Old Aug 12, 2015, 08:27 PM
RoGuE_StreaK is online now
Find More Posts by RoGuE_StreaK
Caution: Noob in training
Australia, QLD, Redbank Plains
Joined Jun 2007
Aileron as pseudo rudder?
I posed this question in the Durafly Vampire thread but didn't get any answers as to whether it would work or not
The Durafly Vampire doesn't have a rudder (or rudders, as it's twin boom), but reading one user's description of using asymmetrical aileron throws to help with this got me wondering whether moving a single aileron would act as a pseudo-rudder as it were?
ie., instead of moving the ailerons in opposite directions for a bank, will moving only one aileron result in a rudder-ish behaviour, or will it just be a badly performed bank?
My TX is capable of all sorts of weird and wonderful mixing, so I can "easily" have both normal aileron operation and a possible pseudo-rudder mixed in.
RoryG's original post that sparked the thought, note the differential in the up and down values, and I've bolded his main comment
Originally Posted by RoryG View Post
I've got some info on my blog page here, but the throws I use are:
  • Ailerons: low rate 7mm up / 4mm down; high rate 10mm up / 6mm down
  • Elevator: 10mm up / down
  • Spoilerons: ailerons 10mm up; elevator 4mm down
I tend to fly in low rate most of the time, the ailerons are *very* responsive and don't need much travel. I find the differential really helps as the bird has no rudder.
Hope this helps,
Rory
Here's my original query based on the above:
I'll have plenty of questions, but one that presented itself after reading RoryG's post/blog, is whether mixing rudder into the ailerons would work as a pseudo-rudder? I always fly with rudder (started with 6ch helis, so it's second nature), and I think I'll feel a bit lost without one!
My vague idea is this, based on RoryG's asymetrical aileron throws; if for example I set the ailerons to +/- 4mm, and then mixed rudder to ONLY give an increase in the positive of up to an extra 3mm, would this give a pseudo-rudder in that one side drags more rather than increases roll, sort of a skid-steer?
eg.
full right aileron, no rudder
=> left: -4mm, right: +4mm
full right aileron, full right rudder
=> left: -4mm, right: +7mm
full right aileron, full left rudder
=> left: -1mm, right: +4mm
Is that clear as mud?
RoGuE_StreaK is online now Find More Posts by RoGuE_StreaK
Old Aug 12, 2015, 11:03 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Spoilerons is an option. A number of aircraft use spoilers for combined roll and yaw from one control. Many airliners use small spoiler movements for small corrective inputs because it provides drag for some yaw at the same time.
A few aircraft have no actual ailerons. Just spoilers on the outer wings that are used differentialy for roll control. So it's certainly possible.
Will aileron surfaces work for this? Yes and no. They are not actually spoilers that rise from the wing so they don't work quite the same.
And they don't give you yaw with no roll. You're going to get roll with either ailerons used as spoilerons or from true spoilers used for roll/yaw combined control.
So are they a replacement for rudders? Nope.
As for your mixed up rudder and ailerons issue? It's not going to work at all like you think. It'll just act like some differential aileron. Even if you set the ailerons up with 110% throw in one direction and 0% in the other so you have 110% full on differential it's still going to produce a combined roll with yaw. And roll will be the primary reaction.
You simply can't replace the rudders with single surface ailerons.
Now if you do like the B-2 and use split drag rudders then you CAN produce a pure yaw with no roll. But it's a draggy way to do so compared to installing proper rudders.
BMatthews is offline Find More Posts by BMatthews
Old Aug 12, 2015, 11:53 PM
Joined Jun 2007
Hmmm, I not so much expected it to replace rudders, I think I expected that there would be a roll element involved, I guess I'm asking whether it would be a workable way of introducing some controllable yaw without extra hardware mods?
Would almost exclusively be for banking turns, just wanting a semi-controllable way of bringing the tail inline, or inversely skidding the tail in the opposite direction... you know, do a little dance, make a little love, and just generally get down tonight I wouldn't expect to be doing flat yawing.
So if you allow for added roll, would you expect a smidgen of yaw control to be introduced, or is it a useless/dangerous occupation?
RE: spoilerons, I'm looking at those for landing (if we are talking the same spoileron, ie. upwards flaperons), as the vamp is apparently a very glidey bird, sometimes a little too much so for landings.
Hoping to maiden this weekend, so I might start with standard settings and perhaps set some switches up to try bringing in different mixes once she's (hopefully) proven to be flying right.
Old Aug 13, 2015, 09:21 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
A rudder controls yaw, ailerons control roll.
Some of the flying wing guys are using drag rudders for yaw control.
Basically like a split horizontally aileron opening up and down at the same time.
eflightray is offline Find More Posts by eflightray
Old Aug 13, 2015, 11:11 AM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Rogue: what you are (correctly) labeling as asymmetrical aileron movements is more commonly called Aileron differential. It is when the aileron going up travels farther than the aileron going down. Generally a set amount is put into the plane mechanically (by changing the angle of the control wires in plan view, particularly effective with a single aileron servo) or by programming the differential into the radio. Your idea to tie a variable amount of differential to the rudder stick is an interesting variation of the theme. I suspect it would take getting used to, but I could see how it might work in aiding turns. I have a 42" Blubaby (high wing monoplane) that had a problem with adverse yaw when I flew with a KFM3 aileron wing. It would roll, but not turn well with just aileron/elevator unless I added a lot of rudder (like full travel). I got on RCG and asked about it, got the tip to add differential and changed the location of aileron servo to make a 90 degree angle between the two control wires in Plan View. That solved the problem, she now dips the inside wing quite nicely and rolls into the turn. Interestingly she also rolls quite axially as well.
The way it works as you probably have already learned, is that the greater movement of inside aileron drops the inside wing in a turn, thereby aiding the turn. On a high wing plane it really helps, on a mid wing or low wing, it isn't as effective, but they don't generally need it as much either.
Here's a video showing how she flys with that wing and differential: http://www.rcgroups.com/forums/showp...03&postcount=1
springer is offline Find More Posts by springer
Old Aug 13, 2015, 01:13 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
From your #3 post I'd say you're looking at it the right way. What you described is going to be pretty close to what will happen.
I did a rudderless glider with lots of differential and a buddy wanted to fly his electric scale SPAD XIII at very slow speeds near the stall which he considered as more scale like.
His issue was that using the ailerons only produced a lot of adverse yaw. At one point he set up the throws for extreme differential so that he only had upward travel and no downward travel other than a slight wiggle. But due to how slow he was flying he STILL had some adverse yaw unless he used some coordinated rudder with it. Once he finally gave up and allowed the model to fly a few mph over the near stall speed this all changed. Now the high degree of differential acted just like you're expecting and hoping to get. So as long as you don't try to slow it down to nearly the stall speed I think you'll be just fine and happy with the results.
The one time I used a pretty fair degree of differential on an aileron and elevator controlled glider I got just what you describe in post #3. So between my buddy's and my own experiences I'm pretty confident in saying you'll get what you described.
Now if you went with "proper" spoilerons" such as used on the P61 Black Widow and the later Mitsubishi MU-2 I think you'd find that you get more of what you're after with less of the bad side of things. But that means a rather dramatic commitment during the construction phase to install proper spoilers out near the wing tips.
Google up the MU-2 for a better description and reports on how they flew. The MU-2 is a little more unique than the P61 in having NO AILERONS at all. The P61 had vestigal ailerons so it wasn't the full meal deal.
I used to know a fellow modeller that spent some cockpit time as pilot in charge of an MU-2. When I asked about how it handled (I was fascinated with the idea of spoilers for roll control back then) he reported that it handled just like any other plane other than needing litte or no rudder coordination. He was able to just about fly it with no feet on the rudder pedals.
Oh, and then there's the Ercoupe. It uses conventional ailerons with a massive amount of differential and NO RUDDERS AT ALL. So reading about how those fly is another avenue to explore.
Old Aug 13, 2015, 05:23 PM
Joined Jun 2007
Thanks guys, yeah I guess you could term it variable differential, or dynamic differential, or something like that
I might try it with a few different mixer setups, built-in differential vs variable, and see if it's usable or not in this case.
The full-scale Vampire does have rudders, and some have added them to the Durafly, but if I can get a bit of yaw control without having to resort to major mods then that should make me happy
Old Aug 14, 2015, 08:37 AM
Top_Gunn is offline
Find More Posts by Top_Gunn
Joined May 2010
"Oh, and then there's the Ercoupe. It uses conventional ailerons with a massive amount of differential and NO RUDDERS AT ALL."
Ercoupes have rudders, which are coupled to the ailerons, so most of them have no rudder control (a few of the later ones do have rudder pedals). They have a complicated system which moves each of the two rudders a different amount.
Top_Gunn is offline Find More Posts by Top_Gunn
Old Aug 14, 2015, 09:23 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Oops, my bad. I recalled a flying buddy that also flew a full size Ercoupe talking about the no rudder pedals and I guess I jumped to the wrong assumption while finishing off my post.
Old Aug 14, 2015, 02:47 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
A 'differential' aileron would need to cause drag, but not much roll, if you intend using it as a yaw control.
Doesn't the down going aileron cause more adverse yaw ?, that's why we dial in differential aileron, 'more up than down', to reduce yaw.
Isn't there a danger that to get the yaw, it could seriously hamper the roll control, or even aileron roll causing excessive yaw if you tamper with the existing ailerons ?
Wouldn't just adding a micro servo operating one rudder be simpler and give better reliability.
Old Aug 14, 2015, 05:47 PM
Brandano is offline
Find More Posts by Brandano
A way to further enhance aileron differential would be to use Frise ailerons. These are hinged on the top surface, an little back from the aileron leading edge. When deflected downwards the aileron leading edge moves into a recess in the wing, but when deflected upwards the leading edge drops down in the high pressure airstream on the wing bottom surface, effectively acting like an airbrake and providing additional drag.
Brandano is offline Find More Posts by Brandano
Old Aug 15, 2015, 02:52 AM
gerryndennis is online now
Find More Posts by gerryndennis
gerryndennis's Avatar
New Zealand, Canterbury, Christchurch
Joined Jun 2008
Hi Brandano,
I don't mean to sound pedantic but the ailerons you describe aren't actually Frise Ailerons. It's a fairly common misconception in the model aeroplane world and even full size.
Frise ailerons are bottom hinged behind the trailing edge, the up going aileron LE protrudes into the airstream a bit but that's designed to work as a balance horn reducing the effort required to deflect the ailerons more than to help with adverse yaw.
The down going aileron forms a slot allowing high pressure air from the wing undersurface to flow over the top of the aileron. This allows the aileron to produce more lift with less deflection and therefore drag, and makes it less likely to stall. You can get away with the sin of picking up a wing with aileron at the stall with Frise ailerons.
Interestingly enough Frise ailerons on their own don't do much for adverse yaw, experiments with having the LE protrude further into the air flow just caused excessive drag and flutter.
Frise ailerons with a bit of differential are quite good in this respect though.
The ailerons you describe work in a similar manner but without all the advantages and finesse of the Frise ones. I bet they are cheaper and lighter to build though which is why they are superior in some situations, at least that seems to be what Cessna and Piper have decided. Could be patent issues too maybe.
Dave H
gerryndennis is online now Find More Posts by gerryndennis
Old Aug 15, 2015, 03:21 AM
Joined Jun 2008
Roque Streak,
If I read your question correctly you are asking if ailerons can be rigged or manipulated so that they produce yaw. Ailerons produce roll not yaw (other than a small amount of yaw in the other direction to what you are looking for), no amount of playing around with deflection will alter that.
The simple answer already given here is no, unless you go to split drag ailerons or spoilers as mentioned here. The only yaw ailerons generally produce is in the wrong (adverse) direction hence the conversations here about how to reduce the yaw (and therefore reduce the requirement for rudder).
I'm wondering why you need it though? There's plenty of aileron/elevator models out there flying perfectly well. Even the models with rudders don't get used much in turns. I reckon 90% of model pilots only use the rudder for steering on the ground, in knife edge, or stall turns (hammerhead). They'll go to great lengths to avoid using rudder in turns by adding aileron differential etc. instead. (I'm not saying that's a bad thing, in pattern models it's essential).
Other than a few exceptions (gliders with long wings, WW1 types, flying close to the stall etc) there's really not much requirement for rudder. A little dab with the aileron to reduce adverse yaw as the model rolls into the turn then zero rudder throughout the turn when aileron is zero, then a wee dab with aileron on levelling the wings is about it. With most models you won't even notice it if you don't bother. The fin causes the model to align itself with the airflow automatically. That's yaw stability.
Is your model doing something wrong? If so I would suggest that enlarging the existing fin and (fixed) rudder slightly would be a more profitable direction to head. Or you could add a rudder linkage and rudder servo.
Best of luck any way, let me know if this doesn't make sense.
Dave H
Old Aug 15, 2015, 06:56 AM
xlcrlee is offline
Find More Posts by xlcrlee
Joined Apr 2006
I totally agree with the above 2 posts. As confirmation, when the B-2 was first publicly revealed, my neighbor in Seattle did not believe it could fly. So I took the top-view photo from the newspaper and made a small paper model, using cambered and complexly twisted wings. It flew very well and I even flew it at Boeing for my engineer friends there. So when WhiteWings AG [with whom I'd worked before, providing them with some other diecut coverstock glider designs] asked me for a B-2 I told them I could give them one.
However, since no normal person could be expected to accurately reproduce the complex curves of my original P.OP. model on a flat coverstock plane, I basically used what the fullsize B-2 does. That is, the ailerons on the B-2 are well inboard of the tips, the outer control surfaces are rudders! Ailerons on the tips would adversely twist the wing tips but the drag-rudders are symmetrical and do not, apparently open all the time except for stealth mode in my understanding.
With this semi-official knowledge acquired from an expert in the program I used the drag rudders on my diecut toy coverstock design as:
1. yaw stabilizers by keeping them split and open, with the lower surface flat with the wing [which is stiffer than the fullsize B-2]
2. horizontal stabs [fixed elevators], with the locking tab for the folded-over "ruddervator" significantly protruding below the wing to both increase the drag-rudder effect while reducing the asymmetrical elevator effect.
This simple "ruddervator" design allowed fixed drag, elevator and aileron effects without the necessity of users finding and KEEPING the surfaces exactly bent.
The final item [which I produced and sold to WhiteWings] flew well, but of course not so well as my original cambered & twisted-wing design, with maybe 80% of its L/D [stable glide from shoulder height launch of 40ft, vs 50+ft. for the original]
xlcrlee is offline Find More Posts by xlcrlee
Old Aug 15, 2015, 08:28 AM
springer is offline
treefinder
springer's Avatar
SE MI
Based on the above, your second post, i think your plan to program variable aileron differential will do what you want. My experience with adding differential on low & mid wingers is that it aids in turning by both increasing roll (dropping the inside wing faster than without differential) and yawing the plane slightly into the turn roughly similar to adding a bit of rudder. What it won't do is reverse rudder, as the yaw function is directionally coupled with the roll function. I think your idea is cool, and will try it myself. I've built several wings and a couple tailless biplanes flying with elevons. I programmed 10% differential (if i recall correctly) to a switch, and can tell the difference in turning ease/smoothness, but being able to dynamically add or reduce it via rudder will be interesting!
Discussion Setting up Ail Differential and Aileron > Rudder Mix. duworm Multi Task F3X 29 Aug 18, 2015 09:39 AM
Discussion rudder-aileron link Teddy Ong Electric Plane Talk 23 Aug 17, 2015 10:26 AM
Question Flaps working as ailerons... Sergio Lopes Radios 4 Aug 04, 2015 01:19 PM
Mini-HowTo CPO Quick Tip :: Airplane Control Surfaces (Elevator, Rudder, Ailerons, Flaps) cpo Beginner Training Area (Aircraft-Electric) 2 Dec 09, 2013 10:06 AM
Discussion What expo settings do you use in your aileron,elevator and rudder? Pakingzzz Electric Heli Talk 32 Nov 18, 2013 12:24 PM
