Old Aug 09, 2015, 11:46 PM
hiljoball is offline
Find More Posts by hiljoball
hiljoball's Avatar
Canada, BC, Strathcona
Joined Jul 2011
Originally Posted by Scratchy101 View Post
What would be the point, unless that other competitor had something to gain?
Within what timeframe must a protest be lodged after the incident?
For that matter, can a protest even be lodged after the race?
If so, how would the infractor be penalized?
Unless there was video footage to prove the infraction, I don't see this being a viable option.
The time frame for notifying the Race Committee of a protest is set in Appendix E 6.5 as 10 minutes after the last boat finishes. Frequently that is modified by the regatta Sailing Instructions to either 5 minutes or even 2 minutes.
A protest may be lodged after the heat has finished - but that is different from hailing Protest at the time of the incident.
For a breach of a rule of Part 2 (when boats meet), or hitting a mark R 31, the protest hail must be at the time of the incident. However for a boat failing to sail the course correctly R 28, the hail may be done at the finish line after the boat has finished.
Just because a boat is protested does not mean that they will be found at fault. However after a Protest hearing, a boat that is a party to the hearing may be DSQ unless it is shown that they took an alternative penalty at the time of the incident.
John
hiljoball is offline Find More Posts by hiljoball
Old Aug 11, 2015, 12:53 AM
Scratchy101 is offline
Find More Posts by Scratchy101
Scratchy101's Avatar
Canada, BC, Greater Vancouver Regional District
Joined Dec 2011
A point of view about sail racing protest
I think this is a great way to finish off this discussion before the next RRS question arises:
http://wvrcm.tripod.com/protestpov.html
Rowland makes some very good points about protests and how to go about them in a non-antagonistic way.
Scratchy101 is offline Find More Posts by Scratchy101
Old Aug 11, 2015, 01:13 AM
wyldrydes2 is offline
Find More Posts by wyldrydes2
United States, CA, Oakland
Joined Apr 2012
dump the ad
This looks to be an excellent article about protests. That said, I protest the Bud Light advertisement stuck to the bottom of the page.
For this reader, it is inappropriate and irratating having to navigate around beer to read about protests. I did searched for the ususal "x" to delete but couldn't locate it.
wyldrydes2 is offline Find More Posts by wyldrydes2
Old Aug 11, 2015, 07:10 PM
bbbp is online now
Find More Posts by bbbp
a.k.a. Bob Parks
Glendale, AZ
Joined Jun 2008
These new pop up ads have the real X way off in the right margin and somewhat ghosted out. Had one from Sears yesterday that was driving me to never shop there again!
BP
bbbp is online now Find More Posts by bbbp
Old Aug 12, 2015, 06:43 AM
huzway is offline
Find More Posts by huzway
huzway's Avatar
United States, MD, Silver Spring
Joined Feb 2009
Try this for unwanted ad's
Wondered what you were talking about, no ads for me then I remembered I have this
I use it on Firefox. free and works great.
https://adblockplus.org/
Craig
huzway is offline Find More Posts by huzway
Old Aug 12, 2015, 09:18 AM
Earl Boebert is offline
Find More Posts by Earl Boebert
Joined Mar 2007
The other thing about the ad feeds is that malware writers are submitting ads to the feed that try and induce you to load their junk. The most common one lately is a window that tells you that your Flash version is out of date and you should click a button to update it.
Don't.
It's a cute scam because different people get different ads depending on the profile the ad feed has for you.
Cheers,
Earl
Earl Boebert is offline Find More Posts by Earl Boebert
Old Aug 12, 2015, 02:39 PM
huzway is offline
huzway's Avatar
Joined Feb 2009
Cheers,
Earl
What's that say about the guy that got the Budweiser ad....
Old Aug 12, 2015, 11:55 PM
Joined Apr 2012
Note about scammer(s)-Re Bud Light Ad….. My last alcoholic beverage was 1986.
Either this dude is old, or his IQ is approaching double digits.
Ha!
LMAO
Old Aug 13, 2015, 02:35 AM
genghiskt is online now
Find More Posts by genghiskt
genghiskt's Avatar
Joined Sep 2011
Hi John,
At P3, the yellow boat mast hook onto the blue mast, is blue at fault?
genghiskt is online now Find More Posts by genghiskt
Old Aug 13, 2015, 06:38 AM
tarmstro is online now
Find More Posts by tarmstro
RC Newbie with lots of ideas
Chile, Santiago Metropolitan Region, Stgo
Joined Dec 2012
Originally Posted by genghiskt View Post
Hi John,
Yes. Green was on starboard and Blue on port. Blue has to keep clear of Green. Blue's decision to gibe in front of Green was a very bad one!
tarmstro is online now Find More Posts by tarmstro
Old Aug 14, 2015, 12:13 AM
Joined Dec 2011
Here's another scenario using the example above.
Both boats are on starboard approaching the mark.
Once blue rounds the mark, let's say she does not gybe, but stays on starboard tack (wing on wing) when the collision occurs.
Since blue is the windward boat, so does that mean she must keep clear of the boats sailing upwind if they are both on the same tack based on rule 11?
11 ON THE SAME TACK, OVERLAPPED
When boats are on the same tack and overlapped, a windward boat
shall keep clear of a leeward boat.
Old Aug 14, 2015, 08:43 AM
hiljoball's Avatar
Joined Jul 2011
Yes. R11 applies.
Old Aug 29, 2015, 03:14 PM
FoamCrusher is offline
Find More Posts by FoamCrusher
If it floats....sail it!
FoamCrusher's Avatar
Elk Grove, CA
Joined Sep 2002
Starting question -
Situation: 40 seconds to start. Blue and Yellow approach from below the line, Yellow on port tack, Blue on starboard. Both go head to wind at about 30 seconds before the gun and then begin drifting toward each other while both remain head to wind.
At location 6 they bump beams. Neither has sufficient rudder response to avoid the collision. Does the last heading, even though it was some time before the contact, determine their course for the purpose of determining who has right of way, so Yellow is at fault?
And yes, blue should have fallen off to remain on starboard so as to defend his "space", but he didn't.
FoamCrusher is offline Find More Posts by FoamCrusher
Old Aug 29, 2015, 03:27 PM
Psychosis is offline
Find More Posts by Psychosis
Joined Jul 2011
From foam crusher
''And yes, blue should have fallen off to remain on starboard so as to defend his "space", but he didn't. ''
Blue did remain on starboard as at no time did she go beyond head to wind (a tack).
Similarly yellow remained on port the whole time.
So as long as blue didnt alter course and prevent yellow from keeping clear then yellow is in the wrong (port and starboard.
Psychosis is offline Find More Posts by Psychosis
Discussion Question about the Brushless 2226/2300 KV Easysky motor question (dolphin/cessna) twincobra Micro Ready-to-Fly 0 Feb 11, 2013 12:49 AM
Discussion AMA ALES Rules Question Roger Rocket Electric Competition Soaring-F5J/ALES/e-Soaring 7 Feb 01, 2013 04:33 PM
Discussion I know, I know stupid question about about World Tech Hercules Helo drtuvoc Coaxial Helicopters 1 Jan 26, 2013 08:40 PM
Discussion question about this sail plane munen123 Electric Sailplanes 8 Dec 29, 2006 04:52 AM
