Old Jul 10, 2014, 08:46 PM
New Zealand, Auckland
Joined Jan 2013
Lipo C rating formula
OKay : saw this formula and now think I have it sorted, please confirm one way or the other
11.1 volt 2000mAh -10C
2000 milliamps = 2 amps
2 Amps x 10 = 20 amps continuous discharge
So therefore if I have a motor that draws 50 amps then I should have a battery witha C rate of 25 or more
ie 3300mah 20/30 C
As you will probably gather I dont know alot about electricity but still find it intresting
Crusty One is online now Find More Posts by Crusty One
Old Jul 10, 2014, 09:27 PM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Most C rating are marketing hype and thus if you really need 20C continious it is best to get atleast 30c if not40C. Also realize that a true 30C discharge rate means less than a 2 min. flight.A 10C average discharge rate equals a 6 min . flight but as you should only use 80% of the capacity closer to 5 min. flight.
everydayflyer is online now Find More Posts by everydayflyer
Old Jul 10, 2014, 10:30 PM
Joined Oct 2009
There is no formula as some 25C lipo's will outperform 45-90C ones.
Also some 20 or 25C packs will perform ok and deliver their rated current for the few cycles, but then quickly drop off shortly thereafter..
Best thing to do is to research and find a high quality long-lasting lipo.
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Jul 11, 2014, 03:13 AM
Staffs, UK
Joined Nov 2003
ie 3300mah 20/30 C
Your calculation is basically correct and I think you understand what you're getting. But just to be clear, it doesn't mean you need a C-rate of 25 or more to get 50A because it also depends on the size of the battery.
3300mAh at 20C would be good for 3.3 x 20 = 66A
5000mAh at 15C would be good for 5 x 15 = 75A etc
That's assuming you can depend on the vendor's C-rating which as already said is a bit debatable.
Steve
slipstick is online now Find More Posts by slipstick
Old Jul 11, 2014, 08:26 AM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
And, operating a pack at it's "advertised" C-rate greatly decreases the cycle life. If it's just to cover full throttle bursts you are probably OK with your calculation, which by the way is right on the money. It's the Manufacturers C-rating that is in question, not your calculations.
hoppy is offline Find More Posts by hoppy
Old Jul 11, 2014, 12:26 PM
Joined Oct 2009
Originally Posted by hoppy View Post
And, operating a pack at it's "advertised" C-rate greatly decreases the cycle life..
Do you have any data to back that up?
I have some Gens Ace 25C packs that I regularly run over their rated output and they are holding up better than other much higher rated packs.
I think what the point here is (and it's been made several times in other threads), you cannot make any hard and fast calculations of what a lipo can deliver based on it's packaging.
ie: A 3000mah 40C labelled packed is not guaranteed to give you 120Amps sustained.
Old Jul 11, 2014, 12:39 PM
Southern Pride
Even if a LiPoly is rated 25C and can be dischrged at 25C without kiling it right away it still will hae have it's ife reduced cmpared to what it would have done i fs chargeat ony say 15C. Most like to get more than minute flights thus in fact discharge ther LiPolys at less 15C aveage dischage rate.
Here is a post where I discharged a 3S 50C 2200 at up to 110Amps. , it did not die right away and during a flight which was discharge #64 I forgot I was fying a 2200 in an aircraft I normaly flew a 3300 in and discharged it to less than 10V resting and it still lasted over 100 flights .
http://www.rcgroups.com/forums/showp...0&postcount=47
Old Jul 11, 2014, 02:06 PM
United States, WA, Woodinville
Joined May 2014
As with most of this Chinese stuff, specs tend to be pulled out of thin air and have little relation to the actual capabilities of the product. I've seen the exact same item advertised by different sellers with different specs at times.
That's why you want to be fairly conservative with the C rating. I usually like to get double what the actual max draw will be. Also for high amp draw planes it's a good idea to get reputable brand packs with honest ratings when you can find them.
James_S is offline Find More Posts by James_S
Old Jul 11, 2014, 02:20 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
See Discharge Current Rate paragraph, page 7 here.
Hyperion stated that packs operated at the max continuous rate would yield 50 cycles or less.
An older report on discharge rate vs cycle life. http://www.researchgate.net/profile/...11eaf53c3d.pdf
Some anecdotal evidence from the electric vehicle forum - http://endless-sphere.com/forums/vie...p?f=14&t=34239
See item 6. here.
Check the temp/capacity/cycle chart here. If you agree with me that higher discharge rates create higher pack temperatures you can see how the capacity losses are related to pack temperature and subsequently cycle life.
Old Jul 11, 2014, 02:38 PM
A man with too many toys
United States
Joined Feb 2001
ie 3300mah 20/30 C
The true C of a LiPo can be calculated.
1. Use the discharge calculator to get the max discharge current. http://www.jj604.com/LiPoTool/
2. Then divide the max discharge current by the capacity in amp hours.
I have used my Power Lab to measure IR of my new packs and the computed C comes very close to the advertised C. This was for some 25C and 35C packs that I got from hobby king. I have not tried it on and very high C packs.
This is very useful because it tells you how much you can safely draw from an old pack that has lost some of its punch.
RC Man is online now Find More Posts by RC Man
Discussion Where To Buy Light Weight Loose High C Rated Lipo Cells akfreak Indoor Pattern/F3P 2 Mar 11, 2014 06:04 AM
Question Lipo C Rating mismatch Alan2006 Electric Power Cars 5 Jan 22, 2014 07:38 PM
Wanted 850mAh 4S HI C RATING Lipo Pack rghol5212 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Dec 02, 2013 09:02 PM
Discussion Lipo C-ratings puzzle: what's most important, C-rating or mAh capacity?? Merlin45 Batteries and Chargers 18 Apr 03, 2010 04:45 PM
Question What is the formula for lipo discharge amps? C ratings and such? skid_68 Batteries and Chargers 6 Nov 10, 2005 08:10 AM
