Old Mar 25, 2015, 07:22 PM
Bhodi11's Avatar
United States, NC, Raleigh
Joined Dec 2013
Originally Posted by maxx4wd View Post
I use this one too...very helpful even for the smaller models with single servo surfaces...but note that you will have issue with any futaba servos that have centers that occur at 1520 vs. 1500 like standard ones....
Could this also be used to stop a servo from buzzing? I have a HS5085 that likes to chatter at center.
Bhodi11 is offline Find More Posts by Bhodi11
Old Mar 25, 2015, 08:34 PM
I can't fly
camoy's Avatar
United States, CO, Parker
Joined Dec 2006
Possible that the dead band is incorrect so yes maybe resetting it or changing it from the current value might help
camoy is offline Find More Posts by camoy
Old Mar 26, 2015, 11:21 AM
maxx4wd's Avatar
United States, CA, Thousand Oaks
Joined Feb 2013
Yes this can help - on my 72 even all the adjustments to the deadband wouldn't fix it - a lot of 3d guys I know use the fuzzy side of some stick on velcro to add a little resistance to the surface at the center - this paired with proper deadband usually does the trick...I know I saw a tutorial on it either here or 3drcforums....but its a great way to fix a very annoying issue
as a side note - once you take off and get that air flowing over the surface it does the same thing so this is really only a ground taxi issue and it really won't hurt the servos much (assuming you set them up properly) - for me I always seem to have 1 or 2 that make some noise - as long as none of them are over amped anywhere in their operating range then it really is just a wee bit of noise...
hope it helps
maxx4wd is offline Find More Posts by maxx4wd
New Product 3D Hobby Shop 47" Edge 540 #BUILD VIDEOS ADDED# ipsmotors 3D Flying 3960 Nov 23, 2013 07:39 PM
Video 3D Hobby Shop 57" Sukhoi sukhoi26mx Electric Plane Talk 7 Sep 17, 2008 08:33 AM
Sold NIB 3D Hobby Shop SHP Extra 300 *Blue* Version 2 thomer Aircraft - Electric - Airplanes (FS/W) 7 May 04, 2008 01:31 PM
Build Log 3D Hobby Shop 55" Katana LIVE Build Log Jeremy Sebens 3D Flying 54 Oct 12, 2007 03:39 PM
