Old May 10, 2015, 03:42 PM
Bmurry226 is offline
Find More Posts by Bmurry226
Joined Apr 2015
Parkmaster 3d hinge gap HELP!
Building my first foamie (Parkmaster 3d) and I'm to the part where I need to start attaching the ailerons, rudder, and elevator but I don't see anywhere how large the gaps in the hinges should be. Also, when glueing the hinges in, do I put glue on the hinge then stick it in, or stick the hinge in first then just glue around it?
Bmurry226 is offline Find More Posts by Bmurry226
Old May 10, 2015, 04:02 PM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
Joined Nov 2014
The gap should be as little as possible and still have movement.
Put the hinges in and install the control surface, then put a couple drops in each hinge and
do both sides. Make sure the ends are lined up before gluing.
BHOFM is offline Find More Posts by BHOFM
Sold Multiplex Parkmaster 3D ltrfred Aircraft - Electric - Airplanes (FS/W) 5 Jan 12, 2015 11:32 PM
Question Steigeisen hinge gap seal: repair or just remove?? Bodywerks Hand Launch 8 Jun 27, 2014 11:04 PM
Discussion Gap Filling CA In Hinges SIKrandall Balsa Builders 7 Feb 28, 2014 12:36 PM
