Old Yesterday, 10:42 AM
Hollywood2979's Avatar
United States, TX, Cibolo
Joined Nov 2011
I still think its a beautiful plane, I have one of each, a Fly Fly and a Aerosky B60 in boxes.
Hollywood2979 is offline Find More Posts by Hollywood2979
Old Yesterday, 10:54 AM
Mach One
captain MoMo's Avatar
Joined Apr 2011
Originally Posted by Cocg View Post
Didn't think anyone was here.! (like if a tree falls in the woods does anybody here it?) All the un built kits out there! Wow.
I have had gremlins with mine.. Maiden went initially well, yet my right power went down causing an unrecoverable nose in.. A bit of damage.. Persued and fixed all.. Not as pretty anymore.. But .. Changed out some things .. Got another vid I'll put up..
A little disappointed in its "tailwagging" characteristic, Even with counter rotating props.. I wonder if it has to do with its very "flexible" vertical stab. I tried some stiffening but still "wags".. (Have not yet flown in calm air as of yet) And, although goofy a little too, I had him .. So a different pilot as well.. Attachment 7724853
Put a Head Holding Gyro like the Guardian or the A3X and the problem will go away. Its mostly due to air flow and direction bouncing the model around - and at times imperfect aerodynamics of models as opposed to the real scale versions. I want to build mine soon as I love the looks. I will look at going all out with mods Including adding spring loaded metal struts, rubber wheels, Guardian Gyro, maybe ebrakes and lights... plus chaneg out the goofy WWI pilots!
captain MoMo is offline Find More Posts by captain MoMo
Old Yesterday, 10:59 AM
Mach One
Joined Apr 2011
What control surface throws and CG did you use foryour model?
Old Yesterday, 11:18 AM
Fly and let Fly!
Cocg's Avatar
United States, CO, Grand Junction
Joined May 2010
Capt. Momo. Will get back to you on the throws, Generally I'll "eyeball" them.. triple rates.. I found it needed full Elevator rate to feel authorative.. And thought of the Gyro thing.. CG.. 120mm back from LE at the root.. Does well at my 5ooo ft. altitude. BTW, Cannot get the flaps to sit "tight" .. I think the clevis/horn placement is too far back on the flap surface..
Don't let this happen to you.. Name: 2015-01-25 009.jpg
Description: I believe when I "propped up" .. Overloaded an ESC.. But she is good now.. Did buy a new canopy and even though new wings etc. are available, wanted to get this dialed in 1st.. Think I got it..
Cocg is offline Find More Posts by Cocg
Old Yesterday, 12:39 PM
Fly and let Fly!
Cocg's Avatar
Joined May 2010
Here is the other..
Vid...
Nitroplanes Aerosky RC Duke B60 Twin Plane Cam mount. (1 min 41 sec)
.. Since folks are still around.. ! Get them built boys..!!
Old Yesterday, 02:41 PM
Rookie Pilot
Finest Racing's Avatar
United States, NJ, Old Bridge Township
Joined May 2013
Vid... https://youtu.be/kQ3kkD1cyNk.. Since folks are still around.. ! Get them built boys..!!
Reading and watching all the problems make me wonder if I should risk flying the plane.
Has anyone replaced the motors with the HobbyKing 900kv motors? I read somewhere they were more efficient.
Finest Racing is offline Find More Posts by Finest Racing
Old Yesterday, 03:02 PM
Fly and let Fly!
Cocg's Avatar
Joined May 2010
Those HK motors are what I am flying with.. Efficiency ..? So so.. Bats always come down warm, (although all flights have been wind battling) using 3000 to 3300 mah 4s.. Did a 5s for a flight, (separate BEC with a 500mah 3s.) but motors/props seem to hit a red line and rpm out. Flys fine however scale like and then some.. Frankly its gets off the ground in a hurry if you don't scale accelarate, could probably change pitch for more rpm.. You must fly it scared or not. No excuses..!
Old Yesterday, 04:16 PM
United States, CT, East Hartford
Joined Jul 2008
My FlyFly is built, no maiden yet. Aerosky still in the box.
handyman 220 is offline Find More Posts by handyman 220
Old Yesterday, 04:54 PM
Rookie Pilot
Joined May 2013
Thanks, I have a 4000mah I would to try. It is small enough to fit.
Question Nitroplanes Aerosky 55" Extra and Sbach rcninja 3D Foamies 220 Jul 16, 2014 07:30 AM
Discussion AeroSky B60 Tim B. Electric Plane Talk 100 Jun 19, 2014 03:45 PM
Discussion FLY FLY Beechcraft Duke B60 Hollywood2979 Foamies (Kits) 0 Jul 16, 2012 01:51 PM
For Sale FS/FT Keurig B60 Special Edition...Used only 5 times Bombo Non R/C Items (FS/W) 1 Feb 21, 2011 12:58 PM
For Sale Keurig B60 Special Edition Gourmet Single-Cup Home-Brewing System thannamhbfp Non R/C Items (FS/W) 1 Dec 18, 2009 03:53 AM
