Old Jul 08, 2014, 02:19 PM
Norway, Vestfold, Larvik
Joined May 2012
need to loose wight on my fy680
Just got my 6cell 10000 batt.. and also using a 3 cell lipo for lights gimbal and so on. can i use this to get 12v out of y main 6 cell batt??
http://www.foxtechfpv.com/foxtech-au...-2a-p-200.html
GTI20 is online now Find More Posts by GTI20
Old Jul 08, 2014, 02:37 PM
CG Photo's Avatar
United States, CA, Fresno
Joined Feb 2013
Yes, that should work but make sure you don't go over 2 amps. At 12 volts that is 24 watts you have to work with.
CG Photo is online now Find More Posts by CG Photo
Old Jul 08, 2014, 02:40 PM
A&P Diddy
Midlothian, Tx
Joined Oct 2008
I am wondering about this same thing.... except I need something to handle a constant 6-7a of draw. Am I stuck with running a seperate battery or do you know of anything that will work?
clonedkorl is offline Find More Posts by clonedkorl
Old Jul 08, 2014, 02:54 PM
Joined May 2012
Now im lost.. thaks for answer. using led light gimbal and fpv.. does that go over 2 amp..This is not my stongest side..
Old Jul 08, 2014, 03:19 PM
CG Photo's Avatar
Joined Feb 2013
Ohms law. Volts times Amps equals Watts (V x A=W).
You can use a good quality voltmeter with an amp setting to figure out what the amp load is on each item. Then add up the items to figure out your total load. You may be able to find a wattage used number and from the manufacture and from there be able to figure. If you know the voltage, it is easy to out amps if you have the watts or watts if you have the amps using ohms law.
I learned ohms law in 7th grade radio/electricity class. That was one of the best classes ever!
Discussion Need advice on FY680 Pro build ptaylor999 Multirotor Talk 2 Apr 28, 2014 10:25 PM
Discussion Need advice on FY680 Pro build ptaylor999 Scratchbuilt Multirotors 0 Apr 28, 2014 09:49 AM
Discussion Need some advice on how to teach my daughter GooberRC Beginner Training Area (Aircraft-Electric) 20 Oct 24, 2013 02:10 PM
Discussion Need some help on RTF options for me and my 13 yr old FTLOSM Beginner Training Area (Aircraft-Electric) 19 Oct 23, 2013 06:24 AM
Discussion Need help on my electric setup with Eflite edge profile nateprice 3D Flying 2 Oct 19, 2013 08:24 PM
