Old Nov 09, 2014, 10:59 PM
Australia, QLD, Burua
Joined Jul 2012
Originally Posted by Helicoy View Post
How do you lock the legs of the rider on his steps ?
Glue ? all the times the legs goes out of their lock ball .
I never had an issue with the std footpegs holding the feet although I did break one. I found these from Hobbyking for the QRF to be a really tight fit to get his feet on so should be better at holding them in position, you will need longer screws to hold these pegs. I bought some of the springs to try also and am using the longer orange one now with the std shock.
chktm is online now Find More Posts by chktm
Latest blog entry: More bike fun
Old Nov 10, 2014, 02:39 AM
AYP
AYP's Avatar
france
Joined Nov 2010
Bonjour.
Avec un pilote articulé,un support fendu de quad HPI sur une tige fileté M3 ŕ l'emplacement d'origine.
Hello.
With a hinged driver, supporting quad split HPI on a threaded rod M3 at the original location.
AYP is offline Find More Posts by AYP
Old Nov 10, 2014, 03:56 PM
Nice
Joined Nov 2008
J'aime avoir mon explication en Frenchie ! la ca va plus sauter le monsieur !
I like to see the explain in French language !If the pilot jump is that he brake his legs :-)
Helicoy is offline Find More Posts by Helicoy
Old Nov 11, 2014, 02:08 AM
RC Motorcycles are fun Bobby
King of the hill's Avatar
Australia, NSW, Royal National Park
Joined Sep 2013
Originally Posted by AYP View Post
Bonjour.
Hello.
Engine detail and steering damper on SR4 - nice AYP .
King of the hill is online now Find More Posts by King of the hill
Old Nov 22, 2014, 01:58 PM
Joined Nov 2014
Hello. I´m sorry to come up with a noob question, but I`m new on this forum. Just bought a Phantom 400 after reading about it here, and I just need to know if the gyro is supposed to start spinning when you connect the battery? Even if the power button is off? If not, Im going to return the bike and ask for another one.
torkorp is offline Find More Posts by torkorp
Old Nov 22, 2014, 02:27 PM
United Kingdom, Walsall
Joined Mar 2013
If it's wired the same as an Atomik MM450 then yes that's correct. The gyro ESC is wired direct to the battery.
Syncro is offline Find More Posts by Syncro
Old Nov 22, 2014, 02:52 PM
Joined Nov 2014
Thank you! Thats all I needed to know before loctiting and adjusting everything.
Old Nov 22, 2014, 05:59 PM
Joined Jul 2012
Hi, the ESC has no low voltage cut off also so make sure you disconnect the battery as soon as the main motor feels like it starts to lose some power. I don't think the main ESC has a cut either so just be wary not to run the battery down. Lipos won't tolerate the voltage going lower than about 3.2 volts per cell. So about 9.6 volts for a 3s. The std battery that comes with the Phantom is pretty sad in performance and run time. Hobbyking do a 4000 25c battery for the QRF that fits with a small battery box mod ( just cut the plastic tabs ) and performs better with huge run time. There's a few other bits here that fit the bike also such as the alloy swingarm ( grub screws needed ) and some different springs, I tried the longer orange one and am happy with it.
http://www.hobbyking.com/hobbyking/s...400_Parts.html
Old Today, 12:59 PM
San Jose, CA
Joined Oct 2003
hello all
For those that have this and SR4, which one do you recommend? this seems to be better looking. How does it"s handling compare to SR4?
Thank you.
yesbee1 is online now Find More Posts by yesbee1
Discussion New 1/4 dirt bike ? - CSF 411S - Nuova Faor King of the hill Motorcycles 4 Oct 17, 2013 01:23 AM
Sold NEW Psycho Cycle Dirt Bike Max Tech Motorcycle lmpbpd Cars - Motorcycles (FS/W) 0 Mar 12, 2013 10:16 PM
Sold Vmx dirt bike ruthee Cars - Motorcycles (FS/W) 2 Jan 31, 2013 07:46 PM
For Sale 125cc Dirt Bike - Trades? fordp Non R/C Items (FS/W) 0 Jan 25, 2013 04:43 PM
For Sale Vintage Kyosho Yamaha 250 Dirt bike ruthee Cars - Motorcycles (FS/W) 0 Jan 09, 2013 09:13 PM
