Old Feb 22, 2015, 11:43 AM
Joined Feb 2015
Help!
D4R/Naze telemetry problem..
Hi people,
So i recently went from a Naze 32 Acro to a Naze 32 Full.
To get my voltage readings, i hook it up to the FrSky telemetry pins on the Naze and run green and black wire to my D4R-II telemetry port. (just like i did with my old Naze)
From my PDB i run 3S voltage to the Naze "Voltage reading" pins.
I activate VBAT, TELEMETRY in baseflight / cleanflight ( yes, ive tried both).
Now to the problem or mistake by me...
On my old Naze i got the total voltage value on my flight battery. (around 12 volts)
On my new Naze i get about 5-6 volts. (Which could be the simulated "per cell?)
On my Taranis i have tried both "Cell" and Cells" but these give me the same value.
Vfas is not working either.
Mind that the readings come when i arm the board. as it should.
I really want my total voltage reading and nothing else.
Please help! what am i missing?
Setup:
Naze 32 "Full"
Kiss ESC 18A
Cobra 2208 2000KV
HQ PROP 6045
D4R-II with Telemetry
Taranis X9DPRO
GoPro Hero 3
ImmersionRC 600mw
Fatshark 600TVL
Fatshark Attitude V2
running on 3S Nano-tech battery.
Dump:
Code:
aux 0 48
aux 1 512
aux 2 1024
aux 3 512
aux 4 0
aux 5 0
aux 6 0
aux 7 0
aux 8 128
aux 9 0
aux 10 0
aux 11 0
aux 12 0
aux 13 256
aux 14 0
aux 15 0
aux 16 0
aux 17 0
aux 18 0
aux 19 0
aux 20 0
aux 21 0
aux 22 0
aux 23 0
mixer QUADX
feature -PPM
feature -VBAT
feature -INFLIGHT_ACC_CAL
feature -SERIALRX
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -LED_RING
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -POWERMETER
feature -VARIO
feature -3D
feature -FW_FAILSAFE_RTH
feature PPM
feature VBAT
feature SERVO_TILT
feature FAILSAFE
feature TELEMETRY
map AETR1234
set looptime = 2000
set emf_avoidance = 0
set midrc = 1500
set minthrottle = 900
set maxthrottle = 1850
set mincommand = 800
set mincheck = 1100
set maxcheck = 1900
set deadband3d_low = 1406
set deadband3d_high = 1514
set neutral3d = 1460
set deadband3d_throttle = 50
set motor_pwm_rate = 400
set servo_pwm_rate = 50
set pwm_filter = 0
set retarded_arm = 0
set disarm_kill_switch = 1
set fw_althold_dir = 1
set reboot_character = 82
set serial_baudrate = 115200
set softserial_baudrate = 9600
set softserial_1_inverted = 0
set softserial_2_inverted = 0
set gps_type = 0
set gps_baudrate = 0
set gps_ubx_sbas = 0
set gps_autobaud = 0
set serialrx_type = 0
set spektrum_sat_bind = 0
set spektrum_sat_on_flexport = 0
set telemetry_provider = 0
set telemetry_port = 0
set telemetry_switch = 0
set vbatscale = 110
set currentscale = 400
set currentoffset = 0
set multiwiicurrentoutput = 0
set vbatmaxcellvoltage = 43
set vbatmincellvoltage = 33
set vbatwarningcellvoltage = 35
set power_adc_channel = 0
set align_gyro = 0
set align_acc = 0
set align_mag = 0
set align_board_roll = 0
set align_board_pitch = 0
set align_board_yaw = 90
set yaw_control_direction = 1
set acc_hardware = 0
set mag_hardware = 0
set max_angle_inclination = 500
set moron_threshold = 32
set gyro_lpf = 42
set gyro_cmpf_factor = 600
set gyro_cmpfm_factor = 250
set pid_controller = 0
set deadband = 0
set yawdeadband = 0
set alt_hold_throttle_neutral = 40
set alt_hold_fast_change = 1
set throttle_correction_value = 0
set throttle_correction_angle = 800
set rc_rate = 90
set rc_expo = 75
set thr_mid = 50
set thr_expo = 67
set roll_pitch_rate = 24
set yaw_rate = 36
set tpa_rate = 47
set tpa_breakpoint = 1500
set failsafe_delay = 10
set failsafe_off_delay = 200
set failsafe_throttle = 900
set failsafe_detect_threshold = 985
set auto_disarm_board = 5
set rssi_aux_channel = 0
set rssi_adc_channel = 0
set rssi_adc_max = 4095
set rssi_adc_offset = 0
set yaw_direction = 1
set tri_unarmed_servo = 1
set fw_roll_throw = 0.500
set fw_pitch_throw = 0.500
set fw_vector_trust = 0
set gimbal_flags = 1
set acc_lpf_factor = 4
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = 1
set small_angle = 25
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set accz_lpf_cutoff = 5.000
set mag_declination = 0
set gps_pos_p = 11
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 20
set gps_posr_i = 8
set gps_posr_d = 45
set gps_nav_p = 14
set gps_nav_i = 20
set gps_nav_d = 80
set gps_wp_radius = 200
set nav_controls_heading = 1
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set p_pitch = 24
set i_pitch = 28
set d_pitch = 32
set p_roll = 20
set i_roll = 24
set d_roll = 31
set p_yaw = 63
set i_yaw = 18
set d_yaw = 13
set p_alt = 40
set i_alt = 25
set d_alt = 60
set p_level = 90
set i_level = 10
set d_level = 100
set p_vel = 120
set i_vel = 45
set d_vel = 1
set fw_gps_maxcorr = 20
set fw_gps_rudder = 15
set fw_gps_maxclimb = 15
set fw_gps_maxdive = 15
set fw_climb_throttle = 1900
set fw_cruise_throttle = 1500
set fw_idle_throttle = 1300
set fw_scaler_throttle = 8
set fw_roll_comp = 1.000
set fw_rth_alt = 45
/ Alex, Sweden
Alex__ is offline Find More Posts by Alex__
Sold FrSky D4R-II Telemetry Receiver ShokWaveRider Aircraft - Electric - Multirotor (FS/W) 0 Feb 22, 2015 06:44 AM
Sold FrSky D4R-II 4ch 2.4Ghz ACCST Receiver (w/telemetry) PepsiCola Aircraft - General - Radio Equipment (FS/W) 1 Jun 18, 2013 05:44 PM
Sold FrSky D4R-II 4ch 2.4Ghz ACCST Receiver (w/telemetry) PepsiCola Aircraft - General - Radio Equipment (FS/W) 2 Jun 18, 2013 05:43 PM
Sold JR 9303 w/ Frsky telemetry DJT module and D4R-II RX DaMaDo Aircraft - General - Radio Equipment (FS/W) 0 Apr 05, 2013 10:47 AM
Help! How to easily setup voltage telemetry on FRSky DHT DIY Kit and D4R-II receiver? Atleee Radios 1 Oct 16, 2012 10:40 AM
