Old Feb 23, 2016, 06:37 AM
AmsterdamHolland is offline
Find More Posts by AmsterdamHolland
the Flying Dutchman
AmsterdamHolland's Avatar
Netherlands
Joined Aug 2013
New Product
UPair Chase *** Owners' Thread***
UPair Chase
Will be adding more information.
AmsterdamHolland is offline Find More Posts by AmsterdamHolland
the Flying Dutchman
Netherlands
Joined Aug 2013
The Chase does not come with an external USB port, but there is one on the inside.
So to open it:
  • first remove all 26 screws/bolts
  • disconnect cable from the compass
  • make sure the main board has come loose from the 4 points holding it in place
  • disconnect the gimbal cable
  • guide the antenna through the hole
  • cut the little tie wrap that is holding the compass-cable along with some other wires
  • disconnect the other end of the compas cable from the FC
this cable is ideal for the job, the notch provides it to fit snug
Have a micro USB to USB female cable, I bought one in white as shown above and a USB male to male in white.
I then measured the size where the notch is at (of the USB female side), for reference it is 15x8.5mm.
I then filed a notch into the lower part of the canopy
[i]the USB Cable in place[/img]
the finished result
EMI Tape:
while you have the Chase open, you might want to add some layers of EMI tape to lessen any interference to the GPS module.
Old Feb 23, 2016, 06:38 AM
the Flying Dutchman
Netherlands
Joined Aug 2013
Reserved..
Old Feb 24, 2016, 03:55 AM
tvdrone is offline
Find More Posts by tvdrone
SAR
Joined Aug 2013
Neat
tvdrone is offline Find More Posts by tvdrone
Mini-Review UP air "Chase" (V1) & "One" (V2 & V3) (Under construction) SeByDocKy Multirotor Talk 617 Today 10:13 AM
Discussion UPair-One ***Cheapest 2K/4K Camera Quad*** [442$ for 4K version] Quadbuddy Banggood.com 168 Jul 22, 2016 01:14 PM
Cool UPair Chase is pretty cool GC drone reviews Multirotor Talk 2 Jul 14, 2016 11:16 AM
Discussion Cheaper Than DJI--UP Air UPair-Chase 5.8G FPVRC Quadcopter GeekBuying Geekbuying.com 2 Dec 27, 2015 06:40 AM
New Product UPair Chase Droneguy Multirotor Talk 0 Oct 20, 2015 02:20 AM
