Old Aug 15, 2015, 09:43 AM
dankar04 is online now
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Sounds like a win/ win deal. My Forza is all JR and look foward to your results. My Forza and anoth 450 kit will be Winter projects. right now have three good 450's flying daily. Plus couple smaller c/p's.
dankar04 is online now Find More Posts by dankar04
Old Aug 15, 2015, 11:20 AM
dteel is offline
Find More Posts by dteel
Poor at Object Avoidance
dteel's Avatar
United States, CA, El Cajon
Joined Mar 2014
I'm hoping you don't have any problems with your TAGS unit Dan, that would sure be a bummer. Sounds like it was sort of hard to troubleshoot too.
Flew my Forza this morning, very nice flight. Getting better at setting down very lightly... trying to limit wear and tear on the skids.
Looks like it's going to be another hot day. Glad I got the oil change done on the wife's truck early this morning. It's not going to be pleasant outside later.
dteel is offline Find More Posts by dteel
Old Aug 15, 2015, 11:36 AM
2Doggs is offline
Find More Posts by 2Doggs
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
After I broke my second set of skids, I put on 450 Pro skids. Tho there's less tail clearance, I prefer the look of the heli with them on - and clone 450 Pro skids are dirt cheap from Value Hobby....
2Doggs is offline Find More Posts by 2Doggs
Old Aug 15, 2015, 02:53 PM
Powerdyne is offline
Find More Posts by Powerdyne
KBDD Team Pilot
Powerdyne's Avatar
United States, IN, Muncie
Joined Mar 2013
I've thought about doing the same on the Forza. I have the EX skids, and have already broken one of the Skid pipes. They are very thin, and rather pricy.
Powerdyne is offline Find More Posts by Powerdyne
Latest blog entry: TSA Infusion 600E Pro Build
Old Aug 15, 2015, 03:16 PM
2Doggs is offline
2Doggs's Avatar
Joined Nov 2009
The 450 Pro skids fit well, after you file down the locating tabs, and I've even used some old Leadershobby 450 strut and pipe type skids too.
Old Aug 18, 2015, 06:26 PM
Tatonka is online now
Find More Posts by Tatonka
Buffalos have wings
Tatonka's Avatar
Vancouver Washington
Joined Nov 2007
Did a little custom painting on my canopy, inspired by what you did with yours 2Doggs, my paint was a high coverage type though, so I got a different result.....Visibility is greatly improved, particularly when it is flying toward you.
Tatonka is online now Find More Posts by Tatonka
Old Aug 18, 2015, 11:13 PM
HeliFlyer14 is offline
Find More Posts by HeliFlyer14
United States, OR, Corvallis
Joined May 2014
I guess I will be doing this a piece at a time. I was placing an order from Hobby King, so as long as I was paying postage, I also ordered a YEP 40A esc and programming card.
I already have a yellow kbar, so the last items will be the servos.
HeliFlyer14 is offline Find More Posts by HeliFlyer14
Old Aug 19, 2015, 05:26 AM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
Actually crashed mines yesterday. Did a half piro too low to the ground and lost it in the dirt. Only damage was the main gear, skid, and blades.
ridge_racer is offline Find More Posts by ridge_racer
Old Aug 19, 2015, 08:34 AM
Tucson, Az
Joined Feb 2007
I may sell the Tags Mini as I have AR7200 BX. I bought the kit with Tags as only $20.00 more. I know I can get alot more then $20.00 for it.
I will be testing JR XG6 TX with couple other flight packs. 9ch RX/ w satelites.
Old Aug 19, 2015, 09:51 AM
OrbitalGolem is offline
Find More Posts by OrbitalGolem
Joined Jan 2012
I have almost 100 flights on my Forza with AR7200BX and it flies great. One benefit of the BX is fewer wires. Only two gotchas to watch for:
  • Don't let the stock canopy push down on the AR7200's perpendicular antenna. I was too initially too lazy to cut a notch in the canopy and that antenna eventually broke off. After Horizon repaired it, I learned my lesson.
  • You'll need to mount the AR7200BX a bit forward on the gyro deck to accommodate the ESC throttle cable.
OrbitalGolem is offline Find More Posts by OrbitalGolem
Old Aug 19, 2015, 11:54 AM
ACITceva is offline
Find More Posts by ACITceva
Canada, ON, Toronto
Joined Apr 2013
I'm just curious what you used to cut the canopy for the antenna?
ACITceva is offline Find More Posts by ACITceva
Old Aug 19, 2015, 12:06 PM
Joined Jan 2012
Scissors
Old Aug 19, 2015, 07:16 PM
ACITceva is offline
Canada, ON, Toronto
Joined Apr 2013
[LIST][*]Don't let the stock canopy push down on the AR7200's perpendicular antenna. I was too initially too lazy to cut a notch in the canopy and that antenna eventually broke off. After Horizon repaired it, I learned my lesson.
What actually damaged the antenna? Having the antenna bent or the sharp edge of the canopy rubbing against it?
Old Aug 19, 2015, 07:55 PM
Joined Jan 2012
Both.
Old Aug 19, 2015, 10:20 PM
Tucson, Az
Joined Feb 2007
Scissors
Good answer. Thanks for info on AR7200 BX.
Wanted Forza 1/10 2-speed nitro buggy joeyv2008 Cars - Cars and Parts (FS/W) 0 May 16, 2009 07:29 PM
Sold XBOX 360 Forza 2 Motorsport Game With Prima Official Game Guide JohnM Non R/C Items (FS/W) 2 Aug 22, 2008 09:58 PM
Angstrom Forza Worth Fixing? Steve McBride Life, The Universe, and Politics 0 Apr 23, 2001 07:28 AM
