Old Jan 27, 2015, 08:48 AM
Joined Sep 2013
New lipos are not charging help question
This is the charger
http://www.hobbyking.com/store/__260..._Genuine_.html
I used it prior and it has worked now after a while of it sitting in trying to charge new battery's I purchased and the charger works normal like it should be except the mah stays at zero, even after few min of charging voltage is currently 11.29 If I remember correctly I'm not home but it stays at that voltage won't increase
abiddar is online now Find More Posts by abiddar
Old Jan 27, 2015, 01:43 PM
Joined Sep 2013
doubble ordered the charger from hobbyking last year found my new one and still will not charge? any idea whats wrong
when i attach cables it displays voltage ill set amps to lets say 2.2? my 2200 mah battery i used to charge on 1.0 amp to help save life tryed that aswell still doesnt work, charger allows us to start the charge the balance lights go on and flicker voltage stays same amps displays 0.00 mah is 0.00 and time will continue to go up
battery is connected otherwise errors would pop up like if i remove a wire or something
seams like its working but just not working
balance leads are connect the right way black wire to negative
Old Jan 27, 2015, 01:50 PM
BigBadDogg's Avatar
United States, MI, Wyandotte
Joined Dec 2014
bummer. but Time for a new charger..
just might check your supply voltage..or hook up to a Real car battery.
BigBadDogg is offline Find More Posts by BigBadDogg
Old Jan 27, 2015, 01:52 PM
Joined Sep 2013
only thing that changed is i moved? would my new house have lower voltage to power these chargers? cause it worked with a few of my old batteries and now it does not work with anything. even the new charger i just opened
Old Jan 27, 2015, 02:10 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
What are the individual cell voltages?
hoppy is offline Find More Posts by hoppy
Old Jan 27, 2015, 02:15 PM
Joined Sep 2013
im not sure how to tell that? the battery says 3 cell 11.1V
Turnigy Nano-Tech 2200
Old Jan 27, 2015, 02:18 PM
Germany, BY, BA
Joined Sep 2014
Is your power supply strong enough?
Someone had already the same problem:
http://www.rcgroups.com/forums/showthread.php?t=2006307
RNFLY is offline Find More Posts by RNFLY
Old Jan 27, 2015, 02:28 PM
Joined Sep 2013
same one i used that it came with 12v
Old Jan 27, 2015, 02:36 PM
Joined Sep 2013
plugged it into my broken xfinity cable box's dc plug it has a power block thing on it and now it works and charges
Old Jan 27, 2015, 02:51 PM
Germany, BY, BA
Joined Sep 2014
Ok!
Discussion New traxxas ID lipo balance charging question hotdog1 Electric Power Cars 1 Dec 23, 2014 12:05 PM
Discussion New traxxas ID lipo balance charging question hotdog1 Batteries and Chargers 0 Dec 23, 2014 10:36 AM
Question Lipo Charge question, Could not find the answer (New here) Stadashic Batteries and Chargers 5 Feb 10, 2014 10:56 AM
