Old May 22, 2015, 03:32 AM
The Recursion is offline
Find More Posts by The Recursion
q {bld(); fly(); brk(); q();}
The Recursion's Avatar
Canada, ON, Mississauga
Joined May 2012
Cleanflight reminder - Set fail safe on your Receiver AND flight controller
I learned a valuable lesson today. On my 250mm quad, I only had fail safe setup on my D4R-II receiver (set to cut throttle) since I was planning on doing the flight controller (clean flight) after I got basic flight working. I never did. I've always relied on my receiver fail safe, so I wasn't too concerned.
After a crash today I blew off some dirt, replaced 2 props, did a hand thrust test of the quad, and took off again in FPV. Little did I know the crash almost completely severed my FC connection to my receiver. About 10 seconds into the flight I started to roll up, and lost control (the connection finally severed), rendering the aircraft out of control with my last inputs being present. I was extremely lucky in that I was slowly pitching up at the time, so I slowly saw the sky, then the ground. Once it crashed the motors remained spinning until I skillfully disconnected the battery while grabbing and flipping over the quad with the motors spinning full speed.
If I was in angle mode or flying directly forward|up, I cringe at the thought of what might have happened.
Lesson learned. Hopefully for you too.
feature failsafe
set failsafe_delay = 10
set failsafe_throttle = 1000
The Recursion is offline Find More Posts by The Recursion
Old May 22, 2015, 04:13 AM
Phantom604 is offline
Find More Posts by Phantom604
The Ground is the Limit
Phantom604's Avatar
Canada, BC, Vancouver
Joined Oct 2013
Good advice. Recent user of Naze32 and Cleanflight.
Remembering to set failsafe on Flight Controller. CHECK
Phantom604 is offline Find More Posts by Phantom604
Old May 22, 2015, 08:11 AM
waltr is offline
Find More Posts by waltr
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
Yep, I keep posting that reminder and this is the exact reason to Always enable the FS in the FC.
If the RX to FC disconnects it can be bye, bye copter.
Good your copter crashed instead of flying away.
waltr is offline Find More Posts by waltr
Old May 22, 2015, 09:36 AM
dvation is offline
Find More Posts by dvation
Joined Mar 2015
As a new flier, this is very helpful advice, thank you.
Time for the "new guy" question.
I see a few potential problem areas:
1. TX stops transmitting/working (TX battery dies, for example)
2. RX loses it's lock with TX (craft flies too far away, for example) or
3. RX stops sending TX input to the FC (RX breaks for whatever reason)
(any others?)
It seems to me that setting the failsafe in CleanFlight (or any FC) would help with #3 only (RX stops sending signals to FC), right?
In what scenario does the TX failsafe come in? And is there any protection against scenario #2?
dvation is offline Find More Posts by dvation
Old May 22, 2015, 10:25 AM
waltr is offline
Team WarpSquad
Joined Jan 2014
For #2 to activate the FC's FS you must ensure the RX outputs NO PULSEs (or pulses that are outside the FS pulse threshold limits) on loss of the TX signal.
You must refer to your Radio RX's manual to learn how to set it up to do this. and then TEST to ensure to actually works as you expect.
#4- The power to the RX drops out.
#5- A wire or wires between the RX and FC break or disconnect.
For these the FC must have FS enabled.
If the FS is not enabled in the FC and the RX is disconnected/powered off, then the FC HOLDs the last good values from the RX. If this is full throttle then it holds full throttle until the battery dies even it it crashes or hits something/someone.
Old May 22, 2015, 10:42 AM
Joined May 2012
My method is that the Receiver should handle the fail safe if the transmitter loses connection. With the D4R-II you put the sticks/switches into the spots you want them (in this case, zero throttle and centred), then push the FS button to set. Others may differ but the concept should be the same. You can test this by turning off the receiver with the motors spinning (without props). This was all I had setup, and would really be 99% of the situations you'll likely run into (1-2).
For the cleanflight configuration, the full details including testing can be found here: https://github.com/cleanflight/clean...cs/Failsafe.md
Basically the concept is that if pulses are not sent from the receiver to the flight controller, it'll trigger fail safe. In the configuration I posted above if the FC doesn't see pulses for a second it'll shut the motors off.
Careful! SOLVED how to set the fail safe on hobbyking car radio transmitter TheLeabres HobbyKing 2 Feb 25, 2015 04:33 PM
Discussion Flight Controller firmware with position hold on fail safe? hcker2000 Multirotor Talk 4 May 02, 2014 09:42 AM
Discussion Best "fail-safe" receiver settings Soar-on Sailplane Talk 6 Jun 10, 2008 09:10 PM
Discussion What are the correct Fail/Safe settings for the rx on my DLG? roybe Hand Launch 2 Nov 14, 2007 07:00 PM
Discussion What's the common consensus on rx Fail Safe settings? Mochaboy Micro Helis 12 Jan 08, 2007 05:45 PM
