Old Jul 11, 2015, 05:10 AM
DYORD is offline
Find More Posts by DYORD
Philippines, NCR, Quezon City
Joined Apr 2012
Vertical stab - slightly angled to the right.
Hobbyking Sbach 342 1325mm (balsa)
Is there an easy way to correct this? I'm in the process of assembling this then i noticed that the vertical stab is slightly off.
It's more obvious in real life than the picture.
DYORD is offline Find More Posts by DYORD
Old Jul 11, 2015, 08:55 AM
monk87 is offline
Find More Posts by monk87
Joined Jun 2015
Bend it striate and use heat to shrink the covering to keep it where it needs to be?
monk87 is offline Find More Posts by monk87
Old Jul 11, 2015, 09:14 AM
Doc Austin is online now
Find More Posts by Doc Austin
TEAM EXTREME FLIGHT
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
You can't really fix it, so fly it and see what happens. I had a plane like that and it flew fine.
Of course, it might fly awful, but you've got nothing to lose.
Doc Austin is online now Find More Posts by Doc Austin
Old Jul 11, 2015, 09:23 AM
Brashair is offline
Find More Posts by Brashair
3D-Lishus
Brashair's Avatar
North Carolina
Joined Nov 2009
Not nearly enough to notice a difference in flight. You just have to deal with the ulcer every time you look at it.
Brashair is offline Find More Posts by Brashair
Old Jul 11, 2015, 01:08 PM
DYORD is offline
Joined Apr 2012
Thanks for the replies. I'm sure it will fly once it is trimmed. But planning to practice some 3D maneuvers with this plane. Just want to know if this will affect the performance. Or will it be imposible to do 3D moves.
Old Jul 11, 2015, 02:05 PM
Aeroplayin is online now
Find More Posts by Aeroplayin
Not as Good as The Kid
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
LOL... may actually help, and you may come up with a new maneuver because of it. The X-tail Krankensheitshaft.
Aeroplayin is online now Find More Posts by Aeroplayin
Old Jul 11, 2015, 03:19 PM
AeroKen is online now
Find More Posts by AeroKen
3D? I only got two thumbs!
United States, MA
Joined Jul 2012
I had a plane like that. Didn't seem to affect 3D at all. It did have a bit of an effect for more precision stuff, but not too bad.
AeroKen is online now Find More Posts by AeroKen
Old Jul 11, 2015, 05:25 PM
Poffertjesporem is offline
Find More Posts by Poffertjesporem
Thumbs are overrated.
Poffertjesporem's Avatar
The Netherlands, NB, Sint-Michielsgestel
Joined Nov 2014
Had a beer this evening so im not planing to exercise the brain.......
At my school (direction aviation) we had some old planes in the hangar. The High powered single engine prop driven planes all had a slight agle on the verticle vin to assinst in compensating trust angle. Hope yours in the right direction.
Poffertjesporem is offline Find More Posts by Poffertjesporem
Old Jul 11, 2015, 07:02 PM
Aeroplayin's Avatar
South Pasadena, FL
Joined Sep 2009
Interesting... when the P-51 Mustang design files were declassified, it showed a 1 degree offset to the port side of the vertical stab, but the offset was against the fuse median instead of to the 90 degree vertical. Are you sure the offset was vertical and not to the fuse median?
Old Jul 12, 2015, 03:38 AM
DYORD is offline
Joined Apr 2012
Good to hear that! Mine is angled to the right.. not sure if that is the correct direction.
Old Jul 12, 2015, 05:55 AM
Joined Nov 2014
@aeroplayin: im not sure about the exact angles as it has been over 17 years. With the nake eye you could see the offset.
Discussion Problem: right deflection on loops and vertical lines black6088 Sport Planes 5 May 17, 2015 04:04 AM
Discussion Problem: right deflection on loops and vertical lines black6088 Electric Plane Talk 17 May 17, 2015 03:07 AM
Question It's cool to use a slightly damaged lipo right? CyberJay Electric Plane Talk 94 May 12, 2015 02:17 AM
Idea Keep That Vertical Stab Vertical! A Useless Geek Foamies (Scratchbuilt) 3 May 23, 2010 10:55 AM
Discussion Vertical stab not quite vertical...what's the effect? cadders FPV Talk 2 May 03, 2010 03:26 PM
