Old Jun 14, 2014, 01:36 PM
The Fixer
Martin Y's Avatar
Canada, ON, Milton
Joined Jan 2009
Looks good, just dont paint the element black, reflector ok. They can use carbon in the formulas when mixed up and that will greatly reduce range. Clear coat will be a better option on the antenna.
Martin Y is offline Find More Posts by Martin Y
Latest blog entry: Flyfly Fox Glider
Old Jun 14, 2014, 02:08 PM
Just FPV'n
Orange County Ca.
Joined Feb 2009
Thanks Martin..
I'll be sure to give the element a light coat of clear....
Mykro is offline Find More Posts by Mykro
Old Jun 25, 2014, 11:44 PM
yzguy's Avatar
Florida
Joined Mar 2007
Well here is mine
I hope the cable I used is ok, it might be a little small, but at this short length I hope it does not matter much.
also, not sure if something like this has been posted, but this helped me straighten the copper wire first with a drill:
How to straighten 10g copper wire the easy way (0 min 42 sec)
yzguy is offline Find More Posts by yzguy
Old Jun 26, 2014, 07:46 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That looks great to me.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jun 27, 2014, 05:22 PM
yzguy's Avatar
Florida
Joined Mar 2007
-Alex
thanks, I hope to try it out soon
BTW if anyone is wondering, I used 1/4" expanded PVC for the backing and the standoff (probably could have use 1/8 for the backing, but I had 1/4), galvanized plate for the reflector, and a copper tube for the ground connection.
another hint is attach the copper tube to the reflector first using a torch to heat it and melt the solder, also use the torch to tin the other end of the copper tube (obviously without the cable inside), as well as the element connections. Once you have solder on all these, getting them to connect with a soldering iron is much easier than if you did not do this. Also it takes less heat to connect them, and you won't burn up your cable inside that tube connecting the ground.
Old Jul 15, 2014, 10:02 AM
United States, FL, Lady Lake
Joined Oct 2013
IB, is this good for 433mhz ?
Long dist. flight would go in one direction so the dipole spread energy where it's not needed.
I would think beaming it to the direction of flight with at least 60degree cone is quite good.
6.8" section length makes it large but not impossible. If you fly in windy places, perhaps using copper screen (EBay) as reflector would work, wouldn't it ?
Also, I used both Aluminum plates (happened to have it) then later copper plated PCB and found that copper ones got me better pictures (steady and clearer). Has anyone compare them ?
Modglock20 is offline Find More Posts by Modglock20
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 22, 2010 11:52 PM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 03:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 12:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 04:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
