Old Jun 21, 2015, 10:57 PM
72dan is offline
Find More Posts by 72dan
72dan's Avatar
United States, CA, Thousand Oaks
Joined Oct 2012
Hotliner throttle ramp and easy launch with Spektrum Radio
Spent a few hours on the Spektrum radio today.
The throttle ramp is in the servo settings, throttle menu. Note I have my throttle on the trainer button. Some call it throttle switch, I like a button, I let go and the motor is off, push the button and feel the speed.
I have been using throttle on a switch for a few years now and always torque roll can be scary at 100% throttle and has made a few flights very very short.
Step 1) Hook up the Castle Creations USB programmer. Set the throttle settings to fixed end points.
Step 2) For full throttle your Spektrum radio has to be -100% at no throttle and +100% for full throttle.
Step 3) Go into the mix menu
Mix mot > mot Yes you are mixing motor with motor
Pick a switch you are going to use at the bottom of the menu
Set offset to -100%
Then set rate to a negative number in percent that will be subtracted
from full throttle
I haven't flown and pulled data logs but bench tested it and it works.
72dan is offline Find More Posts by 72dan
Old Jun 22, 2015, 09:44 AM
Dbox is online now
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Dan.
Thank You much for such a valuable information about radio ramp setting.
I guess basics are same for all radios ....
Yuri
Dbox is online now Find More Posts by Dbox
Old Jul 03, 2015, 06:42 PM
Balsastaub is offline
Find More Posts by Balsastaub
Balsastaub's Avatar
Canada, SK, Regina
Joined Nov 2003
Excite killer...
The touch is even better than the look
The Exite looks pretty low performance beside the Formula
Balsastaub is offline Find More Posts by Balsastaub
Old Jul 03, 2015, 07:23 PM
Dbox is online now
Dbox's Avatar
Joined Jun 2005
I am glad,she got there just in time
Thank You for the picture.
Yuri
Old Jul 03, 2015, 07:26 PM
hubcapsteve is online now
Find More Posts by hubcapsteve
United States, CA, Redondo Beach
Joined Oct 2013
Yours is beautiful, mines dusty
hubcapsteve is online now Find More Posts by hubcapsteve
For Sale New Castle Creations HV-85; ICE2 HV80; ICE2 HV160 - Used HV-85 & HV-110 jgalexander Aircraft - Electric - Power Systems (FS/W) 5 Jul 01, 2013 10:46 PM
For Sale New Castle Creations HV-85; ICE2 HV80; ICE2 HV160 - Used HV-85 & HV-110 jgalexander Aircraft - Electric - Power Systems (FS/W) 1 Jun 20, 2013 03:20 PM
For Sale Hobby Wing HV ESC & HV BEC ravikoth Aircraft - Electric - Power Systems (FS/W) 0 Feb 17, 2013 12:29 PM
Sold JETFAN 90 & HV ESC With HV BEC ravikoth Aircraft - Electric - Jets (FS/W) 4 Feb 13, 2013 03:00 AM
For Sale Spektrum AR8000, MaxAmps 4S 11000, DW crash cage jackwrangham Aircraft - Electric - Multirotor (FS/W) 2 Sep 25, 2012 08:24 AM
