Old Jul 17, 2015, 01:58 PM
RaidersRoll is online now
Find More Posts by RaidersRoll
Joined Jul 2015
Help!
ECS not working! wierd beeping
I bought a new power system for the FT Viggen I am building, and I have some major concerns about the ESC.
Here is the circuit breakdown:
Turnigy 70mm EDF unit with 630w brushless motor.
Hobbyking Orange 8ch Receiver
Turnigy 2200MAH 3s lipo
Hobbyking 60A ESC
Spektrum DX6 Radio
When I connect everything up with my Tx on) the system gets power (the Rx LED is on) and does two beeps, but never does the 3-quick, ascending beeps to signal that everything is working. If I plug a servo into the receiver it functions properly, but the motor does not respond to any stick movements. ESC/Motor is in channel 1.
To make things even more curious, when I go into programming mode (plug-in the battery while the throttle stick is all the way open) I get all the programing tones and beeps listed in the ESC manual, but the motor still will not spin or initialize!
Any suggestions? I know the receiver works, and I know the EDF unit and motor works as well (I tried it with a different ESC a 30A) . I have not been able to get the 60A ESC to work with any components.
What did I do wrong?
RaidersRoll is online now Find More Posts by RaidersRoll
Old Jul 17, 2015, 02:16 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Have you tried to do the, 'set throttle range' ?
eflightray is offline Find More Posts by eflightray
Old Jul 18, 2015, 05:15 PM
Joined Jul 2015
I don think so... how is that done?
Old Jul 18, 2015, 05:26 PM
Diesel6401 is online now
Find More Posts by Diesel6401
Memento Mori
Diesel6401's Avatar
United States, NC, Charlotte
Joined Sep 2009
Def could be throttle endpoints. Also check throttle trim on your radio and make sure the trim is 0.
Normally to set the endpoints the common procedure is to:
1) set throttle to full
2) connect power to esc
3) listen for a beeps
4) after pause in beeps lower throttle, listen to confirmation beeps
* not 100% on all esc's, but the procedure for the majority of them.
Try to find the manual on your esc and find throttle calibration.
If throttle calbration doesn't work, play with the throttle trims.
Diesel6401 is online now Find More Posts by Diesel6401
Old Jul 18, 2015, 05:43 PM
ernie b is offline
Find More Posts by ernie b
3RN13
ernie b's Avatar
United States, IL, West Chicago
Joined Feb 2008
Reduce the throttle trims so the ESC can arm.
ernie b is offline Find More Posts by ernie b
Old Jul 21, 2015, 04:42 PM
Joined Jul 2015
The trims are at neutral, and always have been - any more thoughts?
Old Jul 21, 2015, 04:47 PM
ernie b is offline
3RN13
ernie b's Avatar
Joined Feb 2008
Some ESCs need a throttle trim to be negative before they will arm.
Ernie
Old Jul 21, 2015, 09:20 PM
propwash17 is online now
Find More Posts by propwash17
propwash17's Avatar
United States, NJ, Bergenfield
Joined Jun 2004
Hobbyking 60A ESC
Spektrum DX6 Radio
Hi, all the above info is correct and should get you going, make sure, like stated above, you move the throttle trim all the way down. If that doesn't work, all you can do is try another esc and see if yours is DOA. Please come back and let us know what solves your problem.
Cheers, Ron
propwash17 is online now Find More Posts by propwash17
Old Jul 24, 2015, 10:23 AM
Joined Jul 2015
Fixed! Throttle Trim! But then......
Cheers, Ron
Thanks everybody - problem was solved by lowering the throttle trim all the way down.
My Motor span up properly! Bu then...
My fan exploded. Seriously. at about 60% throttle, there was a pop and the fan blades started shooting out the back of the fuselage.... The fan Hub is intact but all the blades snapped off of it.
EDF unit and motor seem to be in good shape, but the fan is completely destroyed.
Any ideas why this would happen?!?
Old Jul 24, 2015, 12:36 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
FOD (foreign object damage) ? Fan sucked something into it.
Blades rubbing housing, causing one to break, taking out the others.
Poor construction, blade broke off, again taking others with it.
Those and more.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Jul 24, 2015, 01:45 PM
propwash17's Avatar
Joined Jun 2004
Glad you got the ESC sorted out, sorry to hear about your EDF problem. R
Old Jul 24, 2015, 01:53 PM
ernie b is offline
3RN13
ernie b's Avatar
Joined Feb 2008
Good news that the ESC and motor are ok.... sorry about the fan unit.
Ernie
Old Jul 24, 2015, 05:05 PM
ernie b is offline
3RN13
ernie b's Avatar
Joined Feb 2008
I would go with a manufacturer that has a good track record with their product, I hear that E-Flite is pretty good right out of the box with their fan units but I am no expert on EDF fan units.
Ernie
Old Jul 24, 2015, 05:17 PM
Oregon Craig is offline
Find More Posts by Oregon Craig
AMA 636518
Oregon Craig's Avatar
United States, OR, Sandy
Joined Jul 2004
Nope.
Oregon Craig is offline Find More Posts by Oregon Craig
Question eRC 45amp ESC not working... (no beeps) pizatio Power Systems 2 Nov 28, 2013 11:39 AM
Discussion ESC does not emit any beeps anymore, but works. tlh101 Power Systems 1 May 02, 2012 10:12 PM
Help! HELP! Twin TORNADO ESCs beeping and not working! Si Goodchild Electric Ducted Fan Jet Talk 11 Jun 01, 2011 01:30 PM
Discussion Hobbyking SS esc 25-30 beeping and not working moocowfish Power Systems 4 Oct 30, 2010 11:36 PM
Help! Motor Not working, weird beep tone TuanT Power Systems 6 Sep 19, 2009 08:40 PM
