Old Oct 15, 2015, 02:33 PM
335driver is offline
Find More Posts by 335driver
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Build Log
depron Bandit
Here's a couple of pics of my unfinished as yet, Bandit. Made with Depron 6mm and hot glued together, a FG arrow shaft for spar. Using a Freewing 70mm 6 blade fan, 60A Plush ESC & 3000mAh 30C battery. Servos are ones I had on hand, just a few more hours of work and we'll be ready to give it a try. Probably will fly it unpainted first.
335driver is offline Find More Posts by 335driver
Old Oct 17, 2015, 01:31 PM
Ed Waldrep is offline
Find More Posts by Ed Waldrep
Ed Waldrep's Avatar
Las Vegas, NV
Joined Dec 1996
With higher power setups mine would start to roll this or that way probably because of the wing in front of the spar twisting at higher speeds. Heck it even did it with lower power setups in a dive. I'd add a balsa leading edge if I built another one (still have the original but hasn't flown in years) to stiffen the wing, or hotwire a blue foam airfoiled wing.
Ed Waldrep is offline Find More Posts by Ed Waldrep
Old Oct 18, 2015, 11:56 PM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Thanks for the heads-up, Ed. Perhaps, I'll add a 3mm top skin to the wing from LE to where the ailerons get cut out or as you suggest a hard LE.
Old Nov 05, 2015, 02:25 PM
335driver's Avatar
USA, TX, Round Rock
Joined Dec 2006
Maidened this airplane the other day, no wind and test pilot had a bit of a time getting up to speed. Not the best hand launch either as it is hard for me to run, bad knees and all.
Once up to speed tho' flew well, did not notice any rolling that was not planned, Ed. I used some HD clear tape on leading edges of wing & stab. Don't know seemed to fly well both hi & lo speed and landed easily all be it a little fast. Going to put a hook on the bottom, so I can bungee launch it.
All in all, pretty decent airplane.
Thinking of trying a Depron F-100 next.
For Sale PA iPA pro Bandit with bling package crispypilot Aircraft - Electric - Airplanes (FS/W) 0 Apr 26, 2015 09:20 AM
Wanted Bandit ARF MK1 / Super Bandit Wings PANTHERFLYR Aircraft - Fuel - Jets (FS/W) 0 Oct 29, 2014 12:29 PM
Build Log New Bandit Depron jackdb Pusher Prop Jet Models 10 Oct 30, 2007 08:43 AM
Bandit or Hawk balsa/depron plans wanted testpilot Electric Ducted Fan Jet Talk 5 Jan 17, 2005 02:24 AM
Depron Bandit Jensst Foamies (Kits) 1 Feb 12, 2002 05:53 AM
