Old Yesterday, 05:13 PM
Pasco Tri Cities, Washington, United States
Joined Aug 2004
Help!
2.4ghz wiskers
Does anyone know of a source for the little streamlined exits that are used to get 2.4ghz antennas out of a carbon glider fuse? Normally I've seen two used, one for each whisker, so the whiskers are 90 degrees from one another. Not sure I've ever seen one, just photos on this website. I think they are made of nylon or other moldable plastic.
LRFitch is offline Find More Posts by LRFitch
Old Yesterday, 06:48 PM
Mark LSF # 3792
United States, TX, Garland
Joined Nov 2008
Both of my sailplanes that require external whiskers use these. Requires two packages per aircraft. Also, I have found that it's a good idea to add heat shrink tubing on the internal core outside of the fairing. Helps support and protect the active antenna core.
http://www3.towerhobbies.com/cgi-bin...P?I=LXE973&P=8
http://www.horizonhobby.com/products...-guide-SPM6824
Soarmark is offline Find More Posts by Soarmark
For Sale 2.4GHz 9.5dBic 5 Turn RHCP Helical Antenna (2.3-2.4GHz) IBCrazy piscaj FPV Equipment (FS/W) 0 Feb 23, 2014 10:09 PM
Sold Lawmate 1W 2.4Ghz PnP Tx and 2x Lawmate 2.4Ghz Rx Craig9080 FPV Equipment (FS/W) 2 Nov 22, 2013 10:01 AM
Question 2.4Ghz R/C + 2.4Ghz wireless mic, interferance ? Johnny Danger Radios 1 Oct 10, 2013 06:28 AM
Discussion Spektrum 2.4ghz wiskers always curl! Thermal Hobby Radios 12 Dec 24, 2010 11:36 PM
Discussion 2.4 Wisker Grommets Mathelo Sailplane Talk 2 Nov 03, 2010 07:08 PM
