Espritmodel.com Heli Air
Old Oct 03, 2012, 11:05 AM
Romania, Bucharest
Joined Jul 2012
AXI 2814/22 Droidworx Problem or NO ?
Hello.
I own a Octo XL Droidworx V3
Specs:
1xFrame Droidworx AD-8HL extended
1xBig Droidworx pipes, 465 mm. HL version
1xPhotoHiger Camera Mount AV-200 Pro
1xExtended landing gear for AD-8HL
2xTurnigy 5000mAh 4S 30C Lipo Pack
Mikrokopter electronic ( FC, Navi, GPS, Bl )
The motors i use are: 8pcs of AXI 2814/22 MikroKopter special motor ( http://mikrokopter.altigator.com/axi...otor-p-58.html )
The total weight of drone including camera is 5600gr ( 5.6 kg )
Can the motors pull this weight or it is overload and i will burn motors ?
Please help, i want to know if i have to change the motors.
Thank you!
inluv is offline Find More Posts by inluv
Old Oct 04, 2012, 12:30 AM
Romania, Bucharest
Joined Jul 2012
Can anyone help please?
Old Oct 04, 2012, 12:56 AM
Joined Dec 2011
yes it most likley can if you use apc sf 13x4.7 etc.
have you tried using this calc over here ? http://www.ecalc.ch/xcoptercalc_e.htm
coachbird is offline Find More Posts by coachbird
Old Oct 04, 2012, 02:05 AM
Romania, Bucharest
Joined Jul 2012
Hello,
When i use ecalc.ch i get error if i put 2xTurnigy 5000mAh 4S in parallel. If i put 1xLiPo of 10000mAh works fine.
What is the problem ?
I don-t trust this calculator I just want to know if someone uses this motors on octo to pull up this weight or more ( 5.6 kg )
Thank you!
Old Oct 05, 2012, 12:05 AM
Romania, Bucharest
Joined Jul 2012
Could anyone help ? :-s
What-s the problem ?
Old Oct 07, 2012, 11:27 AM
Romania, Bucharest
Joined Jul 2012
Any help ?
Old Oct 10, 2012, 06:43 PM
Joined Jul 2010
Originally Posted by inluv View Post
Any help ?
Hi there! Sorry - I just happen to stumble upon your message in some search - I am not usually active in this forum.
But while I'm here: in answer to your question... Totally perfect your setup. Optimum prop load for this engine (50% throttle) is 700 grams so this takes you exactly to the 5.6 AUW with 8 engines. Couldn't be better! You can lift more weight of course, but your load comes in perfectly on the sweet spot.
The 465mm booms are not stock standard - the standard 410mm booms with 12" props would have done well too and would have made the craft somewhat more compact. But people are getting great results on the longer booms as well and you can fit 13" props.
You have all the right components for a successful build - let us know how you go. If you have any further questions please contact us via email since I don't monitor this forum space... contact@droidworx.co.nz...
Thanks a lot and much success!
Regards,
Linda
droidworx is offline Find More Posts by droidworx
Old Oct 14, 2012, 12:37 AM
Romania, Bucharest
Joined Jul 2012
Thank you very much!
For Sale Axi 2814/22 elliott000 Aircraft - Electric - Multirotor (FS/W) 6 Sep 01, 2012 09:04 AM
For Sale 6 AXI 2814-22 Motors sycoelectric Aircraft - Electric - Multirotor (FS/W) 1 Aug 29, 2012 02:27 PM
Discussion I need some E clips for my axi 2814/22's... anyone know where to get em? elliott000 Multirotor Talk 1 Jul 27, 2012 06:24 PM
Sold *PriceDrop* Droidworx/Photohigher Quad/Hex/Octo/Y6/X8 + AXI 2814/22's + DJI Wookong-M Huddo Aircraft - Electric - Multirotor (FS/W) 8 Feb 10, 2012 03:55 PM
Discussion AP: Quad w Axi 2820/14 or Hex Axi 2814/22? glmccready Multirotor Talk 13 Nov 26, 2011 06:08 PM
