Old Dec 18, 2014, 02:21 AM
Joined Jun 2010
Any news about that voltage thingy on AA23920L ?
I have just opened mine and there are no adjustments to be done via a potentiometer or anything ...
I think that the voltage is set to 12.2V via software ... so if you want to change that, you have to change the software?
Or maybe some fixed value resistor ... ? My work as a communication electronics engineer is long ago, now i'm working as a software engineer ...
Would be really appreciated if anyone figured out how to get this thing to >13.5V!
tbirdulm is online now Find More Posts by tbirdulm
Old Dec 18, 2014, 06:50 AM
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Just wondering, why would one want 13.5V ? Isn't everything we do based on 12V
GregG is offline Find More Posts by GregG
Old Dec 18, 2014, 07:26 AM
Son, Norway
Joined Sep 2004
Sometimes 12V means 13.5V or 13,8V.
These are sometimes used for powering radio amateur gear, car HiFi etc.
Many chargers will put out more power on a higher voltage, but can't take two in series (24V).
Fred
flarssen is online now Find More Posts by flarssen
Old Dec 18, 2014, 09:57 AM
Power! Power! Power!
HaxNobody's Avatar
Joined Jan 2012
12v "nominal" is based on lead-acid battery technology which is considered fully charged at 12.6 volts (2.1 volts per cell). Car audio and related equipment are usually rated for peak output at 13.5-13.9 volts because this is the "float" voltage provided by the alternator to maintain the battery's state of charge. The equipment may provide additional output when juiced up to 14.8 volts since this is what the alternator can provide for "bulk" charging when the battery is flat or when the system is under heavy use.
HaxNobody is offline Find More Posts by HaxNobody
Old Yesterday, 12:55 PM
Joined Jun 2010
Just a bit more info on the Astec 23920 (12V / 236A Power Supply):
I have just found out the key to get more than 12V ... the key is located on the big daugtherboard located in the left side => ADM1041.
This IC (Secondary-Side Controller with Current Share and Housekeeping) is responsible for the Output voltage Regulation.
Tech Sheet: http://www.analog.com/static/importe...ts/ADM1041.pdf
What i now have to find out is, how to increase the Output voltage and make the ADM1041 "think" he has to do 13.5V ...
Problem:
=> I have to find out how to program that Thing ... O.o
I'll Keep you guys updated.
Old Yesterday, 06:19 PM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
If you get it to work, make sure you post a link to your solution on this thread over on the main reference thread here.
http://www.rcgroups.com/forums/showthread.php?t=1292514
John
jj604 is offline Find More Posts by jj604
Old Yesterday, 09:57 PM
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
can you put a diode to v ref to the chip?
rampman is offline Find More Posts by rampman
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 09:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 01:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 05:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 03:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 03, 2002 12:31 AM
