Old Aug 03, 2011, 11:45 AM
bluffman is offline
Find More Posts by bluffman
bluffman's Avatar
Joined Sep 2003
Rodent R10
I am in a plane building mode. I got a R10 from john higgins, a week ago, and decided to knock it out fast, so far i bagged the wings with 1/64th plywood, then i bagged them with inside layer of 6oz cloth then 7.8oz carbon then 2oz cloth on the outside, each wing weighs in at 12.4oz. i also made the horizontal stabalizer with a 1/64th ply inside core with the slot cut out for the easy hindges, i shaped it and bagged it with two layers 2oz cloth on top and on the bottom one layer of carbon and one layer of 2oz cloth, i would of put carbon on the top but it would have hidden my hindge line. So far the plane weighs 48oz. Ian
bluffman is offline Find More Posts by bluffman
Old Aug 03, 2011, 01:59 PM
BillO is online now
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Looking good Ian! Sure wish I could knock out something fast -- I'm one of those slooow builders...
BillO is online now Find More Posts by BillO
Old Aug 03, 2011, 02:26 PM
slopemeno is online now
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
I like that 1/64" core on the tails technique. It really makes for a beefy tail that doesn't easily ding.
slopemeno is online now Find More Posts by slopemeno
Old Aug 03, 2011, 05:31 PM
bluffman is offline
bluffman's Avatar
Joined Sep 2003
It gives it a core strengh and it only weighs 2oz not bad for a beefy tail where weight is not a factor, thanks bill i am not reinventing the wheel on these just building a kit plane, so they can go pretty quick, the paint job will be the lingest part.
Old Aug 03, 2011, 08:16 PM
slopeiron is offline
Find More Posts by slopeiron
No fuse too fat
slopeiron's Avatar
USA, CA, Redondo Beach
Joined Apr 2002
It'll never fly. Black wings are the worse, man. Very nonaerodynamic. Something to do with the way the sun rays bounce off of them and push them toward the ground.
slopeiron is offline Find More Posts by slopeiron
Old Aug 03, 2011, 08:26 PM
bluffman is offline
bluffman's Avatar
Joined Sep 2003
I was going to paint them pink
Old Aug 03, 2011, 11:21 PM
SethPenery is offline
Find More Posts by SethPenery
SethPenery's Avatar
Eldorado CA
Joined May 2010
I have a fetish for black pointy planes...... they look faster.
SethPenery is offline Find More Posts by SethPenery
Old Aug 03, 2011, 11:59 PM
agarchitect is online now
Find More Posts by agarchitect
On the Go Fly List
agarchitect's Avatar
United States, CA, Concord
Joined Dec 2009
Looking good.
I just bagged a set of RODENT wings (my first in carbon) with a layer of uni carbon against the cores, then 5.7 carbon weave and then a layer of veil against the mylars. Much lighter than yours but when your carbon tears off at speed you will still have a bullet proof plywood wing Best to put the ballast IN the wing.
Are you going to use a hardwood leading edge? Sanded tips at 45 degrees with a sheet of ply? Two servos in the wing or one?
Adam
agarchitect is online now Find More Posts by agarchitect
Old Aug 04, 2011, 09:54 AM
bluffman is offline
bluffman's Avatar
Joined Sep 2003
I have a hardwood leading edge, my tips are square, I will be putting the ballast in the fuse, I have not decided how I am installing the lead yet. This is my third rodent and it will be the heaviest,
Old Aug 06, 2011, 01:18 AM
On the Go Fly List
Joined Dec 2009
By "ballast IN the wing" I meant that your heavy layup is built-in ballast; with the added benefit of extra strength.
Adam
Old Aug 19, 2011, 01:17 PM
bluffman is offline
bluffman's Avatar
Joined Sep 2003
Last night i cut off the ailerons, with the this cool tool i copied from Joe Manor.
Old Aug 19, 2011, 03:42 PM
ian hammerton is offline
Find More Posts by ian hammerton
indeskies
ian hammerton's Avatar
Flat Leicester
Joined Jun 2005
Looking good, keep the pics coming. Can`t get enough sled build threads.
Can you show a close up of the aileron cutting gadget, I couldn`t make the pic big enough to see it properly.
Thank`s,
Ian.
ian hammerton is offline Find More Posts by ian hammerton
Old Aug 19, 2011, 05:07 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
Looking good. I think I need an R10 for my next sled build.
davidjensen is offline Find More Posts by davidjensen
Old Aug 19, 2011, 09:59 PM
bluffman is offline
bluffman's Avatar
Joined Sep 2003
I will post picture tomorrow thanks
Old Aug 20, 2011, 06:46 PM
bluffman is offline
bluffman's Avatar
Joined Sep 2003
Here is my cutting tool, I took apart dremel hand tool extension and used a pieces of brass tubing for the bearings to sit in, drilled a hole so you can lock the diamond bit in it, gooped a small vacuum hose next to it to catch the carbon dust, the plastic part and allumium is a draw alliginment tool.
Sold Rodent Sloper " Kit " jhiggins Aircraft - Sailplanes (FS/W) 3 Jul 28, 2011 05:01 PM
Discussion Rodent - molded servo cover mohr41 Slope 15 Jun 29, 2011 04:54 PM
Sold R10 Sloper Kit jhiggins Aircraft - Sailplanes (FS/W) 4 Nov 13, 2010 03:01 PM
Sold R10 Sloper Kit jhiggins Aircraft - Sailplanes (FS/W) 1 Aug 11, 2010 10:23 PM
