Old Jun 05, 2014, 07:06 PM
TAP993's Avatar
Joined Aug 2012
I tried a flight in the real world rather than my garden. The wind was 20kph and gusting to 25kph and had real problems with the gimbal. hovering seams OK, but as I set off upwind it blew the camera backwards. I corrected this and then turned downwind and the gimbal blew forwards so I just got sky in the video. Looks like not enough power to counteract the forces? The gimbal is well balanced and tilt total gain is at 70. Higher tilt gains gives me a chattering servo.
ecilop zyx gimbal in wind (0 min 31 sec)
TAP993 is offline Find More Posts by TAP993
Old Jun 06, 2014, 06:24 AM
Zaitsevsky's Avatar
Vilnius, Lithuania (EU)
Joined May 2009
It was a single test? ZYX-GS may switch off if tilt limit was achieved. It is possible to use 1N/mm spring, but 0.4N/mm will provide a more accurate operation in most cases.
Test with an airflow ( 2:50 ):
ee demo (5 min 26 sec)
Some time ago we found one reason of a wrong servo operation: http://www.rcgroups.com/forums/showp...postcount=3058
If you are using a 760mksek servo you must use a proper servo tester mode to find a neutral position of the pot.
Zaitsevsky is offline Find More Posts by Zaitsevsky
Site Sponsor
Old Jun 07, 2014, 05:45 AM
TAP993's Avatar
Joined Aug 2012
I flew 6 flights, mostly around 7 minutes due to altitude, wind and temperature. I did get the gimbal locked out one one flight so increased travel setting from -60 to -74, but get a bounce from the gimbal knocking on the pot with this. I'll order a better servo tester and start again. My force servos are very new, so after the problem described in that post presumably
Old Jun 11, 2014, 03:49 AM
TAP993's Avatar
Joined Aug 2012
I got a 760ys servo tester just like the one in your video and recalibrated. This is definitely an improvement and allows me a higher total gain on the tilt servo. A quick test in the garden looks good, but I'll test properly later.
Old Jun 15, 2014, 09:02 PM
Joined Dec 2010
If anybody is interested in a new ecilop airframe pm me. I bought mine and never got around to putting it in the air. Very flexible on price
KFM
drumbum961 is offline Find More Posts by drumbum961
Old Jun 22, 2014, 04:07 PM
TAP993's Avatar
Joined Aug 2012
KFM
From which country, for shipping?
Old Jun 27, 2014, 06:38 PM
Joined Jun 2014
Easy ECILOP build question - what bolts to connect the engine stands?
I started building my ECILOP Easy today, I've hit a dead end and I have a question.
Can someone describe the bolts that attach the engine stands to the main frame? I have already used all of the "chassis fixers" and "axial fixers" packages. I don't see any bolts/nuts that would be an obvious choice.
I think I'll be heading to the hardware store to try and find some bolts that will work, but before I do that I wanted to ask and see if I could get a description of the bolts/nuts that I need.
Never mind. After looking at the kit for an hour or so, I decided to use some bolts/nuts from the engine bolt bag. If these aren't the correct ones, I'll just go buy some more. Onward...
jmooreou is offline Find More Posts by jmooreou
Old Jun 29, 2014, 11:23 AM
Zaitsevsky's Avatar
Joined May 2009
M3x16 ... M3x20mm
Site Sponsor
Old Jul 05, 2014, 01:41 PM
Joined Dec 2010
I'm in the US. Will post details about the ecilop I have for sale soon.
KFM
Old Jul 19, 2014, 02:57 PM
Joined Jun 2014
More build questions
ymmv
Old Jul 20, 2014, 05:17 AM
Zaitsevsky's Avatar
Joined May 2009
I need DETAILED instructions/photos to enable me to get these installed. The servos that were sent are not the same as depicted in the photos in the EE 1209 assembly instructions.
MANUAL
Installation of a Force Servo on the Ecilop Easy gimbal (2 min 25 sec)
Site Sponsor
Old Jul 30, 2014, 05:30 PM
Joined Jul 2014
gimbal controller for servos
Hi there
is it possible to use a 2 axis gimbal controller, such as the Tarot ZYX22? or is compulsory to use a 3 axis one?
thanks
best regards
DDuser is offline Find More Posts by DDuser
Old Today, 12:45 PM
Joined Jun 2014
Hello Aleksey,
Here is a short video showing my attempt to calibrate my F-Servo
Ecilop Issues (1 min 21 sec)
I am using the large springs with the F-Servos I purchased from you.
As you can see, there is a neutral position that is close to level, but any slight deviation in either direction causes the gimbal to swing to the full limit position in that direction.
After working on this for several hours, this is as close as I can attain, so I plan to continue with this setting unless you have some other suggestion. Any observation or suggestions would be much appreciated.
Also, is there any detail on the dual controller setup? I purchased the Futaba and Turnigy transmitters to enable the separate controls for the pilot and camera operator like you show in your video and I'm just wondering if there are any examples of how to set up the two transmitters to achieve this capability.
Thanks again and wish me luck! ;-)
Discussion Five easy piece f-14 tomcat bobdaeronort Foamies (Scratchbuilt) 80 Oct 25, 2012 05:43 PM
Discussion Easy Glider VS Easy Glider Pro (what's different?) MkFn Electric Sailplanes 7 Nov 17, 2011 07:42 PM
Discussion Easi Glider film boca55 Serbia 0 Apr 20, 2008 04:46 PM
Discussion Spring Easi* in NZ harrys one Aerial Photography 8 Nov 14, 2007 01:22 PM
