Old Nov 26, 2015, 03:47 PM
Lurch16 is offline
Find More Posts by Lurch16
Joined Jul 2012
Gyrocopter W6625 shaft gear is not engaging motor gear
There appears to be a gap between the lower propellor support and the top of the propeller body support. Because of this , the top gear and shaft are able to slide down which causes the shaft gear to lose contact with the motor gear. This would be the upper gear losing contact with the rear motor. The end result is that the rotor blades won't spin.
Anybody know How did this gap developed and how to fix it?
Lurch16 is offline Find More Posts by Lurch16
Old Nov 29, 2015, 11:05 AM
Lurch16 is offline
Joined Jul 2012
Solved by pressing the shaft down into the plastic piece around the rotor shaft.
Discussion storm racing type A motors not engaging over_run Multirotor Talk 0 May 19, 2015 03:40 AM
Help! 1 of 4 Motors does not engage until 50% Throttle MarylandFly Multirotor Talk 5 Aug 13, 2014 02:43 PM
Discussion Prop shaft gear and pinion engagement Altbob Power Systems 12 Sep 27, 2013 11:39 AM
Help! Double Horse 9101-cog not engaged on shaft and... 5ammy Coaxial Helicopters 1 Nov 30, 2011 10:07 PM
