Old Jul 31, 2015, 10:46 AM
PsychoNhere is offline
Find More Posts by PsychoNhere
PsychoNhere's Avatar
United States, TX, Galveston
Joined Feb 2012
ESC works great!!!! However I'm having some type of interference with my 2.4 ghz Fly Sky. It use to not drop out after 200 yards. Wonders if i should move receiver to back of boat and maybe run part of antenna out of top and seal with silicone. Any thoughts?
PsychoNhere is offline Find More Posts by PsychoNhere
Old Jul 31, 2015, 11:04 AM
Sympster is offline
Find More Posts by Sympster
Louisville, KY
Joined Jun 2006
Try placing it to the back of the boat first and loop the antenna the best you can, away from the esc. If that doesn't work, do a quick dry test by running it out the water dump hole.
Sympster is offline Find More Posts by Sympster
Old Jul 31, 2015, 11:12 AM
Joined Feb 2012
What does looping the antenna mean? Circular rotations
Old Jul 31, 2015, 11:15 AM
Sympster is offline
Louisville, KY
Joined Jun 2006
Sorry, "route" the antenna
Old Aug 02, 2015, 03:02 AM
Superboater is offline
Find More Posts by Superboater
Joined Aug 2015
Hi!
Yesterday i purchased a FT009 to my son, during the first ride everything was working fine, big waves but the self-righting worked as intended.
Recharged the battery and during the second run the self-rightning doesn't seem to work, I'll try to give full reverse and full forward but it does not turn around.
I have opened the boat and looked at the solder joints but they seem to be fine.
Does anyone have any idea of what could be wrong? Am I doing something wrong? During the first run when the self-rightning worked fine i think it turn around automatically, I was just pulling full throttle forward the whole time, maybe the waves helped the boat to turn around
UPDATE: I have now done some testings and it looks like if the battery runs low there is not enough power for the self-rightning to work.
Superboater is offline Find More Posts by Superboater
Old Aug 04, 2015, 04:33 PM
Fredrik1 is offline
Find More Posts by Fredrik1
Joined Jul 2015
I have tested the boat now with Hpi 15T engine, and its the same speed compered to my sons original ft009.
Why is that?
Fredrik1 is offline Find More Posts by Fredrik1
Old Aug 04, 2015, 05:49 PM
Joined Feb 2012
Why is that?
Are you using the stock ESC?
Old Aug 09, 2015, 02:01 PM
Fredrik1 is offline
Joined Jul 2015
Yes stock esc.
Old Aug 09, 2015, 03:56 PM
microhelidude is online now
Find More Posts by microhelidude
microhelidude's Avatar
Joined Dec 2007
Had some fun last week with my FT009. I finally retired my brushless FT009 as I didn't want to spend $80 on an ESC and instead used that money to get a Barbwire Atomic XL!
My daughter had been nagging me for weeks to get the boats going again!
FT009 Boats Fun Chasing (2 min 29 sec)
microhelidude is online now Find More Posts by microhelidude
Old Aug 18, 2015, 06:31 PM
Joined Dec 2007
Man, does anybody still have a FT009?
Old Aug 18, 2015, 06:43 PM
Chinadevil is online now
Find More Posts by Chinadevil
United States, MD, Towson
Joined Apr 2013
Absolutely. And an FT-007 too. These are great boats. My FT009 has had hours of trouble free run time, and has never given me any problems at all.
Can't say the same for its faster brother, the FT012. Much faster, but with more issues too. I think the 009 power train is the ideal setup for this size boat.
Chinadevil is online now Find More Posts by Chinadevil
Old Aug 18, 2015, 10:21 PM
Joined Dec 2007
Sweet. I'm thinking of upgrading my green FT009 to the 14v Titan 21t motor. Its my wifeys and she complains its too slow. But I need another brushed esc and some more 3s 1000mah lipos which is about $50 bucks. My other FT009 has been really reliable on that same setup.
Old Aug 19, 2015, 11:38 AM
Windy Heap is offline
Find More Posts by Windy Heap
Windy Heap's Avatar
Joined Apr 2014
I've got 3 of the FT012's coming on the slow boat.
Describe your trimming of the boat, and what problems you've seen?
Wife and I love bashing our twin 009's, they're tough little buggers.
I think with the 012, you'll have to respect that the throttle isn't an on/off switch. Smooth is good. Can't wait to get all three out on a pond, hope they all bind tx/rx together.
Windy Heap is offline Find More Posts by Windy Heap
Old Aug 20, 2015, 08:53 AM
Joined Apr 2013
[QUOTE=Windy Heap;32464044]I've got 3 of the FT012's coming on the slow boat.
Probably the biggest issue reported has been leakage, mainly in earlier models and supposedly now corrected. My first one suffered the front bearing seizing issue, where the bearing overheats to the point that it melts the interior shaft mount assembly. Banggood sent replacement parts for the problem, and I have just gotten the boat ready to run again this weekend. I have also replaced the bearings with ceramic versions, which should help with the heat. Did the same with the second one I just received. Also ordered the TFL 432B prop, which should be great on the FT012.
Not too much you can do to trim this boat, other than try to adjust the turn fins. The trim tabs are plastic and not really adjustable. It really is a great little boat - much faster than the FT009 - and I hope to have lots of run time with mine this Fall.
Have fun with your new FT012s
Old Aug 28, 2015, 06:31 PM
Joined Feb 2012
Hey guys selling my Modded FT009 it is a BEAST check it out! Lots of Accessories
http://www.rcgroups.com/forums/showt...5#post32547747
Discussion Skywalker 2014 - 1800mm - FPVModel - Spanish Review Japanx FPV Aircraft 10 May 12, 2015 06:29 AM
Mini-Review Turbodrone Micro Quad review stallion explosi Multirotor Talk 0 Nov 22, 2013 08:27 AM
New Product Vitality H36's Brother Vitality H39 2.4G 4-axis RC Quadcopter With camera RTF Aaron qin Mini Multirotors 14 Sep 18, 2013 09:02 AM
