Old Yesterday, 06:50 PM
RCvertt's Avatar
Joined Aug 2007
Coax outer main shaft that is 3 mm diameter?
Any coax heli out there that has an outer main shaft that is 3 millimeters in diameter?
Looking for the shaft to be hardened steel and not a carbon fiber rod.
RCvertt is offline Find More Posts by RCvertt
Latest blog entry: Chupacabra sighting !!!
Help! 3.54mm diameter prop shaft? JeremyBB Dock Talk 11 Oct 16, 2013 08:22 PM
Wanted needed. Prop Spinner 25 mm / 3.2 shaft plainguy Aircraft - Sailplanes (FS/W) 0 Oct 13, 2013 11:57 PM
Wanted WANTED! MCX Inner Shaft with hub, Outer shaft collar, main gear collar screws rcpilotjr Aircraft - Electric - Helis (FS/W) 1 Apr 26, 2010 08:44 PM
Question RFM Spinner for 3.2 mm shaft on Hacker B20 Motor with only 3.0 mm shaft? AEMontoya High Performance 1 Dec 28, 2009 03:57 PM
Question 3 MM prop adaptor shaft diameter? conceptmachining Power Systems 7 Nov 06, 2006 09:11 AM
