Old Jan 16, 2016, 11:01 AM
addictedtoplanes is offline
Find More Posts by addictedtoplanes
and helis!
addictedtoplanes's Avatar
Canada, ON, Guelph
Joined Jun 2012
Question
Waterproofing pre-covered floats
So this past summer, I acquired a well loved .40 size Hangar-9 J-3 Cub, with the Hangar-9 .40 size floats. They had considerable hangar rash, so I've spent most of this winter repairing them for the summer. They are balsa, covered with Ultracote. I am worried about water leakage in the seams. Do any of you guys have any ideas about sealing the floats, short of stripping them completely, and fibre-glassing them?
addictedtoplanes is offline Find More Posts by addictedtoplanes
Old Jan 21, 2016, 08:51 AM
Lambro is online now
Find More Posts by Lambro
Joined Feb 2013
I believe the current H9 Floats have a fiberglass "skin" on the bottom surfaces. If you do not see cracks at the seams, the UltraCoat covering is not prone to leakage. On other balsa floats which are covered by the builder, 1/2" strips are run completely over edges everywhere there is a balsa seam and especially at the keel before final Monocote or UltraCoat covering to give a bit more durability and covering thickness. In my experience, in the absence of actual damage to covering, leakage has never been an issue except at penetrations through the balsa, such as at strut mounts and rudder mount screw at the transom. At those penetrations, I apply a little marine adhesive/sealant around the attaching screws or bolts.
Lambro is online now Find More Posts by Lambro
New Product Microaces Cessna 195 & LC-126 Float Plane - Pre-ordered Kit despatch dates set MICROACES Scratchbuilt Indoor and Micro Models 27 Dec 11, 2015 10:07 AM
Sold Waterproof floating quadcopter fatshark fpv thefido Aircraft - Electric - Multirotor (FS/W) 5 Jun 30, 2015 08:47 PM
Sold Pre Built, Pre Covered Sig Somethin' Extra Kit and OS .46 AX2 FlyLowFlyHard Aircraft - Fuel - Airplanes (FS/W) 0 Mar 09, 2015 08:47 PM
For Sale Pre Built, Pre Covered Sig Somethin' Extra Kit and OS .46 AX2 FlyLowFlyHard Aircraft - Fuel - Airplanes (FS/W) 0 Mar 04, 2015 05:14 PM
Pre-covered floats? anixs Waterplanes 5 Jan 04, 2005 05:43 PM
