Old Mar 24, 2015, 11:38 PM
clive_fox is offline
Find More Posts by clive_fox
Australia, NSW, Sydney
Joined Jul 2002
Question
Servo current draw
Not sure if this is the right forum apologies in advance if not.
Assuming a constant air speed when using digital servos and the sticks on the TX are centered and not trimmed is the current draw minimized.
If the trims are used to stabilize/modify a flight path does this increase the current draw. If this is the case does re-centering the servo on the TX reduce the draw.
clive_fox is offline Find More Posts by clive_fox
Old Mar 25, 2015, 06:03 AM
davidmc36 is offline
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
This may give you some insight to current draw.
http://www.rcgroups.com/forums/showt...ighlight=servo
davidmc36 is offline Find More Posts by davidmc36
Old Mar 25, 2015, 07:28 AM
richard hanson is online now
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
IF the model flies hands off with no aerodynamic trim, the servo loads are only from holding position with no aerodynamic load .
so no power required at servo
That condition does not exist !
There is always some load
The more offset in trim surfaces - The greater the aerodynamic loading the servo must combat. So-- more power will be required to hold the position The tx setting is not relevant here .
The servo CENTER can be changed and there will be no load (except idle current) when the model is parked and if the trim surface is perfectly counterbalanced
However-- any load will require servo power -no matter where the servo center may be
Back when we were doing big aerobatic models- ailerons and elevators sometimes were so heavy, the surfaces would fall to low position when model was parked and power was off ! (not my models - I balanced the surfaces .)
these things sucked a lot of power - just pulling surfaces to center - then holding them there against the engine shake and airframe vibrations.
richard hanson is online now Find More Posts by richard hanson
Question Current draw of vtx... clonedkorl FPV Equipment 1 Oct 23, 2014 04:49 AM
Discussion Servo Current Draw Rich in ILM Electric Plane Talk 8 Mar 07, 2014 02:24 AM
Discussion Servo Current Draw with Pull Spring set up MikeHLG Hand Launch 8 Dec 08, 2013 05:06 PM
Discussion static current draw vs in flight current draw myp Power Systems 1 Nov 05, 2007 04:04 PM
