Old Feb 25, 2015, 09:52 PM
iflyrc4333 is offline
Find More Posts by iflyrc4333
iflyrc4333's Avatar
USA, NY, Tyrone
Joined Sep 2007
Fiberglassing with Polyurethane??
a while ago I saw a post someplace ( unfortunately Im Not sure where ) that had links to you tube videos showing how to use polyurethane with fiberglass .. hopefully someone with remember it and point me to it ??
Thanks !
iflyrc4333 is offline Find More Posts by iflyrc4333
Old Feb 26, 2015, 04:56 PM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I just glassed an airframe with polyurethane. It's basically the same as if you use polycrylic or epoxy finishing resin.
Is there anything that I can help you with ? Sorry, I have no You Tube links.
TomCrump is offline Find More Posts by TomCrump
Old Apr 14, 2015, 04:10 AM
Pukin_Dog is offline
Find More Posts by Pukin_Dog
┼tvidaberg, Sweden
Joined Jul 2008
Polyurethane...
It dries quickly.
It's much cheaper.
It smells real strong.
You can't use foam as a plug to cover, it will melt unless you protect the foam in some way.
Pukin_Dog is offline Find More Posts by Pukin_Dog
Old Apr 14, 2015, 08:20 AM
kwblake is offline
Find More Posts by kwblake
Canada, MB, Gunton
Joined Jan 2014
I have no links either, but I just went to You-Tube and did a search. There are a ton of videos there.
kwblake is offline Find More Posts by kwblake
Old Apr 27, 2015, 11:12 AM
orbsah is offline
Find More Posts by orbsah
United States, RI, Cumberland
Joined Dec 2010
I use this and it works great:
http://www3.towerhobbies.com/cgi-bin...&I=LXCX58&P=ML
orbsah is offline Find More Posts by orbsah
Old Apr 27, 2015, 02:58 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
What are the advantages of using this instead of the customary low viscosity epoxy laminating resin?
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Apr 27, 2015, 03:35 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
The polyurethane is one part, and therefore you use only what you need. There is no worry about mixing too much and having waste material to dispose of.
If cost is a concern, the polyurethane is less expensive.
Old Apr 27, 2015, 04:04 PM
┼tvidaberg, Sweden
Joined Jul 2008
polyurethane that I have encountered for laminating is always two parts. Used for boats and that stuff. Or is that another thing? It's called Polyester here and that is nasty stuff to work with.
Old Apr 27, 2015, 04:18 PM
Joined Aug 2008
Originally Posted by Pukin_Dog View Post
.........................It's called Polyester here and that is nasty stuff to work with.
No. Polyester resin is a completely different product. It is used traditionally for general fibreglass production. Sometimes used for model aircraft moulds, but inferior to epoxy resin in some terms.
Not in my part of the world at least:
http://www.bunnings.com.au/cabots-4l...rnish_p1522326
In comparison, a similar quantity of the best low viscosity epoxy laminating resin I can obtain costs less. Courier charges to my locality makes it a bit more expensive.
Not worth compromising in my situation; besides, I would have to stock yet another product with it's tendency to go off once opened. I know it can be decanted into smaller tins and jars etc.
Old Apr 27, 2015, 04:32 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
I am not referring to the waterborne product. I'm referring to this, oil based product. http://www.walmart.com/ip/17300053?w...392751&veh=sem
32 fluid ounces goes for around $20.. while the epoxy finishing resin is $15.00 for 12 ounces.
I gave up on the waterborne polys, preferring finishing resin or the oil based polyurethane.
Old Apr 27, 2015, 04:58 PM
Joined Aug 2008
Yes Tom. The solvent based (oil type) product is less than half the price here in Australia: http://www.bunnings.com.au/british-p...thane_p1409605
I can see that it has a place in our range of options for building models.
Strength comparison?
Old Apr 27, 2015, 06:17 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
I don't know about strength. I glass a model to provide a stable surface for finishing. Strength is not on my priority list.
Ding resistance is, though. The oil based poly has adequate ding resistance. It seems to hold up under normal treatment.
Old Apr 28, 2015, 03:31 AM
┼tvidaberg, Sweden
Joined Jul 2008
Ok, I see. Then I have thought about a completely different product.
But i the Polyurethane that good really? I have tried the water based and I only use it to protect the foam before using paint that will otherwise melt it.
Old Apr 28, 2015, 08:11 AM
Glacier Girl is online now
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
You have to be careful as to what's under the poly. I melted an EFlite Super Airliner using oil based poly on it. Was not a happy camper.
On the other hand, I found out using water based poly and simple paper makes a pretty strong coating, granted not as tough as fiberglass. My third Airliner had a Castle BEC fail right after take off. Resulted in a wing first, nose second, multiple cartwheel.
Bent the one wing tip down 45 degrees,ripped one nacelle completely off, and the fuselage has several compression marks and two minor cracks where the poly/paper broke. Had it not been there this would have been a garbage bag retrieval.
Glacier Girl is online now Find More Posts by Glacier Girl
Question Can I mix Minwax Polyurethane with Minwax Polycrylic? djacob7 Foamies (Scratchbuilt) 1 Jul 25, 2014 06:08 AM
Question Water Based Polyurethane and Fiberglass for wing joiner. rail.bird The Builders Workshop 26 Aug 03, 2010 01:54 AM
Fiberglass with Polycrylic or Polyurethane on Balsa? tnavressdog The Builders Workshop 5 May 01, 2004 10:33 PM
Sheeting with Polyurethane Glue mattg Slope 9 Sep 05, 2003 07:42 AM
Water-base PolyUrethane vs Epoxy for fiberglass Balin Electric Plane Talk 2 Oct 24, 2002 08:32 PM
