Old Jan 13, 2015, 09:49 PM
I'd rather be flying.....
United States, IA, Story City
Joined Oct 2013
Build Log
Austin Craft CIVY BOY 24 AMPLAN build
Hi Everyone-
Well, my PH 43 is still not done but I need to keep moving with my builds this winter... I'll finish the PH 43 later but before the end of March
So, I started building the Austin Craft Civy Boy 24 from my original kit plan printed copy. I have a complete original kit but am not using any kit wood.
Mr. Reck turned 90 years young last year and had quite an involvement with the Civy Boy models.
My version of this rare model will use a parkzone P51 micro gear drive and a " brick " receiver / servo board.
Litespan may be too heavy for this small model....
This should be a quick build but I'm a slow builder. Fuse sides are nearly done.
More later,
Best Regards,
Jeff
JeffMac is offline Find More Posts by JeffMac
Old Jan 14, 2015, 04:16 AM
I like real wooden aeroplanes!
Sundancer's Avatar
South-west France
Joined Sep 2007
Should be a cute little model Jeff, I've posted te entry and will be watching with interest.
Sundancer is online now Find More Posts by Sundancer
Old Jan 14, 2015, 08:51 PM
Joined Oct 2013
fuselage progress
Thanks George !
There is just enough room in the fuse to install the " brick ". This is a simple model
and hopefully will build up quickly.
Esaki tissue will be the covering. I'll try experiments with my WBPU on some
practice frames or just get some nitrate dope....
Best Regards,
Jeff
Old Jan 15, 2015, 11:10 PM
Joined Oct 2013
some progress
The tail surfaces are simple sheet balsa and are shaped and installed.
I'm thinking of taking a picture of my K & B " Infant " and using it as a profile
" engine " for fun...
The model will have a single wire strut landing gear similar to the plan.
More later....
Best Regards,
Jeff
Old Jan 17, 2015, 02:08 AM
Joined Oct 2013
Good news -
The test panels of esaki shrunk wonderfully with my nelson clear which had a few drops of
H2O added.... more later....
Best Regards,
Jeff
Old Jan 18, 2015, 10:38 PM
Joined Oct 2013
progress
fuselage is moving along -
the pylon is installed. The " brick " will slide into the fuse vertically .
The battery will attach externally to the pylon.
I'm probably going to use rudder and throttle on this model. Elevator pushrod will be installed just in case
Wingtips were made similar to my PH43 - leading edge cut from sheet rather than bending stripwood and warping the assemblies. The sheet wood shapes rather easily.
More later,
Jeff
Old Jan 19, 2015, 04:25 AM
Paul_BB's Avatar
France, IdF, Lagny-sur-Marne
Joined Feb 2007
Very cute, good luck !
Paul
Paul_BB is offline Find More Posts by Paul_BB
Old Jan 20, 2015, 11:41 PM
Joined Oct 2013
progress
Thanks Paul ! Luck I need.... the nose is so short and the fuselage is long...
The wing is together but not totally finished. The obligatory assembled view pics
are attached....
Best Regards,
Jeff
Old Jan 21, 2015, 12:06 AM
Paul_BB's Avatar
Joined Feb 2007
Post deleted, because of duplication.
Old Jan 22, 2015, 09:29 PM
Joined Oct 2013
progress - wing covered
The wing is now completed and covered with Esaki yellow. It's not shrunk yet -
the nelson clear WBPU will accomplish that when it's applied.
more later.....
Best Regards,
Jeff
Old Jan 23, 2015, 10:50 AM
Africa
Joined Jan 2005
Is the cg on the plan shown to be near the TE of the wing?
Cheers
Simon
Snorks is online now Find More Posts by Snorks
Old Jan 23, 2015, 06:53 PM
Joined Oct 2013
Hi Simon -
Yes, the CG is shown on the plan at the trailing edge, so that's good .... I will install the single strut LG similar to what is on the plan also... A heavy wheel may be in order ?
I'm about to the point of considering a 10 gram outrunner and a BL " brick " but not sure for now... the 10 gram would mount neatly and quickly, unlike the P51 motor / geardrive....
Progress - the wing has one thin coat of WBPU and shrunk nicely and coverage seems adequate.
Best Regards,
Jeff
Old Jan 24, 2015, 08:08 PM
Joined Oct 2013
motor mount progress
Well I figured why not just mount the P51 motor the old fashioned way, but using thick balsa for the mounts...
The prop is close to where it would be if the K&B .020 Infant were being used when test fit the motor assembly....
More later,
Best Regards,
Jeff
Old Jan 25, 2015, 01:20 AM
Patzpaint
Canada, BC, White Rock
Joined Sep 2014
Pardon my ignorance but what is wbpu?
Patzpaint is offline Find More Posts by Patzpaint
Old Jan 25, 2015, 03:34 AM
Sundancer's Avatar
South-west France
Joined Sep 2007
wbpu = water based polyurethane. The "Eezeedope" sold through the model trade is material of this type but is supposed to have some other additive, but also it is sold in DIY shops as a varnish for hardwood floors etc. Used in place of normal dope, but need a somewhat different technique. Search my build log for the KK Bantam for an explanation of using it. http://www.rcgroups.com/forums/showt...ghlight=Bantam
Discussion Ben Shereshaw 1937 "Champion" - AMPLAN Build Off September 2014 to March 2015 cpmcgraw Vintage & Old-Timer Designs 95 Today 11:26 AM
Contest AMPLAN Build Off - See Post # 152 for Status Report - 3 months to go Sundancer Vintage & Old-Timer Designs 166 Jan 25, 2015 03:46 PM
Discussion Ignition Coils and Austin Craft Timer Crist Rigotti Vintage & Old-Timer Designs 0 Jul 13, 2014 04:55 PM
