Old Feb 28, 2007, 11:31 AM
Oakridge, Oregon
Joined Jul 2004
Question
max voltage per lipo cell
I wanted to know what is the max and min voltage per cell for lipos?
Am I right to assume 3 to 3.2 v per cell is the minimum?
-ryan
TheDonski is offline Find More Posts by TheDonski
Old Feb 28, 2007, 11:39 AM
Mooresville, NC
Joined Dec 2004
Li-Po voltage.....
The maximum is 4.2 V/cell, and this should be checked at times to make sure the charger remains in calibration. When the voltage reaches this point the charge switches from constant current to constant voltage mode, tapering down the current to a cutoff point (usually around 50 mA).
The minimum voltage of 3.0 V/cell is questionable. Usually you don't want to go even that low if you want your Li-Po's to last. They suggest to only discharge them to around 80% of capacity. The no load per cell voltage would be much higher then 3.0V. I would say around 3.5 to 3.75V no load after a 80% discharge.
Michael
MichaelT1960 is offline Find More Posts by MichaelT1960
Old Feb 28, 2007, 11:40 AM
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Voltage in lipo cells can be broken down like this:
4.20v = 100%
4.03v = 76%
3.86v = 52%
3.83v = 42%
3.79v = 30%
3.70v = 11%
3.6?v = 0%
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Max is 4.2 per cell. Minimum depends on if resting / no load or uinder load and if under load how greater of a load at which stage of the discharge / remaining capacity, temp.. etc.
http://www.rcgroups.com/forums/showp...68&postcount=1
Charles
Old Feb 28, 2007, 02:28 PM
Oakridge, Oregon
Joined Jul 2004
Thanks for the replies. I had always seen different takes on when the minimum was from all the reading I had done. Now, I understand that I need to keep the lipo well above 3.2v and below 4.2v per cell for the longevity of the pack. Lipos for me sometimes seem a bit mysterious at times even after the countless hours of reading about them, but I think I am starting to get it.
Thanks for the help,
Ryan
Old Nov 05, 2008, 05:37 PM
CSRC Service and Support
Scott_Smith's Avatar
Santa Clarita, CA
Joined Sep 2008
Hi, Ryan;
I just read your question and thought you'd be interested to know that our new Proton 4 Digital Balancing Charger has a feature that figures this out for you. While charging, the Proton 4 scrolls through three different data screens, and the first gives you a "fuel" rating that calculates the pack's state of charge as a percentage (like Tram did above).
The Proton gives a lot of other useful info too, like voltages of individual cells and the mAh supplied to the pack during the charging cycle thus far. Check it out and let me know if you have any questions.
Scott Smith
Common Sense RC
Scott_Smith is offline Find More Posts by Scott_Smith
Old Mar 30, 2009, 08:51 AM
Sweden, Skåne, Malmö Municipality
Joined May 2007
4.20v = 100%
4.03v = 76%
3.86v = 52%
3.83v = 42%
3.79v = 30%
3.70v = 11%
3.6?v = 0%
Jeff
I've made an Excel document that should help calculate this percentage.
(Requires Office 2007)
If you don't have Office 2007, you can try it (without the nice graphic) in your browser here: http://sheet.zoho.com/view.do?url=ht...Calculator.xls
gigel_cel_mitite is offline Find More Posts by gigel_cel_mitite
Old Mar 30, 2009, 10:22 AM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Or download the free OpenOffice program which opens all the MS stuff.
hoppy is offline Find More Posts by hoppy
Old Apr 12, 2009, 09:30 PM
Joined Nov 2007
So, if I have a plane that uses a 5 cell NiMH (5 x 1.5 volts = 7.5 volts), can I replace the NiMH pack with a dual cell LiPo @ 2 x 4.2 = 8.4 volts w/o frying anything?
What about a 6 cell NiMH at 6 x 1.5 volts = 9 volts?
Interested in converting a NiMH plane to Lipo, but have never done this before, and am looking for a good starting point...
Thanks!
Flyboy Steve is offline Find More Posts by Flyboy Steve
Old Apr 12, 2009, 10:57 PM
Tram's Avatar
Florence, Al
Joined Oct 2000
You should be able to get away with 2S and 3S packs respectively..
Jeff
Old Jun 11, 2009, 10:06 PM
Joined Oct 2003
Hey guys,
What would happen if one of the cells charged up to 4.3 v? Is it doom for the cell, as dropping below 3v?
Rob
robster94gt is offline Find More Posts by robster94gt
Old Jun 12, 2009, 07:13 AM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
The important question is "Why did it charge up to 4.3V"?
If that was a non-balancing charge it meant that one of the other cells might have been at 4.1V. If that was the case, during discharge, that cell would be well below the others.
Not a doom situation but a charging problem that needs to be fixed.
What were the voltages of the other cells?
Was it a balancing charge?
Did you check all the cell voltages after flying?
Old Jun 24, 2009, 11:02 PM
Chilliwack, BC, Canada
Joined Aug 2003
Here's a slightly different battery question. NiMH pack, 5 cell, 1600 mAh in a full house glider (6 non digital servos working all the time, elevator mixed with flap, ailerons mixed with rudder, crow braking etc) draws up to 1,000 mAh on a watt meter on the ground with no aerodynamic loads. (can't put the watt meter in th fuse and fly it, not enough room!) Several flyers maintain that if I were to use a 2 cell LiPo of 1,000 mAh insted of the NiMH pack, it would last longer.
Logic says a miliamp is a milliamp regardless of it's source, so can anybody tell me who is right?
Which lasts longer- and if you can, why?
Cheers!
ckuklbac is offline Find More Posts by ckuklbac
Old Jun 25, 2009, 08:43 AM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
2 cell lipo = 8.4V x 1.0Ah = 8.4WHr
5 cell NiMH = 6V x 1.6Ah = 9.6WHr
For what that's worth as I've never tried it.
Old Jun 25, 2009, 01:23 PM
Joined Aug 2003
Thanks Hoppy, I was kinda hoping that would be the answer- anything else smacks of 'magical' properties of one type of battery over another.
Next question: Voltage decay over time at constant load. Does anybody have a graph that shows what happens as the battery pack approaches exhaustion?
Just curious.
Cheers!
Question Max voltage for 8 cell Nimh pack? mc-lite Batteries and Chargers 2 Jun 03, 2005 07:03 PM
Question Beginner's question about voltage regulator/2-cell lipo nessuno Scratchbuilt Indoor and Micro Models 5 May 15, 2005 07:25 PM
Lipo Cell Voltage Rise when Discharging hall woo Batteries and Chargers 3 Jan 03, 2005 07:07 AM
APACHE 2500 end of charge Voltage per cell harvey Batteries and Chargers 5 Nov 10, 2004 11:59 AM
Lithium Poly, Safe end voltage per cell?? hopsterguy Batteries and Chargers 4 Aug 10, 2003 08:44 PM
