Old Apr 15, 2016, 07:20 PM
BigShooter is offline
Find More Posts by BigShooter
Joined Mar 2016
Lipos in parallel capacity
Do all the batteries run in parallel have to be the same capacity? Can I run a 1300 with a 2200?
BigShooter is offline Find More Posts by BigShooter
Old Apr 15, 2016, 07:31 PM
Redtail2426 is offline
Find More Posts by Redtail2426
United States, NY, Rochester
Joined Oct 2015
As long as they are the same cell count like 3s or 4s, then the capacity does not matter,
So don't mix cell counts on the same board,
And just add all the capacities together to get your charge rate.
Example
If you wanted to charge a 1000mah with a 1300 and a 1800 and let's say a 4000, then you would charge at 8.1 amps for a 1c charge rate.
Redtail2426 is offline Find More Posts by Redtail2426
Old Apr 15, 2016, 08:38 PM
Joined Mar 2016
Example
Thanks for the info!
Old Apr 15, 2016, 08:41 PM
ggcrandall1 is online now
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
May I suggest you read this: http://www.tjinguytech.com/charging-how-tos
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Apr 15, 2016, 08:51 PM
GodsLt is offline
Find More Posts by GodsLt
Newbie
Canada, BC, Vancouver
Joined Jul 2015
I echo Glen's suggestion to read the website above. It's a perfect place to start!
That said, I routinely charge 2200mah (300x) and 460mah (180 CFX) all in parallel, up to a combination of 15 batteries at a time with no ill effects. The same will hold true for discharging.
On a side note, when wiring cells in SERIES (not PARALLEL) your voltage changes, which means you can wire a 3S and a 4S in series provided they are both the SAME capacity.
It's all very interesting stuff, I suggest you give it a read!
GodsLt is offline Find More Posts by GodsLt
Discussion large capacity connectors for batteries in series and parallel mistairjoe Batteries and Chargers 11 May 26, 2015 07:24 AM
Question Question about large capacity lipos/charging batteries in parallel Rampage Batteries and Chargers 4 Jan 17, 2015 05:16 AM
Help! Different Capacity LiPos in Parallel acetech09 Batteries and Chargers 5 Apr 22, 2012 10:39 PM
Discussion 2 different lipo capacity in parallel alobe Batteries and Chargers 17 Aug 06, 2007 11:19 AM
Discussion LiPo Packs of Different Capacity in Parallel green66 Batteries and Chargers 3 Dec 24, 2005 02:57 AM
