View Poll Results: Poll Closed
cloled 0 0%
closed 0 0%
Voters: 0. You may not vote on this poll
Old Mar 29, 2015, 10:01 PM
gvank is offline
Find More Posts by gvank
United States, NC, Southport
Joined Sep 2013
Originally Posted by gvank View Post
DCRAWFFF,
You have had problems with the Nirvana III (2014 version) that we have encountered with our club.
1. High winds (15 mph plus) will cause the stock sliders to slip. See attached drawings for the fixes we implemented. An alternate fix for the Tube fix is replace the stock o-rings with Danco #31 o-rings (available at Lowes in plumbing dept.) The o-ring fix will work in 20 mph plus winds without slipping.
The dimensions on the sketches are necessary if slippage occurs. They are from the earlier Nirvana series which had fixed dimensions with the exception of the sheets. The boat will sail OK and you can fine tune from them.
2. Line preference is Berkley Gorilla line, 50#. The 35# line diameter is too small and will slip under the roller sheave on the servo arm. The smaller diameter also has a tendency to slip through in the bowsies in high winds.
Note: The Gorilla line is 20 yr old technology. New 50# line is the dia of a hair. New line technology has 150# line at the old 50# dia.
3. Sail servo arm mods: Pre Nirvana III servos had a lot of problems (well documented in this thread). The new servo appears to have over come those faults. However, my replacement servo choice is the Hi Tech 645MG which falls in the Nirvana torque specs. This servo will flex the arm and the mounting deck under load. There are stronger servos available but I suspect deck or arm damage will occur over time.
The stock servo spline has a larger od than the 645. The stock servo arm spline id is larger than the spline adapter on the 645. This id /od tolerance mismatch can cause the stock arm to slip when used on the 645. The quick fix is to epoxy the two pieces together and use the screws to stop separation caused by flex.
I use Scotch tape to keep the lines from becoming tangled with the arm. Simple but effective.
Hope this helps,
gvank
Effective 04-09-2015 at our next club meeting the tube retainers referenced above will be replaced with the following tuning tip sheet.
The referenced O-rings will work as well as or better than the tube retainers. The O-rings are lighter and have less drag.
gvank
gvank is offline Find More Posts by gvank
Old Mar 29, 2015, 10:21 PM
gvank is offline
Joined Sep 2013
Originally Posted by dcrawfff View Post
Gvank - thank you for the rigging info on the 2014 (III) Production Nirvanas ;-)
DLC
DLC,
You are welcome. At our next club meeting, 04-09-2015, I will present the following information regarding the boom slider retainers. After sailing for the past three months in some real bad conditions, I've had no slippage with the o-rings.
Smooth sailing to you,
gvank
Old Mar 30, 2015, 05:27 PM
Capt.Crash is offline
Find More Posts by Capt.Crash
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Dragons are taking over the pond...but the Vulture is giving em hell!
Capt.Crash is offline Find More Posts by Capt.Crash
Old Mar 30, 2015, 06:35 PM
dwatson is online now
Find More Posts by dwatson
Yosef Sailor
dwatson's Avatar
Singapore, Singapore
Joined Jul 2011
Pirate trumps dragon!!!!!
dwatson is online now Find More Posts by dwatson
Old Mar 31, 2015, 09:40 AM
dcrawfff is offline
Find More Posts by dcrawfff
United States, AZ, Maricopa
Joined Jan 2014
Gvank - any chance you could post the Nivana III Boom mods as a PDF (like your other items)?
As I don't know how to convert on my own ;-) . . . and would like to use your drawing as a reference.
DLC
dcrawfff is offline Find More Posts by dcrawfff
Old Apr 02, 2015, 12:06 AM
gvank is offline
Joined Sep 2013
DLC
DLC
This should cover your request. The O-ring change will sail the boat to it's limits without slippage.
gvank
Old Apr 02, 2015, 11:19 PM
dcrawfff is offline
Joined Jan 2014
Gvank - Thank you good sir ;-)
DLC
Old Apr 10, 2015, 09:55 AM
chidago is offline
Find More Posts by chidago
United States, IL, Chicago
Joined Dec 2009
Turbo Encabulator (1 min 48 sec)
chidago is offline Find More Posts by chidago
Reply With Quote  (Disabled)
Old Apr 10, 2015, 03:25 PM
Hircsailor is offline
Find More Posts by Hircsailor
Kimo
United States, HI, Honolulu
Joined Jun 2011
Chidago Its good to see you back, I missed your post as well as your jokes.
Hircsailor is offline Find More Posts by Hircsailor
Old Apr 11, 2015, 07:00 AM
Yosef Sailor
dwatson's Avatar
Joined Jul 2011
Chi,
That sounds very close to what Marvin the Martian wanted to use to blow up the earth!
"Illudium Q-36 Explosive Space Modulator"
Old Apr 13, 2015, 07:10 AM
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Originally Posted by chidago View Post
The F-35's latest upgrade....
Good to see ya back John.
Old May 03, 2015, 05:53 PM
johnnywop is online now
Find More Posts by johnnywop
johnnywop's Avatar
United States, MI, Grosse Pointe
Joined Nov 2011
johnnywop is online now Find More Posts by johnnywop
Discussion Vixen yacht. chidago Sailboats 1 Mar 01, 2013 02:58 PM
