Salangane - Performance Slope/EP Glider
All Composite 2 Meter Sailplane
2M Composite Glider
The Salangane is a great looking 2 meter glider. It's all composite and you can build it out for powered or unpowered flight using the included interchangeable nose cones. You'll need some building experience to get it together, but the hardware is there. The frame is strong and reinforced with carbon, it has plug-in wings, and a solid carbon wing joiner. It's a full house ship that will be great on the slope or hunting down thermals.
Specifications:
  • WingSpan: 2020mm
  • Length: 1185mm
  • Wing Area: 34dm2
  • Airframe weight: 950g
  • Flying weight: 1400-1600g
  • Airfoil: MH32
Learn more about the Salangane at HobbyKing.
Old Dec 10, 2014, 03:02 PM
chip.greely is offline
Find More Posts by chip.greely
chip.greely's Avatar
Carlsbad, Ca
Joined Mar 2007
Looks awful Blade like,....
....a bit of a combo between the Original 2pc wing version and the more recent Carbon Blade, which sports the carbon boom.
Who is the Mfg'r?
chip.greely is offline Find More Posts by chip.greely
Old Dec 10, 2014, 04:00 PM
Phil.Taylor is offline
Find More Posts by Phil.Taylor
Phil.T-tailer
Phil.Taylor's Avatar
Devon, UK
Joined Jun 2003
http://www.rcgroups.com/forums/showthread.php?t=2017070
maybe Launchmodel?
I think I've seen the model in that build thread on a slope this year - actually flew quite well
Phil.
Phil.Taylor is offline Find More Posts by Phil.Taylor
Old Dec 13, 2014, 12:10 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Wide V angle
The v-tail angle looks very flat.
This plane will have minimal yaw/rudder control with the tails spread that far apart.
Pitch response should be crisp though.
I wouldn't bother with any rudder mixing because of the wide angle. You could get by with 5 servos.
R,
Target
target is offline Find More Posts by target
Old Dec 25, 2014, 04:43 AM
MosyCott is offline
Find More Posts by MosyCott
Albany, the place to slope off
Australia, WA, Spencer Park
Joined Dec 2008
Salangene Glider
I bought one of these from HK and I dont regret it one bit.... :-)
I did some research and found that it was being sold under the Osprey, banner un the UK.
http://www.sloughrc.com/default.asp?...temid=A-HS9172
I have been flying it now for around 12 months and I finally have it flying just as I wanted, with my F3F times coming down every time I get to fly a comp (twice a year) but now that our club ( Southern Slope Soares, WA AU) has got some timing gear, I imaging my time of 53.4 seconds, will start to fall.
https://www.facebook.com/pages/South...0477177?ref=hl
MosyCott is offline Find More Posts by MosyCott
Old Dec 25, 2014, 04:50 AM
MosyCott is offline
Joined Dec 2008
Just a few pics of her flying...... :-)
Old Jan 03, 2015, 02:29 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
I like the look of this glider.
Does someone know the included angle of the "V" tail?
What is the spar and joiner like? Does it seem strong?
This has been a bit of a weakness with some of the (otherwise) ok moulded planes from Hong Kong.
Jim.Thompson is offline Find More Posts by Jim.Thompson
Latest blog entry: Passer Thermo Composite Wings.
Old Jan 03, 2015, 03:17 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Most of the molded planes from over there use a lot of epoxy, and the strength to weight ratio is quite low. They still fly decently, but that is why you don't see may F3J planes originating form there, I believe.
R,
Target
Old Jan 05, 2015, 08:17 AM
homemade_project is offline
Find More Posts by homemade_project
Joined Jan 2015
Good stuff!!
Just added for you guys
---> Recommended electric power unit:
-Brushless Motor ER-252312d
-ESC Pro.c S-45
-LiPo Battery LP 3S 1P 2600 SR
-Folding Propeller Spinner Hub AT38/8C4.0ZM
-Folding Propeller 11x8/8
-Gold Connector 4.0BL
homemade_project is offline Find More Posts by homemade_project
Old Jan 05, 2015, 09:57 PM
MosyCott is offline
Joined Dec 2008
I have been flying mine for over 12 months now, go's like a rocket and my F3F times are starting to drop, its a real tuff bird as mine has hit the ground hard a couple of times, few patches on the leading edge of one wing and all's good.
I'm not with the model at the moment, but soon as I get home, I will measure the V tail angle for you.
Old Jan 05, 2015, 11:47 PM
Joined Aug 2008
Originally Posted by [I
MosyCott;30392716.............., I will measure the V tail angle for you.[/I]
Thanks.
Old Jan 07, 2015, 05:33 PM
a.crabby is offline
Find More Posts by a.crabby
Australia, SA, Adelaide
Joined Dec 2013
Salangane on 3S
Originally Posted by homemade_project View Post
Good stuff!!
-ESC Pro.c S-45
Thanks for that HP. I saw Singapore Hobbies have same setup recommended for the 2m Salsa - http://www.singahobby.com/?q=node/24069 .
Just took delivery of a Salangane yesterday. I hoping to use a 3S setup, however not sure if it will perform with a 1.6kg flying weight?
Has anyone flown the Salangane on a 3S setup?
Cheers
Crabby
a.crabby is offline Find More Posts by a.crabby
Old Mar 17, 2015, 04:58 PM
fasteddie123 is offline
Find More Posts by fasteddie123
FastEddie123
United States, MN, Lake Elmo
Joined Nov 2013
Cheers
Crabby
Im woking on it - It will have the Hobbyking gliderdrive 1120kv 830watt motor, 3s 1800 65c lip , 12x10 folder & 70 amp ESc .... I'm thinking about 13.5 oz sq ft. or so... (reasonable I think ) . eddie
fasteddie123 is offline Find More Posts by fasteddie123
Old Mar 24, 2015, 05:07 AM
a.crabby is offline
Joined Dec 2013
Thanks Eddie.
Let us know how you get on
Old Apr 15, 2015, 01:06 PM
FastEddie123
Joined Nov 2013
Thanks Eddie.
It's getting very close to complete - I had to work a lot of things around ( several iterations later - I have the best - I think ) .
Goal was to get CG correct without additional weight, and clean installation so I didn't have a ton of loose wire from the nose cone -> to the main body all over the place - so removing it for battery replacement goes easy and fast . The ESC is in the front bottom of the servo tray, 2 servos behind it -toward tail & battery mounted to servo tray extending out towards the front of the plane on top of ESC - getting close to motor up front , all electronics jammed back in fuselage Pics to come soon... .. eddie
Discussion 1.52M ARF EP Fox Thermo Fiberglass Slope Glider Sporty155 High Performance 1 Dec 29, 2006 06:32 AM
Off Site Ebay GWS F4U Slope Glider Park Flyer EP ARF 35.5" FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 0 Nov 23, 2006 02:35 AM
Off Site Ebay GWS Spitfire Slope Glider Park Flyer EP ARF 34.5" FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 0 Nov 23, 2006 02:35 AM
Sold GWS Spitfire & Corsair Slope Glider Park Flyer EP ARF 34.5" FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 6 Nov 09, 2006 11:42 AM
For Sale: Opus V DS, high performance slope glider bjaffee Aircraft - Sailplanes (FS/W) 0 Oct 03, 2003 05:58 PM
