Old Jan 26, 2015, 01:48 AM
Wats the worst that can happen
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
I designed and printed two motor mounts for the Rarebear motors I just received from HK.
It's abit heavy, but should fly.
I'm looking for a 6x5e prop, and 6x5e reverse prop. Haven't been able to locate yet unfortuately.
The design is found here in case it interests anyone:
http://www.thingiverse.com/thing:652701
TheCure is offline Find More Posts by TheCure
Old Jan 26, 2015, 03:19 AM
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
http://www.hobbyking.com/hobbyking/s...propeller.html
The 5.5 x 5.5 speed props ( http://www.hobbyking.com/hobbyking/s...ller_2pc_.html ) made my Tu144 go like stink !! Didn't bother with counter rotate - no problem - but PKJ may be due to its smaller lighter size.
But as you say - hard to find counter props ..plenty in the usual 4x4, 5x5 etc.
Wishing you luck - those Funfighter motors are strong .. bit heavy but good ..
You are making me look at fighting my 'twin beast' again. But that's 2 x 3200kv 's ...
Cheers
Nigel
solentlife is online now Find More Posts by solentlife
Old Jan 26, 2015, 04:57 AM
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
APC do a 7x5 in normal and pusher. Perhaps you could trim and balance them
http://www.apcprop.com/ProductDetail...Code=LP07050EP or you could try carbon quad props provided they can take the rpm
Andy
headlessagain is online now Find More Posts by headlessagain
Old Jan 26, 2015, 05:24 AM
Dukejet's Avatar
Australia, QLD, Biloela
Joined Aug 2012
That's a great mount TheCure!! Did you laser print those?
Dukejet is online now Find More Posts by Dukejet
Old Jan 26, 2015, 05:55 PM
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Awww shucks. Thanks for the good words.
It is engineered so it just slides on the back and is friction-fitted to the foam nicely when installed. Of course abit of glue will help too :-)
Yes, I printed with my 3D printer at 30% infill with ABS. Probably could go less and lighted it up abit.
Old Jan 26, 2015, 06:00 PM
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
... !! Didn't bother with counter rotate - no problem - but PKJ may be due to its smaller lighter size.
I have another PJII which runs a 4200kv EDF motor and a 4.5 prop and it doesnt launch at all. just rolls itself into the dirt.
i also have another PJII (mentioned above) with twin stock counter-rotating motors that is probably the easiest plane I've launched in my life.
So, I will stick with the counter-rotating plan.
The idea about filing down props isnt my favourite, but is a certainly a good plan if I can't find any.
Old Jan 26, 2015, 06:12 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
To cut down the prop just use a cheap compass. Find a dowel that's a good fit for the prop hole,place in the holder for the pencil and use the pointy end to scribe both prop tips. Trim off the excess and balance.
Andy
Old Jan 27, 2015, 12:02 AM
Dukejet's Avatar
Joined Aug 2012
Guys, I use a set of calipers to mark the porps from the center out, to the lenth I want and then, snip, sand and balance. Works well.
Old Jan 30, 2015, 09:59 PM
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
Ok, I found a perfect solution. 5.5 x 4.5 regular and reverse rotation props. These are the same size as found on the 3s / 4s capable 800mm Rarebear that uses the same motor.
Maybe can maiden in a week or so.
Should be around 1.3kg thrust per motor.
Old Jan 31, 2015, 06:56 AM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Sounds just the ticket! Where did you source the props?
Old Jan 31, 2015, 02:23 PM
TheCure's Avatar
Canada, BC, Surrey
Joined Jan 2009
'Omnimodels' on ebay.
These props are just the ticket too, since I probably would have had to cut down two 6" props as they'd be contacting each other.
Old Jan 31, 2015, 03:05 PM
Reap the wild wind
Bristol,UK
Joined Feb 2007
Thanks. Looking forward to video and flight report when you have decent weather!
Discussion Hobby lobby F9F Panther EPO Jet Receiver Ready ARF smasher41 Foamy EDFs 1034 Jan 24, 2015 04:52 PM
Discussion HK AT-6 Texan EPO Plug-n-Fly 29.5" w/s stuart warne Electric Warbirds 12 Jun 14, 2011 03:47 AM
For Sale HK Mini-PITTS -- EPO, Brushless, Plug 'n Fly WRXronald Aircraft - Electric - Airplanes (FS/W) 3 Aug 04, 2010 11:03 PM
New Product New HK Mini F-16 EDF Fighter Jet / EPO Plug-n-Fly CrashingDutchman Foamy EDFs 13 Jul 02, 2010 12:15 AM
Discussion HK's EPO F-16 WRXronald Foamy EDFs 5 Apr 11, 2010 03:47 PM
