Old Apr 22, 2013, 11:18 PM
If u aint 1st your last
Throttlejunkie's Avatar
Sydney, Australia
Joined Mar 2010
Nitro VMX/MM450 First run.
I took my nitro VMX/MM450 to the track for it's first run but it was too wet to run on the dirt so i decided to run it on the grass to test steering & suspension & see what it is going to go like & i am so impressed & pleased how good it performs, the stronger gyro force, soft tyres with inserts, oil forks, single pivot steering with damper & big bore shock in the rear it is so stable & smooth.
Nitro MM450 First Run (6 min 12 sec)
& some nude pics for Lukey & any other pervs
Throttlejunkie is offline Find More Posts by Throttlejunkie
Old Apr 22, 2013, 11:37 PM
never stop building
dragbikebam's Avatar
Memphis, TN USA
Joined Apr 2009
Awesome job mate, congratulations!..honestly thats the best running nitro dirt bike I have seen..just awesome!!!The control looks smooth and precise..Its so nice I had to watch it twice..
dragbikebam is offline Find More Posts by dragbikebam
Old Apr 23, 2013, 02:02 AM
Sydney, Australia
Joined Mar 2010
Thanks mate, it does work great & it was pretty easy to do once i had all the parts & it went together nicely, it is going to be a fun bike i can't wait to hit the dirt & see how it goes against my mates electric MM450.
Old Apr 23, 2013, 02:28 AM
Bastelpeter's Avatar
Joined Jun 2011
HI Throttle, nicely done! Quick question, what type of steering head have you used. Is this a multi link or single pivot head? You have the steering directly at the fork....
Cheers
Peter
Bastelpeter is offline Find More Posts by Bastelpeter
Old Apr 23, 2013, 02:35 AM
United Kingdom, Walsall
Joined Mar 2013
Most impressive!
I'll admit I'm not really a nitro fan but there's something about an rc bike with the sound of a 2 stroke engine that just seems 'right'.
Nice job!!
Syncro is offline Find More Posts by Syncro
Old Apr 23, 2013, 02:42 AM
Post Falls, ID United States
Joined Feb 2004
Bravo! Well done.
Did you retain the front end geometry or change it?
The forks, from the video, look stiff to me whats their set up?
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Apr 23, 2013, 03:05 AM
Sydney, Australia
Joined Mar 2010
Cheers
Peter
Thanks Peter, it is a single pivot steering set up, i made a neck from 3 pieces of alloy plate & drilled & tapped them & screwed them together & it has the VMX/MM450 steering stem mounted in it so the VMX/MM450 front end goes straight on & it still has the crash back system.
Old Apr 23, 2013, 03:08 AM
Sydney, Australia
Joined Mar 2010
Originally Posted by Syncro View Post
Most impressive!
Nice job!!
Thanks Syncro, you are right about the sound of a 2 stroke & there is no need for background music the nitro play's it's own.
Old Apr 23, 2013, 03:33 AM
Australia, QLD, Burua
Joined Jul 2012
Love it so cool like synchro said it just sounds right. Awesome job. Can't wait to see it hit the dirt.
chktm is offline Find More Posts by chktm
Sydney, Australia
Joined Mar 2010
Originally Posted by Chris Nicastro View Post
Bravo! Well done.
Thanks Chris, i kept the ARX rake at first as it comes from the mount point on the chassis but found with the axle behind the forks it looked like it did not have enough rake & looked funny so i gave it more rake & it seems to work well so far.
You have a good eye as they were stiff, i was just talking to Chris H about a fork binding issue when the wheel is mounted & slightly spreading the forks causing them to bind, but i have to say the VMX/MM parts have transformed this bike it is really nice to ride now.
Old Apr 23, 2013, 03:40 AM
Sydney, Australia
Joined Mar 2010
Cheers mate, should be hitting the dirt soon, i love the slow mo when it is 4 stroke.
Old Apr 23, 2013, 04:12 AM
Joined Jun 2011
thanks mate, pretty cool!
Old Apr 23, 2013, 06:49 AM
MY '75 CZ "FALTA REPLICA" 2010
TopDave's Avatar
Waterford, Michigan
Joined May 2006
TJ, The whole project is awesome and makes that ARX behave better than ever with the VMX fork and frame mods. +1 on the "SloMo Thumper" exhaust note!
TopDave is offline Find More Posts by TopDave
Old Apr 23, 2013, 10:21 AM
RC Dirt Bike Action
JohnnyMc's Avatar
California central coast
Joined Feb 2010
Ditto what everyone else said. Amazing work. You got skills! It would have been great just getting the bike converted but with the graphics and rider too...wow. I saw the video yesterday around 3pm my time but it later showed up as private. Seems to be working fine today though. Definately will put these up on the website hopefully tonight if I get the chance.
JohnnyMc is offline Find More Posts by JohnnyMc
Old Apr 23, 2013, 09:03 PM
Joined Feb 2004
Rake Angle: the VMX handles better with a slightly more steep rake angle than stock but the stock angle is good most of the time. RA will change stability and how fast the bike changes direction, more vertical = faster steering = less stable so there is a max limit.
The ARX also has a parallel link set up which projects the pivot point ahead of the bike in space. Because of this the rake angle and the steering arc are related. This is not like a conventional bike.
The VMX direct steering also projects a pivot point in space ahead of the bike but since the pivot point in stationary the rake angle is more conventional like a full scale bike. This makes the rake and trail figures good so its stable.
The forks have to be parallel so with a digital caliper measure the fork shafts at the seals and at the drop outs. This should be the same figure if not then they bind. Shim the axle as needed to get them paralllel and square. I made an option part set they sold that includes shims and a tougher axle shaft. You can copy that or buy one and it will help sort out and toughen up the front end.
If the forks are being spread then the tripple clamps could be off. Check them with a caliper to see the inner edge to edge distance is the same from one to the other.
You can do this with the forks installed just take a few measurements to compare.
Another trick you can do is use a thin sand paper with 220 grit and wrap a piece around the fork tube. Use this as a tool to hone the tripple clamp lightly. Take a few measurements after you do a pass and see.
Also, do a double check and make sure the fork shafts and tubes are not bent.
Finally, take the forks and blueprint them as mentioned before in the other threads. You will be able to put a bending load on them and have them work smoothly when this is done.
Now it will come down to tuning the front and rear suspension together and getting it to do what your looking for it to do. Fun project man keep it up, lts see some dirt and comparo vids soon!
Discussion Nitro ARX with e-gyro conversion first test run Throttlejunkie Motorcycles 55 Aug 16, 2012 12:35 AM
Discussion MM450 and VMX Fork Clinic Chris Nicastro Motorcycles 9 Jul 20, 2012 11:05 PM
Cool First test run Ricky Nitro Jena67 Motorcycles 12 Jun 18, 2006 07:39 PM
Rave The first run of my TT nitro on a lovely sunny day! GAZ NITRO Motorcycles 5 Aug 22, 2005 11:10 AM
