Old Jan 12, 2016, 02:06 PM
grfcon is offline
Find More Posts by grfcon
chronic in training
grfcon's Avatar
L.A. beautiful san fernando valley
Joined Nov 2008
Help!
why certain plank ocillate/flutter at speed while DSing?
Only certain designs do this.. lumberjack/ drongo (older Bluto clone) I think the Skua's do as well.
I am not talking about control surface flutter.
I am referring to the whole plank fluttering at high loads/speed.
Leading edge to trailing edge oscillation.
Anybody know why? thanks
grfcon is offline Find More Posts by grfcon
Old Jan 12, 2016, 04:20 PM
sll914 is offline
Find More Posts by sll914
sll914's Avatar
Joined Oct 2003
I think you'd call it freedom body flutter and its just due to a lack of sufficient bending and torsional stiffness.
sll914 is offline Find More Posts by sll914
Old Jan 12, 2016, 06:18 PM
ALEX HEWSON is offline
Find More Posts by ALEX HEWSON
Remember... Fly for fun!
ALEX HEWSON's Avatar
Christchurch, New Zealand
Joined Jul 2005
What Spencer said. It's what happens when the structure isn't strong enough through the Centre
ALEX HEWSON is offline Find More Posts by ALEX HEWSON
Old Jan 13, 2016, 07:36 AM
1000MPH is offline
Find More Posts by 1000MPH
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
There used to be a cool slo-mo video of the infamous Zagi flap.
Edit: found it. NOT one of mine
ZagiFlutter (1 min 50 sec)
1000MPH is offline Find More Posts by 1000MPH
Old Jan 13, 2016, 07:46 AM
Aerogance is offline
Find More Posts by Aerogance
U down with EPP? Ya u know me!
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
Swept platforms exacerbate the issue. A "plank" with a tapered wing and straight trailing edge is technically swept, so look at the planforms of the planes in question and reinforce as required. To heck with the foamy cop, if she doesn't like my carbon reinforcements she can discuss it face to face
Aerogance is offline Find More Posts by Aerogance
Old Jan 13, 2016, 11:04 AM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Edit: found it. NOT one of minehttps://m.youtube.com/watch?v=Rbj90zHECz8
When looking at videos of flutter the actual speed of the flutter is often masked by the strobe effect caused by the frame rate of the camera. The excursion looks enormous so I wonder just how fast it actually was. I guess live audio might offer a clue.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Jan 13, 2016, 11:20 AM
screamin' eagle is online now
Find More Posts by screamin' eagle
R/C Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
The two times my Lumberjack folded, it survived exactly one oscillation before snapping the spars. Unfortunately the first video started rolling a nanosecond after the fold.
Implosion (0 min 9 sec)
Lumberjack death (0 min 40 sec)
screamin' eagle is online now Find More Posts by screamin' eagle
Old Jan 13, 2016, 11:30 AM
dsman is offline
Find More Posts by dsman
More like crunchman....
dsman's Avatar
United Kingdom, Cheshire East
Joined Mar 2007
I've had a few flappers.
Most notably Half-Pipe 60 & M60, both at about 154 mph, turning into sinusoidal jelly.
Though amazingly neither showed any visible sign of their high amplitude strains following landing & each continued to give service, albeit without ever again being allowed to reach those speeds.
The M60 was sufficiently built for DS but not with fast DS in contemplation.
The HP60 had been built for 60" racing & didn't even have a reinforced tape covering, just iron-on over foam. Tracked beautifully though on so many occasions before being pushed one day to its limit.
Reckon one built specifically for fast DS would get very close to 200.
dsman is offline Find More Posts by dsman
Old Jan 13, 2016, 01:57 PM
Bazzie is online now
Find More Posts by Bazzie
New Zealand, Wellington, Paraparaumu
Joined May 2007
With swept wings more often than not you need to add a spar as far back as possible, fairly beefy. Usually you can only get in about a 1/3 to half span before you reach the main spar. The first time I saw it was on an own design, in a dive, and not sufficiently strengthened over the middle near the TE. I probably still have a pic somewhere, it was before digital photography days. I taped a stick I picked up on the hill, to the wing over that area to continue flying for the day
Bazzie is online now Find More Posts by Bazzie
Old Jan 13, 2016, 03:02 PM
deputybuzz is offline
Find More Posts by deputybuzz
Pledged to Always Chase Wind
deputybuzz's Avatar
USA, UT, Salt Lake City
Ditto on my M60(Raven) which has extra carbon tow added to beef up the spar, heavy tape job and glassed elevons. Flies like a dream but right about 160+ it turns into a violently flapping noodle.
deputybuzz is offline Find More Posts by deputybuzz
Old Jan 13, 2016, 10:27 PM
Joined Jul 2005
Models I have seen and flown that were most prone to it are the M60 and Reaper 60. Both seemed to be around the 160 mark.
Speaking of which, just noticed my old M60 speed from about 2006 isn't anywhere to be found, but damn if I remember what it was. Early 150 I think
Old Jan 14, 2016, 04:32 AM
Peter Wick is offline
Find More Posts by Peter Wick
Kopenhagen
Joined Apr 2005
Dear all
nice video!!
flutter of a swept wing and a plank are differet.
There is a flutter study of the SB13 sailplane (because the model of the eat sailplane fluttered badly already at slow speeds).
When the wing is swept, then there is a coupling between when the wing is bending and the twist in the wing. That is not the case for a plank! If you look at the video, you can actually see, that the pilot can start the fluttermotion by pulling elevator (bending the wing!)...and this induces twist into the wing. Twist on a swept wing is always the same as pulling or pushing elevator...and if this to Things act constructivly together :-) they destroy the plane.
In the study the main results are:
This coupling is worst for wingsweep around 15 degrees (SB13 and our own experiences with F3B flying wings ), so fx wing sweep of 30 degrees is in terms of flutter much better.
The main countermeasure is to make the wing as stiff as possible - no bending.
Secondly place the main wing spar at the root further back than at the tip (chordwise).....but if you go too much back you will loose at lot of stiffness as the thickness of the airfoil is less at the trailing edge.
Peter Wick is offline Find More Posts by Peter Wick
Old Jan 14, 2016, 06:32 AM
Aerogance's Avatar
Joined Sep 2008
The Sonic spar is exactly as you describe Peter. Pat Bowman had incredible insight with his foam designs.
Old Jan 14, 2016, 08:05 AM
Kopenhagen
Joined Apr 2005
yes!
Old Jan 14, 2016, 09:52 AM
dsman is offline
dsman's Avatar
Joined Mar 2007
[QUOTE=Peter Wick;33719061
Secondly place the main wing spar at the root further back than at the tip (chordwise).....but if you go too much back you will loose at lot of stiffness as the thickness of the airfoil is less at the trailing edge.[/QUOTE]
Useful tip, thanks Peter.
No doubt particularly so if applied to an HP60, given it does rather well even with a solitary spar installed in contrary fashion.
Help! Why am I losing aileron control at high speed?.... fluxcapacitor121 High Performance 14 Jul 13, 2015 11:48 PM
Video M60 plank sloping at 2X speed Steve 0 Slope 8 Feb 26, 2014 07:37 AM
Question Why does a wing stalls at a decent speed? jwellsy Beginner Training Area (Fuel) 91 Nov 02, 2013 04:42 PM
Discussion Highest Recorded Wind Speed while DSing/Sloping? LVSloper Dynamic Soaring 23 Mar 11, 2010 09:00 PM
Discussion How to: elimate elevon flutter at high speeds S76 Mech Flying Wings 17 Jan 22, 2007 09:29 AM
