Old Oct 01, 2013, 06:00 AM
NewFlyer
KenChin's Avatar
Kuala Lumpur, Malaysia
Joined Aug 2006
Originally Posted by G-LO View Post
Wow! That is impressive Ken!
If you have a good computer radio, you should be fine with the ailerons and such.
Are you going to paint it? If so, from what type eagle or hawk?
Still looking for someone who is good in airbrush. I am only good in brush works..
KenChin is online now Find More Posts by KenChin
Old Oct 10, 2013, 10:16 PM
Flying Foamies
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
PX-22A (7 min 30 sec)
another flight, endurance run. except a few video cuts what I believe to be nearly 10min on a 900mah
have to keep it up high cause the the lower altitude are occupied by 2 CP heli and one Multirotor. collision with those can be fatal
speedactyl is online now Find More Posts by speedactyl
Latest blog entry: Clowncar Challange
Old Oct 17, 2013, 05:43 AM
Italy, Piedmont, Asti
Joined Jun 2012
Originally Posted by Joel K. Scholz View Post
Eagle in flight
Hi!
I have a friend who might be interested in building this Eagle: do you a plan which you could send me?
l.aluffi is offline Find More Posts by l.aluffi
Old Nov 04, 2013, 02:21 AM
tumarol's Avatar
Germany, BY, Ruhstorf an der Rott
Joined Feb 2012
My version of the bird of prey, i called it "Kuno". It´s made all of depron 6mm, wingspan = 120 cm, AUW = 456 gramm. I like it because it´s a nice and quiet slowflyer.
Herbstflug mit Kuno dem Depron Adler (1 min 52 sec)
tumarol is offline Find More Posts by tumarol
Old Nov 04, 2013, 02:58 AM
DIY Mania from Taiwan
Taiwan
Joined Aug 2011
nice one
your "Kuno" is well painted
thanks for sharing
regards
Sam
samwei1950 is offline Find More Posts by samwei1950
Old Nov 23, 2013, 09:12 AM
Flying Foamies
speedactyl's Avatar
Joined Jun 2012
Manila RC Club #16 (3 min 19 sec)
PX22-A up in the air again this time keep an eye in 1:04 Anomaly
a quick screen grab PX22 and PX22-A see the difference in design
PX22
PX22-A
PX22
PX22-A
Old Nov 23, 2013, 09:45 AM
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Nice*
G-LO is offline Find More Posts by G-LO
Old Nov 23, 2013, 01:16 PM
Too many planes isn't enough!
VPCTechRC's Avatar
United States, CT, Hartford
Joined Dec 2012
Mini-Eagle -------> Cardinal
Hi all. I finally finished building one of the eagles! I'm not actually sure which kind to call it, but it's the 3-layer laminated wing version as poopsed to the airfoil wing. I guess it's the FFF eagle... made with Dollar Tree foam... and it's scaled to 50% for a 28'' wing and AUW @ 134 grams (4.7oz). I took all the paper off the foam and sprayed it with red Krylon H2O after it was built. I do have a 7 footer in the works that's about 85% complete.
I couldn't be happier with the way this little guy flies on V-tail only. Soooo much fun and incredibly stable. The ESC,motor, prop, battery and servos are listed at the end of the vid for this set up.
Check out the video here:
RC Mini-Eagle Cardinal MAIDEN FLIGHT with Dollar Tree RediBoard (5 min 29 sec)
I'll try to dig up some build pics and add them to this forum.
The
My opinion? BUILD ONE!! It can be done in a weekend and it's so worth it!
Cheers all,
VPCTechRC
Chris
VPCTechRC is offline Find More Posts by VPCTechRC
Old Nov 23, 2013, 06:55 PM
Addicted to flight since 1944
rbrown3rd's Avatar
southern Florida
Joined Feb 2004
Nice. I like the idea of just using a profile for the fuselage. Seems like an easy build.
rbrown3rd is offline Find More Posts by rbrown3rd
Old Nov 23, 2013, 07:00 PM
rbrown3rd's Avatar
southern Florida
Joined Feb 2004
Originally Posted by Aeronut41 View Post
I have made a quick foam buzzard from dollar store foam and some left over parts from a non working powered kite that was in my junk pile. It has a 60" wing span with a simple KFM2 airfoil and ruddervators for control . Wasn't sure it would fly but was pleasantly surprised as it soars and thermals nicely. Recently three real buzzards came along and joined my bird. We all circled in some nice lift for about 10 minutes and it was a lot of fun. My son took a quick video of a test flight. Cloudy and not much lift but it does look like the real thing up there especially only costing about $3 Thanks for looking, Aero
http://www.youtube.com/watch?v=E2J-Eq4sb98
Old Dec 17, 2013, 09:40 AM
home of the best antennas
United States, FL, Boca Raton
Joined Nov 2011
http://www.youtube.com/watch?v=GFERpqjQiug
The
Cheers all,
VPCTechRC
Chris
Do you have a link to the plan for this? I have plenty of dolla tree foam.
KondorFPV is offline Find More Posts by KondorFPV
Old Dec 17, 2013, 10:12 AM
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Hi Kondor
I have a plan for this on a similar build. There's a downloadable PDF on post 1 and a image on post 7.
Andy
http://www.rcgroups.com/forums/showthread.php?t=2057167
Aero Andy is online now Find More Posts by Aero Andy
Latest blog entry: Eagle
Old Dec 23, 2013, 02:07 PM
VPCTechRC's Avatar
Joined Dec 2012
Hey Kondor! The exact version I built (in 28'' and 84'') is the very first link on POST #3 of this thread. It's the one with the 3 layer wing.
If you build the 28'' version (orig plans scaled to 50%), take off all the paper and don't use a spar of any kind unless you want an indestructible rocket-eagle. It's not needed when the 3 layers are laminated together in this design.
But be sure you trace the wing 1/2s as FULL wing pieces, i.e. don't make 6 pieces of wings... just 3 whole pieces, tip to tip. This makes it MUCH easier to line up the wing layers not having to marry the halves together.
Better still...It all fits on ONE sheet of DT Foam board! Too cool.
Let me know if you need any more info. I'm sure there are others that are more knowledgeable as well I've had great luck with getting info from the great members here.
Thanks / Cheers / Good luck!
Discussion Why aren`t most foam planes made with EPP or equivalent. Scarey Foamy EDFs 1 Jul 24, 2007 10:20 PM
Planes Built With EPP And Depron. What Would Be Your Favorite. jbj620 3D Flying 10 Dec 05, 2004 07:06 AM
Rave Before n After My new war bird P-51 Mustang(EPP) powder Slope 22 Aug 22, 2003 01:27 PM
hey guys if yous are looking for arf war bird planes seafire Foamies (Kits) 5 Mar 10, 2002 05:41 PM
