?
steve_rc is online now Find More Posts by steve_rc
Old Aug 29, 2015, 09:12 AM
jasonille is offline
Find More Posts by jasonille
jasonille's Avatar
Germany, RP, KL
Joined Aug 2012
Steve_rc, I prefer mine tail heavy makes for better slow 3d but the battery placement would depend on how you are going to fly it. That is why I would say take some Velcro and tack it on and fly move alittle then fly some more to see where you like it most. Once you have found your sweet spot cut your hole and off you go again. I can promise you that you will love this plane!!!
jasonille is offline Find More Posts by jasonille
Old Aug 29, 2015, 03:37 PM
ombudsman is offline
Find More Posts by ombudsman
Oklahoma
Joined Sep 2010
I agree with that except for the last part - cutting the hole. Using Velcro allows you to put the battery farther forward on windy days or aft for calm or indoors.
ombudsman is offline Find More Posts by ombudsman
Old Aug 30, 2015, 07:55 PM
Joined Jul 2014
Well I decided to just go with the 3.56" from the LE and maidened tonight. The CG must be fairly forgiving since I was able to maintain reasonable control. In my shop I had the CG nailed so that the battery was in the middle of the velcro strip.
I am sooooo glad I used conservative throws and expo. +/- 30 degrees with 70%.
I had enough light to fly out 2 batteries flying the circuit at the club field before the sun set. It's definitely a handful for simple cruising around.
Next, 3D lessons from someone in the club!
Old Aug 30, 2015, 09:04 PM
TEAM TWISTED
Joined Dec 2011
+100 Daft
Good luck flying your new MXS-C, Steve!!! Curious what field/club you fly from? I'm in MD too!!!
Discussion Th 32" epp mxs-c cw flydynamics 3D Foamies 2 Apr 25, 2014 10:30 PM
Wanted Twisted Hobbys 32" EPP Crack Laser byoung Aircraft - Electric - Airplanes (FS/W) 2 Mar 04, 2014 12:11 PM
Poll Twisted Hobbys: 32" Crack Yak or Edge 540 enracer 3D Foamies 3 Dec 16, 2013 07:32 PM
Sold Twisted hobbies 32" laser lite with good equipment! Walker986 Aircraft - Electric - Airplanes (FS/W) 0 Dec 14, 2013 06:26 PM
Sold Twisted Hobbies Edge 540 32" EPP (LPU) Rich215 Aircraft - Electric - Airplanes (FS/W) 5 Oct 23, 2013 07:07 AM
