Old Jan 30, 2015, 09:03 AM
Saqueeb is offline
Find More Posts by Saqueeb
Saqueeb's Avatar
United States, MN, South St Paul
Joined Dec 2011
Snipe Servo choices for 1s setup
purchasing a snipe and planning on running a 1s lipo setup.
Looking for servo recommendations for it that are solid on 1s setups.
So far I am leaning towards JR 285's for all 4.
Your recommendations are appreciated.
Saqueeb is offline Find More Posts by Saqueeb
Old Jan 30, 2015, 10:04 AM
Doug Cronkhite is offline
Find More Posts by Doug Cronkhite
2015 USA F3K Team Manager
Doug Cronkhite's Avatar
San Diego
Joined Feb 2002
That will work fine. I'm running 285s on flaperons, and 188s on the tail but 4 x 285 is a solid choice.
Doug Cronkhite is offline Find More Posts by Doug Cronkhite
Old Jan 30, 2015, 10:08 AM
Saqueeb is offline
Saqueeb's Avatar
Joined Dec 2011
thank you!! any advantage to 188's on the tail?
Old Jan 30, 2015, 10:23 AM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Airtronics 94802 for flaperons and JR 285 for the tail. Ive used this combo many times with great success.
davidjensen is offline Find More Posts by davidjensen
Old Jan 30, 2015, 10:53 AM
Indubitably is offline
Find More Posts by Indubitably
Just Fly it
USA, CA, Bakersfield
Joined Jul 2006
Servos
The MKS 65 servos will - if you take the tabs off - will nicely overlap and give you great move forward weight, and shorten the length of the "stack". Also they are very light. And the new Gold labels seem to be good. The Snipe seems to have been made for this servo.
The 188s are faster on 1S but wiggle, and loosen up, especially if you use them on the Flaperons. The pull string / spring helps for a while on the Elev and Rud.
Indubitably is offline Find More Posts by Indubitably
Old Jan 30, 2015, 11:04 AM
Saqueeb is offline
Saqueeb's Avatar
Joined Dec 2011
will the MKS run on 1s, also what glue will hold aluminum to carbon well? ( if i were to go MKS what would you use to glue them down?)
Old Jan 30, 2015, 11:34 AM
Techflyer is offline
Find More Posts by Techflyer
Esprit Model
United States, FL, Palm Bay
Joined Aug 2006
Goop.
I texture the servo case and wipe the carbon with alcohol.
Then Goop the servos into place.
If, for whatever reason, you need to remove a servo you can just peel it up.
The only down side is that you need to wait a few hours for the Goop to cure.
David
Techflyer is offline Find More Posts by Techflyer
Old Jan 30, 2015, 12:00 PM
jfinch is offline
Find More Posts by jfinch
hot air rises...
jfinch's Avatar
Pleasant Grove, UT
Joined Jul 2005
I've built Snipes with the JR DS285/188 combo and they fit and work great. No issues. But with the lighter tails coming out of Ukraine, I built my last one with MKS 65k servos and really like them. They are a bit lighter (which helps with CG) and thinner (which helps with positioning wires). MKS servos are very quick on 1S.
jfinch is offline Find More Posts by jfinch
Old Jan 30, 2015, 01:23 PM
Saqueeb is offline
Saqueeb's Avatar
Joined Dec 2011
I saw that there were some issues with the MKS65k and they were recalled. has that issue been resolved?
what did you use to cut the tabs off? dremel and a wheel?
Old Jan 30, 2015, 01:26 PM
funkz is online now
Find More Posts by funkz
funkz's Avatar
United States, NC, Cornelius
Joined Jul 2012
is quite simple:
mks ds75k
funkz is online now Find More Posts by funkz
Old Jan 30, 2015, 02:13 PM
Kiesling is offline
Find More Posts by Kiesling
San Diego
Joined Aug 2004
I don't have a Snipe, but I am really impressed with the DS75K on one cell. They sell a version without the tabs so you don't have to worry about cutting. They don't nest like the 65k, but they are designed specifically to work on 1S and are significantly faster than the 65k. If I remember correctly, they are less than a gram heavier than the 65k. If you absolutely can't tolerate the extra 4 grams, then the 65K's would be a decent choice. Personally I would choose the speed of the 75k over the lower weight of the 65k.
Tom (MKS sponsored pilot)
PS the 65K issue has been resolved. The new version has a gold label.
Kiesling is offline Find More Posts by Kiesling
Old Jan 30, 2015, 02:34 PM
Saqueeb is offline
Saqueeb's Avatar
Joined Dec 2011
So then the big question is, is it worth basically double the price of the JR servos to go with the MKS??
Old Jan 30, 2015, 03:03 PM
mnowell129 is offline
Find More Posts by mnowell129
Mickey from Orlando. Really.
Joined Nov 2004
All the futabas work fine on 1S, S3156, S3154, and S3114. I have them in my snipe.
mnowell129 is offline Find More Posts by mnowell129
Discussion Struggling with charger purchase choice for 1S LiPos MrSteel Batteries and Chargers 2 Dec 16, 2014 02:32 PM
For Sale (2) new 3A 1s Bl esc with ar6400 servo connector will trade for ar6400 brick nemoskull Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Jul 08, 2014 08:39 PM
Help! esc choice for 6s setup chly3001 Multirotor Power Systems 2 Apr 19, 2014 09:12 AM
Discussion Help with charger choice for multiple 1s batteries. DeGrizzle Batteries and Chargers 3 Jan 12, 2014 02:57 PM
Question 1s BL setup for ar6400? EpicRC Micro Ready-to-Fly 7 Nov 19, 2012 02:49 PM
