Old May 26, 2015, 09:07 AM
1938Nebie is offline
Find More Posts by 1938Nebie
United Kingdom, England, Rustington
Joined Nov 2013
Acrowot Mk2 Foam-e Aileron servo's
Help please
Does anyone Know how to change an aileron servo. They are buried in the wing. The wing top has no access -it's covered by the foam wing surface. Under the wing there is a square plastic plate which is probably the way to get at the servo. In the centre of this plate is the servo output arm. I can't move the plastic plate without destroying the lower wing foam surface - its really well glued in the foam this plate probably carries the servo mounting.
Anybody managed to change a foam acrowot aileron servo ?
1938Nebie is offline Find More Posts by 1938Nebie
New Product (Acro Wot Mk2 Foam-E) The 80's British cassic is reborn in FOAM! richos Foamies (Kits) 7 Apr 19, 2015 12:30 PM
Discussion Acro Wot Foam E Mk2... A Failed Masterpiece Richard Haynes Electric Plane Talk 5 Apr 19, 2015 01:48 AM
Discussion acro wot mk2 e-foam vilelas F3A Pattern 3 Nov 20, 2014 02:17 PM
Rant Acrowot mk2 Artf elevator pushrod Pedmondsonni The Builders Workshop 0 May 22, 2014 06:41 AM
Discussion Wot 4 mk2 foam - e aileron servo replacement help. Shep0479 Foamies (Kits) 1 Aug 25, 2013 11:57 AM
