Old Feb 03, 2012, 07:39 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Mini-HowTo
10 dbic Crosshair antenna
For a full tutorial, please go here: http://fpvlab.com/forums/showthread....enna-tutorial!
This is the new Crosshair antenna developed as a joint effort between HugeOne (www.trueRC.net/Canada) and me (Video Aerial systems). It is a nice 10 dbic and incredible .98 axial ratio. Fits nicely on your tracker too!
We encourage hobbyists all over the World to try their hand at this design. While Hugo and I do open source this, we politely ask that it not be copied for commercial sale. We worked very dillignetly refining this design and we ask that you honor our work.
Below are the dimensions of this antenna for quick reference. However I put the build details only on FPVLAB under the VAS forum. The details on this antenna is critical, so I suggest you read the tutorial.
Materials needed:
1 sheet of copper or galvanized steel plate (I used galvanized steel)
1 Copper tube either or 3/8 (if using a balun build method)
1 coaxial cable
2 pieces of MIG welding wire or Memory wire.
4 nylon bolts
4 nylon nuts
Calculations:
Wire diameter in inches = 42/f in MHz to 60/f in MHz
Height over reflector in inches = 2350/f in MHz
Length of copper tube = 2933/f in MHz
Size of reflector panel in inches= 8800/f in MHz to 17500/f in MHz (larger reflector increases gain and F/B ratio)
Short leg length in inches = 2490/f in MHz
Long leg length in inches = 2945/fin MHz
If you want to buy them, you can find these at Ready Made RC, True RC, and Urban Drones
Have fun building!
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Feb 03, 2012, 09:50 AM
pr0ject42 is offline
Find More Posts by pr0ject42
CEL abuser
USA, CO, Denver
Joined Dec 2010
The mad scientist emerges from his lab with another awesome creation!
pr0ject42 is offline Find More Posts by pr0ject42
Old Mar 02, 2012, 05:01 AM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
what antenna works best with is on the tx side? I currently use a cloverleaf.
Gree is offline Find More Posts by Gree
Old Mar 02, 2012, 08:11 AM
Hugeone is online now
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Cloverleaf, windmill, skew planar wheel, turbine... as long as they are same polarization direction (RHCP >> RHCP) and good SWR match.
-Hugo
Hugeone is online now Find More Posts by Hugeone
Old Mar 02, 2012, 09:42 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
i just flew my quad 2000 feet away, behind roughly 60 feet of treeline. 10DB crosshair and lawmate 500mw TX on 2.4ghz. Really really great antenna. I used a CL on the transmitter:
gundamnitpete is offline Find More Posts by gundamnitpete
Old Mar 02, 2012, 09:56 AM
scrtsqrl is online now
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Will enclosing it in a Tupperware plastic box degrade performance?
Thanks for your awesome work.
scrtsqrl is online now Find More Posts by scrtsqrl
Old Mar 02, 2012, 01:43 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Not much. The thinner the plastic, the better.
-Alex
Old Mar 02, 2012, 02:53 PM
scrtsqrl's Avatar
Joined Oct 2006
-Alex
Sweet.
This one, as you said is less cumbersome than the helical. I'm sold!
Thank you.
Old Mar 03, 2012, 05:37 AM
Gree is offline
Gree's Avatar
Sydney, Australia
Joined Jun 2006
-Hugo
Great thanks very much...
Old Mar 09, 2012, 06:37 AM
Locko is offline
Find More Posts by Locko
Locko's Avatar
Australia, WA
Joined Oct 2011
Whats the Beam width?
Locko is offline Find More Posts by Locko
Old Mar 09, 2012, 06:42 AM
Team White Llama!
65 degrees for 10dB i beleive
Old Mar 09, 2012, 06:52 AM
Locko is offline
Locko's Avatar
Australia, WA
Joined Oct 2011
Cheers
Old Mar 09, 2012, 07:32 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Beamwidth:
55 degrees at 7dbic
90 degrees at 4dbic
120 degrees at 0 dbic
What this means it that the singal is just as strong or stronger than a skew wheel within a 105 degree beam.
-Alex
Old Mar 09, 2012, 08:08 AM
Papat is offline
Find More Posts by Papat
Pat K
The Netherlands
Joined Dec 2010
Would this antenna work well at 5.8GHz?
Does the difference in height between the center conductor and shield conductor matter? I guess in theory it should be 0 and will be more critical at 5.8GHz.
Regarding the matching balun, are the diameter/thickness of the tube independant from the frequency as well as from the size of the RF cable?
Papat is offline Find More Posts by Papat
Old Mar 09, 2012, 08:28 AM
nabazul is offline
Find More Posts by nabazul
Joined Jun 2010
this antenna is not working very well on 5.8 at least no one hast yet build a working one. But I would not say its impossible.
nabazul is offline Find More Posts by nabazul
For Sale GPS Unit CF W/ extra antenna out $10 Shipped! RChelisrule FPV Equipment (FS/W) 0 Mar 04, 2011 11:09 AM
What is the best Whip type antenna to use on a Joker and Logo-10 Lv2Fly Electric Heli Talk 11 Aug 12, 2003 07:19 PM
Antenna for Logo 10 Palmtree Electric Heli Talk 1 May 18, 2003 12:12 AM
Deans Antenna w/ Logo 10 ? jdowdle Electric Heli Talk 27 Dec 26, 2002 08:29 PM
