Old Sep 25, 2014, 05:07 AM
Limetwist is offline
Find More Posts by Limetwist
Joined Sep 2014
First plane, first flight, plane lost! anyone else?
I bought my first parkflier after experience with a quadcopter. Hobbyzone Champ.
Took it to the park....open space.....not too wind (I think) and it took off.......totally lost control......flew away in a private property...with closed gates and tall trees...lost for ever...at least for me....
Now I am where I should have started in the first place...in front of a flight simulator (clearview)...... Feel very doubtful to buy another plane......it might just get away again....
any suggestions or comments?
Limetwist is offline Find More Posts by Limetwist
Old Sep 25, 2014, 05:11 AM
Benagen is offline
Find More Posts by Benagen
Blurry Iriot
Australia, WA, Swan View
Joined Sep 2013
Please don't let me dishearten you but......
LOL
Next time do a range check! It gives you a feel for how far away you can let the aircraft get before you may run into problems.
Welcome to RC, may this be your only loss! (touch balsa):-)
Benagen is offline Find More Posts by Benagen
Old Sep 25, 2014, 05:35 AM
gouch is offline
Find More Posts by gouch
de-registered abuser
gouch's Avatar
Lake Macquarie, Aust.
Joined Dec 2002
join the cue I lost a couple when I was still learning. All part of it when you are teaching yourself. I still lose them occasionally, but it's normally due to the ground coming up too fast
I know you didn't, but just don't do what some do and blame the radio when they have a fly away as a n00b......
gouch is offline Find More Posts by gouch
Old Sep 25, 2014, 05:40 AM
Frenche is online now
Find More Posts by Frenche
ooooh yeah
Frenche's Avatar
Ballarat, Victoria, Australia
Joined May 2004
My personal favourite was back in the dark ages (36mhz days) I would blame a "glitch" or someone else turning on their radio on the same frequency for when my planes made a sudden arrival with the ground when I was learning.
Best advice I can give is use a sim, I have Phoenix and use it almost daily even though I've been flying for over a decade. It makes learning orientation so much easier, if you have to "think" about what to do then you are already behind the curve and the plane is flying you instead of the other way around.
Also see if anybody else in your area can give you a hand to setup your plane. The only thing harder than learning to fly is learning to fly with a badly setup plane.
Most importantly, don't give up! It's an amazing hobby that will give your hundreds of hours of pleasure
Frenche is online now Find More Posts by Frenche
Old Sep 25, 2014, 05:47 AM
Joined Sep 2014
Not blaming the radio.....when I said I lost control..I meant I had no idea how to bring it back...radio was working..I panicked....and twisted the controls every which way.....and could only see it getting further away in spirals...LOL
Yes...I am spending time on flight sim now......heading to Parramatta club on Sunday to see what others do......learn that way first...also I felt that the Champ was so light....hard to control...but probably it was just me!
Old Sep 25, 2014, 05:52 AM
ooooh yeah
Frenche's Avatar
Joined May 2004
The lighter a plane (more specifically the wing loading) is the easier it gets thrown around by the wind. Also building/trees cause turbulence which makes it even harder. Calm days are your best friend whilst learning
Old Sep 25, 2014, 06:11 AM
gouch is offline
gouch's Avatar
Joined Dec 2002
That's exactly how I lost my first plane (that actually flew for more than 5 seconds before exploding into balsa dust) it got away on me, then I lost orientation so I thought I'd turn, then turn some more, then some more...... until it was a dot.....then I never saw it again!
flying isn't hard as such, it's the little things like balance throws and trim that catch people out. Get someone to set it up to fly nice and calm and you are 90% of the way there. The rest is simply orientation and stick time. That's where the sims come into their own.
Not flown a champ but if it's very lightly loaded perfectly calm air is very important when learning. Also remember the sticks aren't a switch, gentle movements over crazy bend the stick jabs is the go.
oh, best tip I was ever told on orientation. a plane flying away from you is easy to control roll of course, right stick means right roll, but coming toward you it is reversed, so if you think when the plane is coming toward you push the stick in the same direction to push that wing back up.......if that makes sense?
Old Sep 25, 2014, 06:14 AM
Joined Sep 2014
Thanks for the comments from all....at least I know that I am not the only one!
Probably will get another trainer.......but is it better with a parkflier that is very light or a larger one to fly in a RC field? as a first plane.....
Old Sep 25, 2014, 06:21 AM
gouch is offline
gouch's Avatar
Joined Dec 2002
depends on how much wind you want to fly in. light weight (or more accurately the lighter the loading on the wings) the more they get thrown around in the wind....which sucks when you want easy flying. And the more draggy the airframe the worse that is. But when it's calm, they fly nice and slow, which is very good.
Go out to the club, watch what the other guys are flying and you'll find something suitable for the field and conditions. And expect that whilst you may never lose one over the horizon again, you will crash them into oblivion sooner or later!
just googled that plane you lost, and yeah it's tiny, no wonder you lost it! I'd classify that as almost an indoor flyer, at the least, a zero breeze type outdoor plane. anything more than 2 knots would be a pain to fly that and have fun by looking at it's size
Old Sep 25, 2014, 06:55 AM
Jet Jackson is offline
Find More Posts by Jet Jackson
Ex-Fixed Wing RC pilot
Jet Jackson's Avatar
Australia, VIC, Baxter
Joined Jun 2014
I flew fixed wing for over 25 years and had my share of fly-aways and PFUs. I have only recently come back to RC modelling after a break of nearly 20years, this time flying quads.
If I may give some advice regarding losing orientation, when flying away from yourself the transmitter is in the correct orientation (right stick movement, model goes right, etc) but when model is flying towards you, everything is reversed.
A very simple tip is to point the transmitter antenna in the direction of flight, so if the model is going right, point the antenna to the right, when you turn and come back (left) turn the transmitter to left. What this does is to coordinate your eye-brain-fingers to work in the correct direction. Very simple but it works every time.
Cheers, Jet.
Jet Jackson is offline Find More Posts by Jet Jackson
Old Sep 25, 2014, 03:47 PM
Joined Sep 2014
Thank you for the tips Gouch and Jet, I'll go to the field and learn from others! :-)
Old Sep 25, 2014, 11:12 PM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Get a Bixler with landing gear or a AXN Clouds Fly and learn on either of those. They both handle the wind well, are cheap and fly really well.
The Bixler 2 has a landing gear set you can buy for it but the AXN doesn't. If you build either of them pretty much stock standard they will take off from mowed grass on their bellies pretty easily.
Teamsherman is offline Find More Posts by Teamsherman
Old Sep 26, 2014, 07:27 AM
Joined Sep 2014
Thanks for the suggestion Teamsherman....it looks like a good plane to learn on...will check it out...and the price is good too...seems easy to repair too :-)
Old Sep 26, 2014, 07:45 AM
twang is offline
Find More Posts by twang
twang's Avatar
Australia, QLD, King Scrub
Joined Jun 2005
Join a club
twang is offline Find More Posts by twang
Old Sep 26, 2014, 08:01 AM
NOI53Y is offline
Find More Posts by NOI53Y
Australia, ACT, Canberra
Joined Dec 2011
Yep. What he said.
NOI53Y is offline Find More Posts by NOI53Y
Discussion Anyone else seen this plane? joker24458 3D Foamies 28 Nov 22, 2013 10:12 PM
Discussion Has anyone else lost connection with their BCX2 while flying? wolfspirit Coaxial Helicopters 4 Jan 14, 2009 07:32 PM
Discussion Anyone else been staying up way too late building planes? E-flight planes everywhere! cryhavoc38 Electric Plane Talk 25 May 04, 2007 10:49 PM
Discussion First real flight and lost the plane. gixxer Beginner Training Area (Aircraft-Electric) 10 Jun 27, 2006 04:13 AM
Lost plane in Trees first flight Help Penguinman Parkflyers 31 Aug 11, 2004 06:29 AM
