Old Jul 25, 2014, 11:10 AM
Joined Jul 2014
Question
Charging my battery pack
Hello all, I have a fairly simple question.
Recently I purchased some Hi-Capacity power products D-Type 11000mAH 1.2V Ni-MH Rechargeable Batteries.
I am connecting 10 of them in series to make my own compact 12 volt rechargeable solution. Because getting them in and out will be a slight pain, I want to be able to charge them in place once I finish making the pack.
I dug around and found a nice charger I had for use with sealed lead acid batteries:
12V dual stage charge
Screw terminals
1000 mAh
14.8V fast charge
Its worked great for my SLA batteries and shuts off once the pack is charged.
Do any of you foresee any issues with using this charger or charging in this manor? Or should I take each one out and place in the D cell battery charger that I have?
Thank you very much for the responses!
12VoltNut is offline Find More Posts by 12VoltNut
Old Jul 25, 2014, 11:53 AM
Joined Jul 2014
What I have found online is:
"The cheapest way to charge a nickel metal hydride battery is to charge at C/10 or below (10% of the rated capacity per hour). So a 100 mAH battery would be charged at 10 mA for 15 hours. This method does not require an end-of-charge sensor and ensures a full charge."
So with that being said, a 1000mAH charger should charge the 11000mAH batteries and stay with the C/10 charging range.
The charger I have has a DC voltage output of 14.8V. If I am thinking correctly the D Cell charger I have charges at 1.5 each volts so this would be equivalent to charging each 1.2 volt battery separately, right?
So the big question is charging Ni-MH batteries in series. Is there anything wrong with that?
Old Jul 25, 2014, 12:17 PM
Joined Jul 2014
I found this on eHow:
"If you have a group of NiMH batteries that all need a charge, there is any easy way to do it. Instead of putting each one to charge individually, you can connect them one to another in a series joining with a charger for a complete charging circuit. You can use any charger and number of batteries as long as the combined total voltage of the batteries equals the voltage of the charger."
Has anyone else done this before?
Old Jul 25, 2014, 05:22 PM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
Your numbers are correct. Charge at 1/10 of the rated capacity.
Yes charging in series is correct.
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Jul 25, 2014, 07:19 PM
United States, WA, Woodinville
Joined May 2014
Many lead-acid chargers don't really limit the current though so depending on the charger they may push too much current through the cells. In a pinch a small incandescent bulb or a resistor calculated to limit the current to 0.1C in series with any voltage source at least a few volts higher than the fully charged voltage of the pack will work.
James_S is offline Find More Posts by James_S
Old Jul 25, 2014, 09:46 PM View Post
leveezengxi
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Old Jul 26, 2014, 06:24 AM
homo ludens modellisticus
Ron van Sommeren's Avatar
near Nijmegen, Netherlands
Joined Feb 2001
Don't bother, it's spam, several messages peddling for helthusb. Quote opening post, select 'underwater' screen , end of message: the alturl image link refers to helthusb.
Messages borrowed from the internet, in this case from
www.ehow.com/how_7507187_charge-nimh-batteries-series.html
Indicators:
* very few posts
* out of the blue message trying to look as if part of discussion
Vriendelijke groeten Ron
Ron van Sommeren is online now Find More Posts by Ron van Sommeren
Discussion where do I buy battery pack bits to make my own 6v 7.2v packs? laser173 Sailboats 2 Feb 18, 2014 11:59 AM
Discussion Can I charge my Turnigy 2200 9XR battery with my Accucel6 charger? 335Dude Batteries and Chargers 3 Jan 09, 2014 10:28 AM
Discussion My S107G won't charge after battery replacement ldtheoson Coaxial Helicopters 10 Oct 18, 2013 09:18 AM
Help! Charging my lead acid batteries Liam.great98 Batteries and Chargers 8 Oct 07, 2013 03:09 PM
Charging a car battery while charging my pack? Vertical Batteries and Chargers 18 Aug 01, 2003 10:25 PM
