Old Yesterday, 08:16 AM
Thrawn150's Avatar
USA, IL, Oak Lawn
Joined Apr 2007
Question
EC5 setup
What is the default connection type on a ec5 lipo, Male or female. I am getting 6s lipos with 5.5 bullets and converting them to ec5s. then using a series connector for progressive hobby (http://www.progressiverc.com/series-ec5-adapter.html). My issue is that it looks like it should be male coming off the battery's, but when you look at the charge cables they are also male. The charge cable from progressive says female, but then adds it has male connectors. Very confused.
Thrawn150 is online now Find More Posts by Thrawn150
Latest blog entry: H9 P-47 30CC EP build
Old Yesterday, 08:30 AM
Mulit-Platform Pilot
barracudahockey's Avatar
United States, FL, Jacksonville
Joined Sep 2004
Dont feel bad, those connectors are a little weird in that regard.
EDIT: Don't post before coffee
barracudahockey is online now Find More Posts by barracudahockey
Old Yesterday, 08:33 AM
United States, MN
Joined Feb 2011
barracudahockey is incorrect. Typically the pins not the housing determine if the connector is male/female but they are frequently labeled incorrectly. This is why Horizon Hobby tried calling them DEV/BAT and good connectors have that labeling actually on them.
The link you gave is labeled correct. It has 1 male and 2 female. A 'female' housing has 'male' pins in it and is typically referred to as a 'male' connector.
Several other items on the ProgressiveRC site are labeled incorrectly though. It's best just to look at the pictures to ensure you get the right thing.
grimbeaver is offline Find More Posts by grimbeaver
Old Yesterday, 08:39 AM
Joined Sep 2004
Removed for stupidity
Old Yesterday, 08:44 AM
tntpoof's Avatar
Joined Aug 2012
male connector with female 5 mm bullets is on battery.. Female connector with male end 5mm is charger or esc side That's all folks..
How to solder EC5 connectors (6 min 4 sec)
tntpoof is online now Find More Posts by tntpoof
Old Yesterday, 08:46 AM
tntpoof's Avatar
Joined Aug 2012
Think of the plastic casing. The battery has the female.
Though internally it has the male pins on the battery side, its still the female connector.
WRONG !!!!!!!! totally
Old Yesterday, 09:22 AM
Joined Sep 2004
I'll shut up now.
LOL I went out and looked at it twice and still screwed it up.
Old Yesterday, 09:32 AM
United States, MN
Joined Feb 2011
I'll shut up now.
Happens to the best of us.
Now I'll take this moment to point out this is a great reason to switch to Anderson PowerPoles No matter what you got it will always plug into the other one. No male/female to worry about.
*end sermon*
Old Yesterday, 09:33 AM
Thrawn150's Avatar
USA, IL, Oak Lawn
Joined Apr 2007
I'll shut up now.
No worries, glad you are willing to help.
Old Yesterday, 11:38 AM
Joined Feb 2014
EC (2, 3, or 5) connectors are confusing.
Battery connector Male Housing/ Female Bullet connector
Charger side Female Housing/Male Bullet.
It's best if the vendors use a picture as the naming can be problematic.
Kemora is online now Find More Posts by Kemora
Old Yesterday, 08:31 PM
United States, IA, Sidney
Joined May 2012
All my lipos have the female end on them and the charge lead is male. If you lay them out, male and female, it should be obvious what is what. Look inside your plane where the battery hooks up and you will see it is a male connector.
tyme4me is online now Find More Posts by tyme4me
Old Yesterday, 10:50 PM
Georgia
Joined Jun 2007
Pre-heating the plastic shell with a heat gun before you insert the connector pin can really reduce the needed force. Just don't overdo, or the plastic will melt,
There are more than one kind of EC-5 connector, look carefully at the beveled flange before you start. One version requires that you insert the wire through the connector shell before you do any soldering.
I fill the cup about 1/2 with solder before soldering the wire.
Depending on the wire size, you may or may not want to pre-tin the wire.
The idea behind pre-tinning is to make sure that the wire's inner strands
have solder on them.
It's a good idea to find out the cup depth, and adjust the stripped wire length to suit.
Give that the currents can be quite high, solid, well made solder connections are a
necessity.
chuck75 is offline Find More Posts by chuck75
Sold EC5 Connectors (2 Pairs), Female EC5 Connectors (5 Sets) ff954 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 09, 2014 07:45 AM
Sold Parallel Balance board Ec5 connectors Johnnymeg Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 20, 2013 11:00 AM
For Sale Quantum NIP Balancing board EC5/thunder power NIP lee062988 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Sep 19, 2013 08:24 AM
Discussion Are the E-Flight EC5 connectors compatible with HobbyKing EC5 copies? 6012HD Electric Power Cars 3 Mar 05, 2012 07:10 AM
