Old Feb 16, 2011, 09:02 PM
United States, CA, Ukiah
Joined Jan 2011
spektrum dx6i and dx7 transmission range
I haven't been able to get a solid number as to how far the spektrum signal will carry, so a friend and I tested out our planes -- on the ground -- to see how far we could go, checking it at regular distances and different plane orientations.
setup 1 -- spektrum 7000 rx w/ satellite rx, dx7 tx with lipo batteries.
setup 2 -- spektrum 6100e rx, dx6i tx w/ nimh batteries.
Setup 1 worked perfectly regardless of orientation at .5, .75, .85 miles (800m, 1200m, 1400m)
Setup 2 was good at .5 miles/800m ; good at .75 miles/1200m as long as the plane was not straight up or straight down; and good at .85 miles/1400m only if the transmitter was facing towards the plane.
I'm inclined to think the 7000 receiver made the difference, but I want to try the dx6i with alkalines to see if that changes things any on the transmitter side, or try binding both planes to one tx. Anyone have experience with this?
devinvagt is offline Find More Posts by devinvagt
Old Feb 16, 2011, 09:04 PM
beginner4life's Avatar
United States, MD, Ellicott City
Joined Mar 2008
Just flew to 1000m (1Km) earlier today on DX6i with alkalines and AR7000. Didnt experience a lockout i just got nervous
beginner4life is offline Find More Posts by beginner4life
Old Feb 16, 2011, 09:11 PM
Why is the Rum gone?
sim_io's Avatar
USA, GA, Savannah
Joined Mar 2008
Do range checks with your fpv gear turned on. Depending where the video tx it may limit your range. I've seen Dx6is getting lockouts 600m out with fpv. I'm not an expert with spektrum but I think people in the forum use 2.4Ghz boosters.
sim_io is offline Find More Posts by sim_io
Old Feb 16, 2011, 10:21 PM
Registered Loser :)
mark hitchman's Avatar
New Zealand
Joined Sep 2009
Check out this post for some range tests, not exactly what you want but still interesting.
http://www.rcgroups.com/forums/showt...ht=ar7000+test
Mark
mark hitchman is offline Find More Posts by mark hitchman
Old Feb 17, 2011, 02:50 PM
Joined Jan 2011
Yeah, good idea. That will be my next step. I really want to know whether it's the TX or RX that is creating that difference in control distance, although I suspect it's the RX since transmission power is capped in the US at a certain power (200mw or something like that).
Found Wanted - Spektrum DX6i or DX7 Transmitter Sparkorama Aircraft - General - Radio Equipment (FS/W) 7 Jan 27, 2011 09:26 AM
Found WANTED: Spektrum DX7 or DX6I fly Frontier Aircraft - General - Radio Equipment (FS/W) 2 Dec 12, 2010 08:44 PM
Discussion Range on Spektrum DX7 Jon M FPV Talk 9 Dec 07, 2010 05:54 PM
Discussion DX7 SETUP FOR BELT HELI using a Spektrum DX6i transmitter oomodel.com Radios 1 Sep 02, 2010 01:45 PM
Discussion Spektrum claims the DX7 has full range....does anyone know the actual range in ft? TheFlyingAce Radios 42 May 31, 2008 02:04 PM
