Old Nov 02, 2014, 12:05 PM
Helnet @--X
Helnet's Avatar
Canada,Qc
Joined Dec 2003
Originally Posted by majjed2008 View Post
Hello guys
I am using exactly same setup now but i just have 4S battery can i use it with this setup ?
please help me
thank you
I check with ecalc and the best setting for 1X4S-5000mah is with a 10X4 propeller. You got a mixed flight time of 13 min. If you stay in 3S and change your propeller from 12X6 to 10X4 you will increase flight time to 20 mins.
It's calculate for AUX weight of 2500g
Like Heppy ket wrote " is a good starting point, but not the final word."
Helnet is offline Find More Posts by Helnet
Old Nov 02, 2014, 02:22 PM
Joined Sep 2014
thank you very much for your replay .
I ask since our frined ( rcbedrock ) already try it with that setup and he post some Vedio here in this thread and it was good one , I check the ecalc also and get same as your result but i see one did it with same setup wich i have i just dont have the 3S battery this is why i ask here for any one can help will much appricate .
I am looking for very long range setup if possible as will .
Thank you
majjed2008 is offline Find More Posts by majjed2008
Old Nov 05, 2014, 06:14 AM
Joined Sep 2014
any one can help me please ?
Old Nov 05, 2014, 07:31 AM
amba's Avatar
Joined Feb 2011
Hello guys
please help me
thank you
I don't have this wing but I can say this -
As general rule, any 3S setup will work 4S if you take same weight motor, with 3/4 KV value (to keep final RPM the same), and batteries with 3/4 mAh capacity (to keep AUW the same).
You can keep battery mAh capacity - this means Wh and weight increase by 33%, if the air frame can handle it, all good.
Specifically for the buffalo FX-79, should handle 5000mAh 4S with no problem (from AUW perspective), and probably 10000mAh 4S too.
amba is online now Find More Posts by amba
Old Nov 05, 2014, 04:32 PM
Joined Sep 2014
thank you very much
Old Nov 06, 2014, 08:48 PM
Canada
Joined Jul 2009
Anyone know of a supplier in Canada or the US that sells the main carbon spar? Can't seem to find one that is long enough.
xviper is online now Find More Posts by xviper
Old Nov 06, 2014, 09:47 PM
Canada, ON, Toronto
Joined Nov 2011
I am almost done with my build. What is holding me up is that I am undecided whether I should glue the wings on permanently or leave it removable.
What has everyone else decided on?
01viper27 is offline Find More Posts by 01viper27
Old Nov 07, 2014, 09:43 AM
HuskyDude's Avatar
Canada, BC, Kamloops
Joined Jan 2011
How long and what is the dia. ?
Would a arrow work? That's what we use in our gliders. Walmart...
HuskyDude is offline Find More Posts by HuskyDude
Old Nov 07, 2014, 11:16 AM
Canada
Joined Jul 2009
Interesting thought.
10mm OD, 8.2mm ID (but 8.0 should also work), ~32" L. I'll have to go measure one. Thanks.
Old Nov 07, 2014, 12:10 PM
Hungary, Heves County, Eger
Joined Jan 2010
Hello guys
please help me
thank you
Hi,
I think this setup can work with 4s, but you have to use 11*5 or 10*6 prop.
But i think, the best choise the 3s
rcbedrock is offline Find More Posts by rcbedrock
Old Nov 07, 2014, 01:01 PM
Canada
Joined Jul 2009
Originally Posted by rcbedrock View Post
Hi,
I put in a 60amp ESC, kept the stock motor and run a 10X5 prop. It flies OK but I'd like a little more push. I may up that to 10X6 or even 10X8. I'm not using this plane for FPV but kept a recording FPV camera on for aerial videos.
Old Nov 11, 2014, 10:40 AM
Joined Sep 2014
Hi,
yes i will tray the 4S with the 10X6 prop and i will update you here how it go maybe this weekend i will .
Thank you very much for your replay and your post it help me a lot much appricate ,
Old Nov 13, 2014, 05:14 PM
Chief
CW4R's Avatar
Joined Apr 2014
Hello,
Does anyone have a good working/stable Mission Planner Pixhawk setting file for the FX-79?
Ben
CW4R is offline Find More Posts by CW4R
Old Nov 21, 2014, 08:23 PM
Canada, ON, Toronto
Joined Nov 2011
This is a build video of my Zeta FX79 Buffalo flying wing plane. I hope you will find it informative and enjoy watching it.
Power Plant;
25-42 900 KV PROPDRIVE Brushless Motor
13" x 7" Graupner Folding Prop
Trust 55A ESC with External Turnigy 5A UBEC
2 - 4S 5200 mAH Multistar LiPo Packs
Avionics;
Dragon Link 433 Mhz UHF
Cyclops Tornado Flight Controller
MFD TeleFlyPro Tracker
Modified HK Pan and Tilt Gimbal Assembly
Sony Super HAD CCD 600TVL IR Block Camera
RMRC 1.3 G Int'l 800mw VTX
RMRC LC Filter LPF-01
X12 Pro UBEC
Turnigy Receiver Controlled Switch
4 - HK 15178B Metal Gear Servos
1 - SW4805-6PA sailwinch servo
Background music composition is by myself from my Mac Air using the Garage Band application which obviously is titled “VIPER Loop.” The drive for me to do this simple composition was made to avoid copyright laws.
FX79 Buffalo Build 20141122 (7 min 48 sec)
Old Nov 24, 2014, 02:08 PM
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Nice mods!
Cheers,
Jim
jesolins is offline Find More Posts by jesolins
Discussion New FPV Age ZETA FX-79 Buffalo 2000mm Professional FPV Fly Wing Jill Liu FPV Aircraft 2 Oct 26, 2013 09:59 PM
