Old Jun 22, 2008, 05:25 PM
Parkesflyer
RJPIoW's Avatar
United Kingdom, Ryde
Joined May 2006
Build Log
Sopwith Pup - Scale but 3D capable
Ive been having a lot of fun with a scale Sopwith Pup I designed sometime ago. Its 32" span and weighs just under 11oz made from 6mm Depron. Ive installed a UH hacker Style Brushless Outrunner 20-28M which is simailr to an Axi 2208/34 and this provides almost too much power from an 850mah 3 cell and a 9X4.7.
It amuses me to cruise about in the local park at scale speed looking like the original, but then surprising a few folk by opening the throttle to do most tricks in the book. I originally thought it would be very close coupled, but it can be sensibly balanced with the gear as far forward as possible. I will probably move the tail surface servos into the fusalage as they look a bit odd with external CF pushrods.
I flew it last night in 15 knots and it behaved well, and despite having a pair of 4% @ 40% undercambered wings flies inverted with just a touch of down trim.
Aileron response is good and maintaining my Fidgit3D standards the loops are tight. The elevator is a bit bigger than scale and I think scale would probably work fine.
I have CAD plans if anyone is interested, the prototype should really be silver, but i couldnt wait so added the decals and left it depron coloured !
If the wind ever dies down I will get my 10yr old to grab some video.
Richard
RJPIoW is offline Find More Posts by RJPIoW
Old Jun 22, 2008, 05:43 PM
CNC Cutter
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
3d + CAD Plans - sounds hard to beat !
I have Rhino so can do most formats !
Post em up - and ThanX
Bob
birdofplay is offline Find More Posts by birdofplay
Old Jun 22, 2008, 05:51 PM
You deserve my opinion
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
That's a beauty! Great work! Congratulations!
FirstShirt is offline Find More Posts by FirstShirt
Old Jun 22, 2008, 06:11 PM
USA, CA, San Carlos
Joined Nov 2007
How effective is that tiny rudder in a hover?
Lookin' good!
- Jeff
jkarnacki is offline Find More Posts by jkarnacki
Old Jun 22, 2008, 11:09 PM
Parkesflyer
RJPIoW's Avatar
Joined May 2006
Lookin' good!
- Jeff
I cheated a bit on the rudder as well as the elevator, I extended its area as well, in fact I almost think a scale one would work ok. Scale and bigger areas are both shown on the plan. I am just altering my original plan to show the motor mounted slightly differently so that the LiPo can be a little further forward to help the CG then Ill post them.
These were the 2 original photos of teh Pup that inspired me to design this one, I think this plane looks great although I gather that it wasnt one of teh best.
Richard
Old Jun 23, 2008, 12:16 AM
antennahead's Avatar
USA, IL, Lake Forest
Joined May 2007
Yea, post up some plans. I've got a stack of epp, a stack of depron,and a stack of cell foam 88 waiting to be turned into something!!!
antennahead is offline Find More Posts by antennahead
Old Jun 23, 2008, 02:23 AM
Parkesflyer
RJPIoW's Avatar
Joined May 2006
Plans
Hers an initial set of plans. Im most the way through a write up with photos of the build and Ill post this in the next day or two
Thanks for the interest - Im enjoying flying this because its a bit different !
Richard
Edit - here is a draft build guide to help in case the plans are not clear enough
Old Jun 23, 2008, 05:14 AM
Registered HotGlue Addict
chaosMurphy's Avatar
Joined Dec 2006
Been thinking about a bipe
why not one with a 'bit' of history
3D to boot
Thanks for sharing
chaosMurphy is offline Find More Posts by chaosMurphy
Old Jun 23, 2008, 07:26 AM
FirstShirt's Avatar
Collierville, TN
Joined Apr 2005
Thanks, Richard. Plan looks great.
Old Jun 23, 2008, 09:32 AM
Crash & Burn
rmgmag's Avatar
Glastonbury, CT
Joined Nov 2004
That is just great. I've looking for something just like that.
rmgmag is offline Find More Posts by rmgmag
Old Jun 23, 2008, 11:28 AM
Parkesflyer
RJPIoW's Avatar
Joined May 2006
Draft build guide added with the plans
Richard
Old Jun 23, 2008, 11:39 AM
kdahlhaus's Avatar
United States, OH, Westlake
Joined Mar 2002
Richard,
Nice job on the plane and build guide. Thanks for posting it.
kdahlhaus is online now Find More Posts by kdahlhaus
Old Jun 23, 2008, 12:22 PM
Brit in Bahrain
Nigelp's Avatar
Bahrain
Joined Mar 2004
Richard,
Thanks for the plans and the build guide - you have done a fine job ! I love WW1 bipes. The real Pup was supposed to be a real pleasure to fly - it looks as though you have replicated that.
Thanks again,
Nigel
p.s. Love the way you have done the cabine struts - never thought of that !!!!
Nigelp is offline Find More Posts by Nigelp
Old Jun 23, 2008, 02:45 PM
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
This is a nice plane. On of my favorites, though, is the Camel. You did good work on this one.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Jun 23, 2008, 03:54 PM
Parkesflyer
RJPIoW's Avatar
Joined May 2006
More thoughts after further flight testing
Funnily enough I debated Camel or Pup when I started the design. Ive seen loads of Camels but few Pup plans so that swayed my decision. I have a Camel plan started so it could get completed.....
Went out tonight with very little wind - 1st time flying in a gentle breeze. The video battery was dead - typical just when you need someting to work .....
The Pup cruises about rather majestically at very low throttle settings, climbs like a demon with the Axi 2208/34, harriers ok, rolls and flies inverted. It does loops as tight as you dare, and will even do an outside loop. KF requires a bit of power - rudder co-ordination, and even with the rearmost cg I havent managed a blender yet, but Im about to increase elevator and aileron movement ....
I didnt set out to make a top of the range 3D machine but it does ok for a very near scale beast.
Try to keep the weight as far forward as you can.
Richard
Sold 1/3 scale Sopwith Pup plans (Balsa USA) flybd Aircraft - Fuel - Airplanes (FS/W) 3 Oct 29, 2005 05:36 PM
For Sale FS Balsa USA 1/4 scale Sopwith Pup fockewulf37 Aircraft - Fuel - Airplanes (FS/W) 1 Jul 30, 2005 06:03 AM
Sopwith Pup 1/3 Scale Grandstand Aircraft - Fuel - Airplanes (FS/W) 0 Mar 21, 2005 06:48 AM
Sopwith Pup scale ailerons help. Dukester Scale Kit/Scratch Built 13 Apr 02, 2004 07:18 AM
1/8 scale Sopwith Pup wad Scale Kit/Scratch Built 8 Jan 16, 2002 10:38 PM
